New Mavic 2 Firmware Released (11/23/2023)
43389 287 2018-8-24
MKPSG12
Flight distance : 341073 ft
I lost my controller icon/intelligent flight modes when i did this app upgrade! Had to uninstall then reinstall the app to get them back!
2018-8-28
PHL
Flight distance : 1044062 ft
HedgeTrimmer Posted at 2018-8-27 15:34
No they don't.  Pre-production FW
Pre-production FW is equivalent of Beta Software or possibly even Alpha Software.  DOT would be all over car company selling a car to public with Pre-production FW for say Anti-Lock Brakes which might fail to apply proper braking vs. traction or lock-up entirely because driver had their turn signal on.
Funny you should say that, as Tesla had that problem, and had to update their software as the ABS was causing the braking distance to blow out too far.
Saying that, the car is still safe, and I'm sure the Mavic 2 Pro/Zoom still flies with the pre-production firmware. I guess the balance is between getting your drone earlier, and update the firmware yourself, or wait longer.
2018-8-28
iAmChrisStone
Flight distance : 2283609 ft
I am getting "Update Failed." every time i update firmware or the No-fly Zone Database.  What am I doing wrong?  I do not have a micro sd card in there, yet.  Is that required?
2018-8-29
AForceOne
Flight distance : 7724367 ft
Used DJI Assistant to upgrade the Pro 2 and the controller with no issues. I upgraded before taking the first flight.
2018-8-29
iAmChrisStone
OK I just put in the micro sd card and it is still failing.   I am doing this via Assistant 2 on my Macbook Pro.  Please advise
2018-8-29
Rblomqvist
Flight distance : 1026260 ft
iAmChrisStone Posted at 2018-8-29 09:43
I also had issues updating the fw using assistant 2 on a Macbook Pro. In my case the download was so slow (I have 200 Mb/s, so not really slow) the at start full battery went below 50% when updating the drone = it failed. Then per instructions from DJI support, changed battery and used DJI Go 4.3.0 (on iPhone 8) and fw update was done in 20 min incl RC.
2018-8-29
iAmChrisStone
UPDATE!!!!!  If anyone else is having the same issue, here is what fixed mine.  Come to find out, I had Assistant version 1.2 and then I downloaded 2.0 and it worked perfectly!
2018-8-29
Dannyar
Flight distance : 140978 ft
I keep getting network disconnected error when trying to update via Go 4 app. Have restarted numerous times as well as trying using cellular instead of WiFi and every time it gives me the same error.
2018-8-29
lev_2551
Flight distance : 3953 ft
Austria
Not working for me either.
Network disonnected message via DJI Go 4.
Update error when updating via Assistant Vers. 2.
2018-8-29
Dannyar
Looks like the update servers are likely down.
2018-8-29
zuwerks
Flight distance : 51886 ft
fans98d63e0a Posted at 2018-8-24 10:12
I didn’t see mentioning if Crystal Sky monitors work with Mavic 2.  Do they?
Tech said no, not at this time..........
2018-8-29
zuwerks
WickedWingman Posted at 2018-8-27 08:16
THIS IS SO OBNOXIOUS!
i have the mavic 2 plugged in, but assistant just keeps searching for firmware in the list.  never finds anything.
the app won't download the firmware.  it just tells me i don't have a network connection, but i do.
same problem here........
2018-8-29
DCatalo
Flight distance : 3225748 ft
When will I be able to get the hyper lapse and dolly zoom on the Mavic Pro??
2018-8-29
OConnb
Flight distance : 15557484 ft
RichJ53 Posted at 2018-8-24 15:55
Std. DJI goggles with the latest FW work only on 2.4G. RE version of the goggles will work on both 2.4 & 5.8G bands. waiting for the latest FW for this to work.(coming soon)
You can see this information on the Mavic 2 pages
I tried my Goggles and it said it had to be after a certain Version! GRRRR They would not Bind!!!!!!!
2018-8-29
OConnb
DJI Susan Posted at 2018-8-24 23:26
Hey JohnnieYaz, it is estimated the 01.00.0600 of Goggles RE will be available in the next several working days, you may check later. Thanks for your patience.
hello DJI Susan,
How can I get my original Goggles working with the Mavic2 pro?
2018-8-29
OConnb
RichJ53 Posted at 2018-8-24 20:53
Don't know if FW 01.00.0600 is available yet. But FW 01.00.0400  for the Std. Giggles is available that works with Mavic 2
apparently not all! My goggles barked about a certain version being needed! And I do not believe it was referring to Firmware! I ran latest firmware on Goggles and could not get it to Bind without Version message.
2018-8-29
OConnb
JohnnieYaz Posted at 2018-8-24 20:35
I was wondering the same thing.. I don't use it but think you're right
Yeah I totally agree! That would have been so awesome!!!! But I guess since this is a Phantom 4 Pro in a Mavic Body, they did not want to stray too much? Maybe Phantom 5 will have Zoom? Or maybe we have to wait for Mavic 3 with 1 inch sensor and zoom?
2018-8-29
OConnb
MauiMaps Posted at 2018-8-24 16:25
Sparks downward sensing limit is 30m
Mavic Air 30m
Mavic Pro 30m
actually you get 2x optical then additional 2x digital on the ZOOM , so potential 4x!!!!
2018-8-29
RichJ53
Flight distance : 1837356 ft
OConnb Posted at 2018-8-29 18:48
That's a bummer. So, you have your new Mavic 2 Pro  or Zoom on the latest FW and you are using the DJI goggles RE?
I do not have mine yet but hopefully tomorrow
Rich
2018-8-29
RichJ53
OConnb Posted at 2018-8-29 19:08
The Phantom 5 (X)  should have retracting landing gear and removable cameras
Let's see what happens
Rich
2018-8-29
fans1d738190
OConnb Posted at 2018-8-29 19:00
Had no issue using the RE goggles today with the MP2
2018-8-29
lev_2551
Austria
lev_2551 Posted at 2018-8-29 13:27
Edit: Today it worked with assistant app
2018-8-30
Tresco
I cant get mine to activate. Very frustrated right now so I am going to try my best to make this post clean. DJI is doing nothing about it right now. I did the firmware update through the app just fine. When I get to the 8th step in the activation process it throws a network error message. Yes im online. Tried two wifi sources. Two ipads and a phone. Deleted and reinstalled the app a trillion times. The issue has to be on their end. I am now waiting for someone to call me back(no time frame) could be in three weeks from now for all i know. I bought this for a film gig and its useless at the moment. They told me to be prepared to send it back for repairs....
2018-8-30
RichJ53
Updated my DJI goggles RE FW version and linked to my Mavic 2 Pro. no problems for me. Did you use the latest Assistant 2 software? don't use the A2 for Mavic
Rich
2018-8-30
RichJ53
DJI Susan Posted at 2018-8-27 05:10
Hi Rich, it is ok to run the DJI Goggles without the extra antenna used for analog operation, no worries.
Updated my DJI goggles RE with the new FW and connected to my new Mavic 2 Pro  no problems!
Rich
2018-8-30
Tresco
All current software here.tech support told me to wait for an app update and that SHOULD work. Harbor freight has better customer support than dji!I'm at a total loss.
2018-8-30
Phan-TOM
Flight distance : 61184 ft
Cant get DJI assistant 2 to work. (Using V1.1.2 - 2)  Tried to update both my Zoom and Pro and had the same result. would not update "no Fly zone" or firmware. Anyone else experiencing issues with DJI Assistant 2?
[EDIT:]  I downloaded DJI assistant for Mavic 2 (which is odd that it is a seperate program from Assistant 2) and that did the trick.. I updated the firmware on my M2P and M2Z with no issues and then updated the Remote firmware through the app. all good.. I keep getting notifications when starting a flight though, asking me to update the geo-fencing data. I'm just going to keep ignoring that though, because I hear people are having trouble getting the drone to fly in areas where they should be allowed to fly.. a farmers little grass strip 4.5 miles away shouldn't keep you from flying. especially if you're part 107 certified. you dont need permission or notifications to fly near or even AT class G airtports under part 107.
2018-8-30
Buzzyone
Flight distance : 4647913 ft
No concerns updating the Pro 2 or the controller.
2018-8-30
fansd518084e
Hi Guys, using App on Android (HTC U11) the option to disable phone charging from RC is not available, however it is when i switch to iphone, any idea why?
2018-8-30
fansd518084e
Phan-TOM Posted at 2018-8-30 16:03
@ Phan-Tom
Had issues updating mine on Android phone and on PC, due to firmware signatures, ended up using Dji Go App, on an iphone, updated with no issues at all.
2018-8-30
BIGDZ Posted at 2018-8-28 22:38
I can’t seem to find the 2day dis charge function, is there not  an option on the M2 Pro, to change  it or is it just like the Mavic Air?
Hi BIGDZ, the battery automatically discharges to less than 60% of the maximum battery level when it is idle for more than 10 days. There is no option in APP for now.
2018-8-30
iAmChrisStone Posted at 2018-8-29 07:40
Hi Chris, do you refer to the Mavic 2 update? If yes, the SD card is not related with the update. Anyway, glad to hear it works now. Wish you have a good time!
2018-8-30
Dannyar Posted at 2018-8-29 13:01
Hi Dannyar, may I know which mobile device do you use and what's the APP version? It is recommended to update to the latest version to check. Alternatively, you may download the DJI Assistant 2 from Mavic 2 page and try to update.
2018-8-30
djiuser_qAL21CB3BvlU Posted at 2018-8-29 15:11
Well can say this the new DJI GO4 .24 update did fix the video lag and pixelation problem for me using samsung s7 however there are still  bugs which point to FW one the MA still drifts and doesn't like to fly in a straight line sometimes  also the drone seems to tilt  while hovering on the left side like the motors aren't  producing enough lift.
Sir, may I have the issue video of the Mavic Air and the corresponding flight data for better analysis?
2018-8-30
zuwerks Posted at 2018-8-29 17:39
Hi zuwerks, we've received some feedback about the server glitches before, but the issue has been fixed. If you have the same issue, please kindly download the DJI Assistant 2 from Mavic 2 page, restart all devices and check again. if no helps, please kindly offer the DJI Assistant 2 version and error message page, we'd like to check the exact status. Thanks in advance!
2018-8-30
OConnb Posted at 2018-8-29 18:53
hello DJI Susan,
Hi OConnb, the original DJI Goggles will be compatible with the Mavic 2 in the future update. We'll release our website as soon as it is ready. Appreciate your patience.
As for the hyper lapse and dolly zoom on the Mavic Pro, we have not got any news for now. If there is an update, we'll release on our website at the first time.
2018-8-30
Piper
Flight distance : 26946 ft
JohnnieYaz Posted at 2018-8-24 20:39
"DJI Goggles RE can only connect to the Mavic 2 with firmware 01.00.0600 or above via DJI Assistant 2 on a computer. Firmware 01.00.0600 will be launched at the end of August, 2018. Please stay tuned."
* Anyone see firmware 01.00.0600 release yet on assistant 2? I can't look without the RE google plugged in.
I downloaded 1.00.0600 and goggles still don't connect to Mavic 2 - I waited this long for Mavic 2 to seamlessly work with the goggles instead of my spark and they don't work. Seriously?????
2018-8-30
Tresco Posted at 2018-8-30 10:54
Hi Tresco, I'm so sorry for the inconvenience. May I have the aircraft SN, the APP version and the screenshot of the error message for better assistance? I'd like to check the current status and try our best to help you out.
2018-8-30
RichJ53 Posted at 2018-8-30 15:20
That's great! Glad to hear everything works now. Thanks for heading up.
2018-8-30
Hi Phan-TOM, it looks like the DJI Assistant 2 issue, please kindly download the correct DJI Assistant  2 For Mavic v2.0.0 from here: https://www.dji.com/mavic-2/info#downloads
Then refer to the tutorial video in #116 to check whether it works.
2018-8-30
