Left arm higher than right arm in full up mode
554 4 2018-9-2
joejohns
The arms on my i2 are operate exactly together in landing mode & in level flight mode. In FULL UP mode  both arms raise together & stop & then the left arm goes up another inch. Is this normal?
2018-9-2
DJI Wanda
Hi. Thank you for reaching DJI Forum. When the left arm went up another inch, does it leveled to the right or not?
2018-9-2
Nicksons
Flight distance : 2668717 ft
Argentina
Hello, I had many issues with my landing gear lately, finally Ive solved all of them by myself... I would like to help you diagnose your problem, If  you can upload a video of the raising arms getting the details for the finishing point of your middle frame from both sides, try to get clear sound too, its important to hear the servo working for diagnosing it, hoping to give you a solution or recommendation!!
2018-9-2
Nicksons
Argentina
Another question is.. Have you done the drone maintenance recommended in the manual? It doesn´t comes with the drone but you can find it on the internet...
2018-9-2
Matthew Dobrski
Flight distance : 1831050 ft
No, it's not normal. I will suggest to cancel any further flights until you check the performance of lifting mechanism. Some pictures or video made with hand-held aircraft may provide more clues. Take the propellers off while testing landing gear performance !!!
2018-9-3
