Why did my spark land in the sea Part 2 Log file attached
1076 10 2018-9-4
Harry Moman
Flight distance : 311240 ft
ok so i have finaly figured out how to upload a log file , as i cant see why my Spark just decided to land in the water ...
can you Pro's have a look at the log and tell me why and if i need to contact DJI about this ..
Thanks Harry
here is the Link
http://www.phantomhelp.com/LogViewer/TXD4PQLPO86TOF5G95U8/
2018-9-4
Warriewoodlad
Flight distance : 625230 ft
I had a flight log similar to yours. It was a longer flight, but the ending was the same.
In my case, I believe that I accidentally pressed the auto land button instead of the RTH. I also believe that it should've hovered at 0.3m waiting to get approval to land. However, I hear that the Spark is often unreliable close to the surface of water and may land in it. Luckily, I had Care Refresh and now am happily flying the replacement.
I hope that the experts on this forum can find a more favourable interpretation for you, and that you are flying again soon.
2018-9-4
Our apologies for the inconvenience. Kindly contact our support team to start up case : (https://www.dji.com/support?site=brandsite&from=nav). We have the professional data analysis team who would do their best to find out the crash reason and then the corresponding resolution would be provided. You can also provide your case number here in case you need further assistance. Thanks for your support.
2018-9-4
msinger
Flight distance : 228255 ft
According to your flight log, you tapped the auto land icon on the left side of DJI GO. Were you trying to tap the RTH icon?
2018-9-4
Harry Moman
DJI Paladin Posted at 2018-9-4 02:36
Thanks i did do one through my dji go app before only thing i did not add was my serial number ...
but by looking at my logs they should be able to help me ? I did not think auto land was even a option in sports mode .. as i did do a full throttle backwards , in which may have triggered this..
i was in line of sight but hey turn your head for one second on these things and thats the time somthing goes wrong !!!
2018-9-4
Harry Moman
msinger Posted at 2018-9-4 03:05
yes i only ever use return to home ,
if i did it was by accident
2018-9-4
Harry Moman Posted at 2018-9-4 03:08
I can't promise you anything but I'm sure our engineers can find out the main reason of the incident and will give  you a corresponding resolution. Make sure to contact our support team so that  we can create a case for you and provide your case number here in case you need further assistance, thanks!
2018-9-4
Aurelian (Spark)
Flight distance : 903350 ft
Is very simple: you pressed “auto landing”
2018-9-4
msinger
Harry Moman Posted at 2018-9-4 03:13
That makes sense then. It's a common mistake since those icons are so close together.
2018-9-4
Wolferl
Flight distance : 23793 ft
Yes, it looks like auto-land into water.
I'm not 100% sure but infrared sensors won't detect a water surface when lighted from nearly perpendicular above, right?
That would explain why his Sparky did not detect the water and stopped the descent.
I personally /never/ use auto-land or RTH. Only in an absolute emergency (loss of sight to Sparky, which did never happen to me yet).
Pro tip: When using RTH or A/L, have your finger ready in the pause button!
Cheers,
Wolferl
2018-9-4
Harry Moman
Thanks people I will leave it at that then a mistake by me
And a expensive one at that
R.I.P  Sparky
2018-9-4
