MadisonAreaDroneService
![](https://forum44.djicdn.com/data/attachment/common/65/common_11_usergroup_icon.png) lvl.2
Flight distance : 133340 ft
You can get around this for now, but you will have to change the Windows registry to allow the download and subsequent program usage to work.
You will need to access this and change it as follows: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System
and change the value EnableLUA to 0.
To understand how to change this value, do the following:
Click Start, and then click Run.
In the Open box, type %systemroot%\syswow64\regedit and then click OK.
OR
hit the Windows key and "paste" this: %systemroot%\syswow64\regedit by hitting "ctrl V" after copying the above bold text.
Once you have entered the registry, click on: HKEY_LOCAL_MACHINE then SOFTWARE then Microsoft then Windows then CurrentVersion then Policies then System
Next, you will see a dialog box with a #1. Change this to 0 and exit. Next, you will need to restart your PC for the changes to take effect.
Then, go the DJI site, download the Assistant 2 program again, and you should be able to use the program after a successful install.
Hopefully DJI gets this sorted out soon. Sounds like a recent Windows update may have triggered this. |
