Mavic 2 sensors & water
988 3 2018-9-11
KCMartin
Flight distance : 29974 ft
Curious if the new sensors on the Mavic 2 detect water when you fly too close over it? Thinking that could come in handy when flying over ocean, lakes, etc.
Keith
2018-9-11
Hi, Thanks for your inquiry. Please do not fly your aircraft close to the water or any reflective surface to avoid the incident on your drone. Kindly be responsible for using your drone. You can check the image below for reference. Thank you for the support.
2018-9-12
R&L Aerial photography
Flight distance : 298100 ft
I’ve flown full throttle sport mode 2 feet above the water surface many times without issue...
2018-9-12
KCMartin
I'll take it that the responses indicate that, NO, the bottom sensors on Mavic 2 Pro cannot sense when there is water closely under it.
2018-9-12
