Video recording capped at 4:50?
3554 25 2018-9-21
Zatx
Flight distance : 158166 ft
Last night I was filming my daughter's High School band practice for the directors and experienced a weird bug/glitch. I had several segments that were greater than 5 minutes (5:25, 6:30, etc.) in length as indicated when I hit the stop record button in the Dji Go 4 app, but when I went to view them, all cut off at exactly 4 minutes 50 seconds. Initially, I was trying to view them on my iPad so I just chalked it up to it being a cache issue or something, but when I got home and viewed the files on my pc, sure enough, all were 4:50.
Has anyone else noticed this issue or have any ideas what could have caused it? And before anyone asks (thought a Dji admin will still do so), yes, all my firmware and software is up to date and my sd card was reformatted.
All recording was done in h.264 4k HQ Normal mode so that I could directly upload them to youtube without editing. Bug aside, the M2P was incredible in this capacity. I hovered at 200ft on the 50-yard line for 30 minutes at a time and the platform was rock solid in 10-15mph winds aloft.
***Disclaimer: I am Part 107 Certified and possess a night-flying waiver and was not directly over anyone.***
Here is an example video, though I warn you these are pretty boring without the music:
2018-9-21
parkgt214
Flight distance : 1167008 ft
Haven't seen anyone else get 30 minutes of hover time, you have a rare M2.
2018-9-21
Zatx
parkgt214 Posted at 2018-9-21 04:14
Well, it may have been 28:37 and I rounded up. ;)
*This was after the batteries had seven cycles on them.
2018-9-21
DemolitionMan14
Flight distance : 1963583 ft
What was the file size of each clip?  My guess is they are around 4 gb.  That is the file size limit in FAT32 file system
2018-9-21
Zatx
DemolitionMan14 Posted at 2018-9-21 05:05
Bingo. They are in fact right around 4GB. So how do I get around that?
2018-9-21
simis
Flight distance : 405102 ft
Latvia
Looks that way, just format exFat and you will be fine
2018-9-21
Zatx
simis Posted at 2018-9-21 05:10
Are we given an option when selecting "Format Card" in the Go app? I don't recall seeing that.
2018-9-21
simis
Latvia
Zatx Posted at 2018-9-21 05:52
Duno, I'm usually formatting them straight on computer  after I buy one.
2018-9-21
spark-ch
Flight distance : 5547667 ft
Yes, there's an option to do that. In the camera settings menu if I remember ...
2018-9-21
Zatx
spark-ch Posted at 2018-9-21 06:28
Excellent. Thank you!
2018-9-21
simjs
Your issues is that the Mavic 2 Pro is obsolete and has a fish-eye Hasslebad camera. Like I stated earlier I usually format my memory card in exFat or FAT32. But I also have no clue what I am doing and just sort of google search answers and post them so take it with a grain of salt. Most likely it's an obsolete SD card that DJI created using another name.
I would try recording in P.236 format at 4k60.
2018-9-21
Zatx
simjs Posted at 2018-9-21 09:38
Wow, simjs, you sure have a bone to pick for some reason. Maybe you should consider not posting on forums and go outside and relax.
2018-9-21
simjs
Zatx Posted at 2018-9-21 10:02
Maybe you are just obsolete and upset that you have a fish-eye lense
2018-9-21
DRONE-flies-YOU!
Flight distance : 1638323 ft
Mavics write at a 4GB files size no matter how you’ve got it formatted. Exfat is just for greater than 32GB capacity, but writes happen around 4GB. The R/C will ping like you just started a recording.
2018-9-21
DRONE-flies-YOU!
simjs Posted at 2018-9-21 10:05
You’re going off of bad reviews from people too naive to realize that they don’t know how to use a camera properly. I shoot Normal Color (so as you know, my horizon is perfect with no distortion across the whole scene) and H.265. H.265 gives more clarity across the entire scene over H.264 - that’s it. The P4P I own does the same thing, except slightly warms up the image in 265.
I shoot 0 sharpness, 0 contrast, and -2 saturation. This gives me almost D-Cinelike. It looks fantastic straight out of the drone onto my high-end 10-bit 4k television prior to any file manipulation. The footage looks nearly identical to the vast amount of P4P footage I have. I prefer the footage to look as close to what I want my end result to be... you know, like real directors seek.
You’re knowledge about this Hasselblad camera is an illusion from keeping you from facing your own incompetence. You’re dead wrong about this camera, so give it up. Don’t assume we’re all fork lift drivers here.
2018-9-21
BlueSkies99
Flight distance : 3238 ft
Many video recording devices limit file size to 4GB.  My Canon 5D mkiv does the same thing.  When you drop the clips onto your editor's timeline they are seamless.
2018-9-21
simᴉs
DRONE-flies-YOU! Posted at 2018-9-21 10:39
What the **ll is wrong with forklift drivers? They don't let just anyone drive those things.
2018-9-21
simᴉs
I do not need a lesson on image processing, thank you..
My photos and video's come out so amazingly awesome that even when I go out of my way to record them out of focus, they still come out in focus.
2018-9-21
DJI Natalia
Hi, sorry for the inconvenience and trouble caused. Regarding your concern, can you please try to format your SD Card using your computer? Let see if this will work. Thank you.
2018-9-21
Wachtberger
Flight distance : 261509 ft
BlueSkies99 Posted at 2018-9-21 10:53
Exactly. One just needs to recombine the clips in post, that's all.
2018-9-22
A CW
Flight distance : 14588274 ft
Just use transitions in post production
2018-9-22
Zatx
Oh, I understand this can be done in post, but I needed to be able to quickly record, then upload for immediate viewing without the time requirements of editing/rendering.
2018-9-22
Zatx
I just checked and the SD card is formatted as exFAT while the internal memory is FAT32.
2018-9-22
A CW
Zatx Posted at 2018-9-22 08:39
Glad you found the answer
2018-9-22
eyecapture
Flight distance : 517848 ft
The easiest thing to do is switch to h265. It's a more efficient codec.
2018-9-22
R&L Aerial photography
Flight distance : 298100 ft
You think the earth is flat but it’s not, it’s been proven many times over. The David hasslehoff camera is simply catching the curvature of the earth...
2018-9-22
