New Release Notes For .500 FW
123456
15915 214 2018-9-26
HedgeTrimmer
HendrikJB Posted at 2018-10-7 00:34
Captain HedgeTrimmer and AndrewUK,
A VERY, VERY IMPORTANT POINT.
Stand a ways away from your craft once switched on as you may (will actually) cause a "shadow"
Thanks for tip.  But not a problem for me.  I usually backoff anyway.  Guessing 10 feet or more.
Really never had problems with Mavic Pro accurring GPS satellites.
2018-10-7
KlooGee
Flight distance : 16783757 ft
I've not had any GPS issues with mine either.  TTFL has always been quite reasonable based on how long ago my last flight was.  This is still the same with the 0500 firmware for me.
2018-10-7
KlooGee
AndrewUK Posted at 2018-10-4 16:23
Have they fixed the GPS acquisition issue?  This evening it took between 5 and 10 minutes to find a single satellite.  On the top of a hill with clear view of sky all around.  I think this regressed in 0.400.
I now resort to polishing off the previous flight's battery to acquire GPS which typically uses around 5%, power off, swap in fully charged battery, power on, GPS locks immediately, take off.
When this long time to acquire a GPS signal occurs, how long ago was it from the last flight?  And how far away are you from the location you last flew?
2018-10-7
HendrikJB
Flight distance : 2132792 ft
KlooGee Posted at 2018-10-7 08:30
This is a valid question only when one has tested the "constellation" with either of the 3 mentioned GPS apps.
One thing that I forgot to mention at the time is that a "skewed" constellation will also give erroneous data and fixing problems when the most visible satellites are on one side of the "sky" in a cluster, leaving the "other" side with only 1, 2 of even no satellites.
2018-10-7
KlooGee Posted at 2018-10-7 08:29
Just took Mavic Air out after 3 weeks and updated to .500, gps is very quick to connect and was the same with .400 etc..
2018-10-7
HendrikJB
hallmark007 Posted at 2018-10-7 09:45
Good to hear that.
2018-10-7
BobDoLe
Flight distance : 763094 ft
BobDoLe Posted at 2018-10-3 10:16
i benchmarked it - it was very fast and performs well. then i did a very long test for badblocks on it.. nothing came up... and THEN i formatted the card inside the mavic air. i'll see how that works.
fyi, formatting it fixed the issue. is formatting storage something that should be done after each firmware update?
2018-10-7
AndrewUK
Flight distance : 1403068 ft
Same flight location, next day.  Insists on taking several minutes.  If I use up an nearly flat battery to attain a lock, then power off, swap battery, power on, lock is instant.  So it's not to do with powering off and losing last location.
2018-10-7
HereForTheBeer
Flight distance : 5381368 ft
AndrewUK Posted at 2018-10-7 13:31
hmmmmmm, shouldnt take that long to get a lock.  not minutes on the mavic air.. the GPS module extremely sensitive and high gain, mavic pro or phantom 4 pro, 1 - 2 minutes its acceptable. but mavic air  should pick up signals quickly even if the sky was less than ideal....
2018-10-7
dzony
Flight distance : 426850 ft
Where do you live? GPS is generally slower the further north you go. I remember my trip to Finland was a bit of a shocker for me in that regard.
2018-10-7
suzan
hallmark007 Posted at 2018-9-26 07:24
I got it from downloads on the dji website, I would imagine it will be rolled out over the next few days,
wow good, Can we get it?
2018-10-8
HendrikJB
dzony Posted at 2018-10-7 14:45
IMHO this could only be partially true.  It fully depends on the "visible" constellation. As I`ve never had problems with other devices such as handheld GPS and it was before the GPS Apps mentioned I cannot really comment on the distribution of satellites in a constellation that far north or very south.
2018-10-8
AndrewUK
South of UK, phone and other devices never struggle to lock GPS.
When I took off yesterday after lock and setting of home point message, I noticed it unlocked and the drone accelerated up at crazy speed for a couple of seconds until it locked again.  It seems like GPS lock is critical to the stability of the MA, junk coming out of the GPS module seems to throw the flight control system and it behaves erratically in this scenario which I assume is happening.  I remember a couple of other people reporting their drone suddenly accelerated crazy fast and smashed into something.
It's definitely still very slow to lock with 0500.  Reset procedure time, I hope that doesn't reset the image numbering!
2018-10-8
AndrewUK Posted at 2018-10-8 01:40
When I took off yesterday after lock and setting of home point message, I noticed it unlocked and the drone accelerated up at crazy speed for a couple of seconds until it locked again.  It seems like GPS lock is critical to the stability of the MA, junk coming out of the GPS module seems to throw the flight control system and it behaves erratically in this scenario.  I remember a couple of other people reporting their drone suddenly accelerated crazy fast and smashed into something.
It just might be you have some hardware problem, I say this because I haven’t read much regarding this problem, might be time to send in.
2018-10-8
AndrewUK
hallmark007 Posted at 2018-10-8 01:51
Thanks, yes seems like me in isolation.  It's very consistent, powering up just ~18hrs after last use in the same location still took several minutes to get a lock.
DJI suggested using Assistant to reset the drone.  It's also going on about calibrating the vision system since 0500 update.  I'm certain it's not a hardware fault from new because it did not take this long to start with.  My MA has never been crashed or subjected to any other banging around.
2018-10-8
123456
