Ronin-S Calibration Screw
9606 27 2018-10-17
rookpsu12
My Ronin-S fell off a table and one of the grey springy calibration screws you use to tighten the arms bent.  I asked DJI support if I could buy a replacement and they said I'd have to send the entire unit back in for repair which is bonkers.  Anyone know if/where I can get new one?
2018-10-17
Hi rookpsu12, sorry to hear that, the spare parts are not for sale, if you cannot get one from other website, please send in at your most convenience for further assistance, thank you.
2018-10-17
rookpsu12
Again, asking me to send my entire unit back at cost because you can't/won't mail a screw is nearly as absurd as the amount of time it's taken you to release an accessory as banal as a mounting plate.
2018-10-17
rookpsu12 Posted at 2018-10-17 22:43
Could you please provide us with a picture of the grey spring screw and what is your location? Where did you purchase the Ronin-S?
2018-10-17
rookpsu12
Here you go.  I bought it here from a local shop in Hong Kong.
2018-10-17
rookpsu12 Posted at 2018-10-17 23:20
Thanks for the details, since you locate in HongKong, we are unable to send this spare part to you currently, as our support team recommended in the email, you can contact local dealers in below link to do a purchase or the local FlagshipStore for further assistance, thanks for your understanding.
https://www.dji.com/where-to-buy/enterprise-dealers GTScreenshot_20181018_184645.png
2018-10-18
rookpsu12
DJI Mindy Posted at 2018-10-18 02:49
https://www.dji.com/where-to-buy/enterprise-dealers[view_image]
And as I told them, no one replied to me.  And when I click on SERVICE on the HK flagships store website it ultimately tells me no service centers exist.
Lol, I'm a 15min train ride from your headquarters how could that be humanly possible.   What if I came to Shenzhen, could I get a screw there?
2018-10-18
rookpsu12 Posted at 2018-10-18 04:32
Sorry about the troubles. Could you provide us with your contact information in PM and leave a message here? We'll try our best to help you out.
2018-10-19
rookpsu12
PM sent, thanks.
2018-10-19
Received with thanks! I've responded you in PM, please kindly check later. Should there is any further question, feel free to contact us.
2018-10-22
Sir, I've sent you a message in PM, could you check and confirm? Thank you!
2018-11-5
fans01020c4e
Hi Susan, I have the same problem when the arm of my gimbal hit the side of the screw. I'm located in Singapore. Is there any way I could get a replacement?
2019-1-4
jamie
Hi. I'm having a similar problem. I've only used the gimbal about 5 times but already one of the screw holes is threaded. Can you please tell me how I can get this fixed? Or a new part sent out?
2019-4-4
soteroco
I have the exact problem as Jamie, the tightening screw seems to have a stripped hole and I cannot tighten it! This causes the arm to loosly slide back and forth making the gimbal unusable. I am located in the USA, any way I can get a part or tutorial on how to fix without sending in my rig?
The little screw thing inside seems to slide around is that supposed to do that? or is that the issue?
2019-4-16
lighttrap8745
jamie@fomostudios.co.uk Posted at 4-4 08:00
Same issue here. Is there any solution?
2019-8-26
fansb55fde82
Same exact problem here, too!  Need to know how to get it fixed.
2019-9-6
DiogoG
Flight distance : 48625 ft
Same problem here Jamie, in Roll arm. I cant move fast because Ronin loses calibration and went crazy...
2019-9-16
djiuser_q7yn5hFEsR6Q
Hi I have the same problem. The screw hole in my gimbal is cross threaded. The screw will not tighten and as a result the roll axis is not stable. Has anyone solved this problem?
2020-1-12
JPaez
Paraguay
I lost the screw and I can't find a place to buy a replacement
2020-1-13
fansd3bb7f04
Flight distance : 92172 ft
Estonia
I have the same problem. I unscrewed the plate and it seems like there is a metal spring like thread that fits in that aluminum hole in the arm. This has somehow unscrewed itself from the aluminum part and I cannot seem to be able to get it b back in. Any ideas or a method on how this works be done?
2020-5-29
ldouros
Flight distance : 71988 ft
I also have this EXACT same issue. It seems like this is a vulnerable part of the gimbal. I don’t question whether this is a problem for anyone else... can someone tell me if DJI has a solution?
Has anyone been able to purchase a spare part? It looks like the whole cap assembly needs replacing. I’m happy to buy one and have already disassembled and reassembled.
2020-6-25
mpater_colognehotmail.com
Although I am quite late to the game, I have the same problem. I barely used my Ronin S and the screw hole is not working anymore. Could someone provide me with information on how to fix this?
2020-8-2
DbXfBYMnQXTf
Portugal
I have the same screw issue, anyone here knows a solution?
2020-10-17
djiuser_CSgvG7VkGsQw
Ecuador
https://www.dji.com/where-to-buy/enterprise-dealers[view_image][Image]
Hi! I need the exact same part! I bought 2 ronin s and both are in the same condition! Can you please send them to me to Miami?
2021-2-4
djiuser_ka76ks8E6QTQ
I'm in the UK and the arm's screw hole is threaded too! This is such a common issue to everyone I was quite upset to see mine had the issue too. Is there yet no fix available?
2022-5-15
MahilDeva
Im' also in the UK and also with the same issue as everybody else here. Given how many people with this issue should there not be a cover to fix this precise issue? because this seems to be a manufacturing error...
2022-6-8
djiuser_MRjyR1tFvjVg
I have the same issue. I’m looking for the tightening screw for the arm. It will not tighten down anymore.
Where do I get that?
2023-1-6
bobbybooster
Philippines
I have the same loose screw situation. What can i do?
2023-4-9
