Need help with ESC question to Flight Controller A3
8484 12 2018-10-18
fans4d376b39
Flight distance : 2041 ft
Hi
I am trying to setup my A3 Pro and getting as mush info as possible.  Having said that, I am running the T motor 80A HV ESC and I am confused on the two different power sources I have to run.  I understand that I have to power the flight controller and will with 12s, but the separate power for the ESC I am a little lost.  How much power do I need for the esc? Also, what is the voltage range for the ESC power.  Much appreciated.  Thank you.
2018-10-18
fans4d376b39
In this picture is the wiring for the ESC and I circled in blue the wires that need to go the A3 flight controller, but there is just signal and ground.  I  see a power wire coming off the ESC, but I am not sure the voltage there (maybe 5v).  Would I take that red power wire and plug it in the middle of the signal and ground? Thank you. A3Pro.jpg
2018-10-18
fans4d376b39
Anyone, please help.
2018-10-19
Slav Webster
Flight distance : 5348 ft
Tmotor ESC connect to the A3 is very simple.
3 thick black ESC wires - must be connected to the motor
2 thick ESC R/B wires - connected to battery
3 thin ESC wires must be connected to M1-M8 A3 terminals. White wire from ESC must be connect to terminal A3 on signal pin on side notch key
everything.
2018-10-20
fans4d376b39
Thank you so much for your reply. So, does the red thin wire go in the middle of the white and black thin wire? I circled it in purple.
2018-10-20
Slav Webster
For A3 of the three-wire tmotor esc wire, only black and white line are important - the signal and gnd.
Red line is not needed  for A3 - its only power +5v,  but A3 has its own power supply (it seems + 9v)
White line - its PWM signal, not PPM.
2018-10-21
fans4d376b39
Ok, thank you so much. I thought I have read this forum that the A3 needed two different power sources for the actual flight controller and ESC's.
2018-10-21
fans4d376b39
This is what I read on here that the Flight Controller where the ESC's plug into need power into the FC.
Two power sources, one for ESC and the other for FC.
- power everything on
- run Assistant 2
- Calibrate all ESC
- props off continue
- everything starts to beep and doesn't stop
- unplug ESC
- Press continue
- plug ESC power back in and they all beep once
- press finish
2018-10-22
fans4d376b39
I appreciate everything Slav Webster, but just trying to figure out if I need the red wire in between the white and black.  Things I am reading on this forum say the flight controller needs a different power source for where the ESC's plug into.  Maybe a DJI moderator can help, please?
2018-10-22
fans4d376b39
All went well and I want to thank Slav Webster for helping me.....greatly appreciated.
2018-11-1
info.onboardcamera
Flight distance : 7828 ft
I have the same problem, but the FLAME ESC require 5v, if I get 5v from another pin of the A3 I can arm the motors, but every time I turn it on the craft I have to bind the controller, why?? Is there another solution for this red wire of the esc?
2019-9-6
djiuser_jA7nJHjC1Kyg
Flight distance : 919820 ft
i have the same problem I can´t start the motors . I tried exactly what dji says but dont work.
- run Assistant 2
- Calibrate all ESC
- unplug ESC
- Press continue
- plug ESC power back in and they all beep once...................this is the step that don´t work for me.
Please
2020-4-17
CASCARLOS
Colombia
djiuser_jA7nJHjC1Kyg Posted at 4-17 03:26
How do you  to solve the issue?
2020-8-9
