P4P+ / DJI Flight Simulator VIBRATE / BLEEPING
4582 11 2018-11-2
Ju97180
Flight distance : 1098330 ft
Hi !
Tested a Phantom 4 Pro Plus controller and it work but there is an issue with the vibration and red blue green light. It keeps vibrating all 3 secondes....
Anyone have the solution ?
Thanks !
2018-11-2
RenM
How did you connect the Controller in the first place? I cant get it to work at all :/
2018-11-3
Ju97180
I force the controller ( Port Com ) to use the  unsigned Driver from the DJI Assistant. All is OK but Vibrating is here...
2018-11-3
Bruno d'Andréa
How did you get the control on the pc exactly ??? I've tried everything here and I can not ...
(Como que você conseguiu conectar o controle no pc exatamente??? Eu já tentei de tudo aqui e não consigo)
2018-12-12
fans001342f7
Flight distance : 1618228 ft
South Korea
RenM Posted at 2018-11-3 15:43
Install DJI Assistant 2 - Which is compatible with your phantom
2019-4-11
fans001342f7
South Korea
Here's your "I have the same issue!" person.
2019-4-11
fans001342f7
South Korea
fans001342f7 Posted at 4-11 07:01
!!! UPDATE !!!
I asked DJI Via E-Mail, why this is happening and how to solve it
and they were Simply like, "It's compatibility issue. the DJI Flight simulator doesn't support P4PV2.0 Plus (Controller with built-in display)".
They did not suggested any of solution for it. sorry guys. this is it.
2019-4-13
djiuser_HGZXfWiKoQxd
Hungary
It is 2021 and the issue still persist!
2021-1-29
CCPuffingtonIII
I came here because I have the same issue.  Apparently there is no plan to address it?
2021-3-17
WeFly ApS
Flight distance : 6430187 ft
Same issue..
seems like a large amount to buy the simulator, when the remote issue is still not fixed... maybe buying simulator on steam is better... and a lot cheaper..
2021-5-5
Northernwolf
I have the same controller issues . My controller works in the flight simulator but the constant beep and vibration is annoying . The lack of DJI support is disturbing
2021-9-18
Privateer Spaz
Still no solution? That's pretty garbage that in 4 years they haven't been able to support their own controllers.
2022-2-18
