GS Pro 2
4991 13 2018-11-1
Keule
Flight distance : 3733015 ft
Groundstation Pro vers. 2.0 released:
GSPro 2
GSPro 2
2018-11-1
Hi mace, thanks for sharing this to our co-pilots. Have a safe flight always.
2018-11-2
CanonMax
Flight distance : 8953215 ft
When using the DJI GROUND STATION Pro 2.0 is it possible to get a kind of FLIGHT LIST like in the DJI GO 4 app... how nice that would be.
Or (as you use the same DJI account) combine it with the flights from the DJI GO 4 app?
Wow.... would that be great!
Happy flying!
(Canon)Max
2018-11-5
Keule
CanonMax Posted at 11-5 14:02
At the end of each flight, you have a log entry in GSPro.
You have to retrieve that entry (or multiple logs) manually for further usage.
You can store them on your local PC, upload to Airdata and so on.
The GSPro logs are not combined with your GO4 log entries.
2018-11-5
astaehli
Flight distance : 4313343 ft
Are you trying way points and are you able to define wp actions? by me wp actions are always N/A ... Manual says that after tapping on this function 15 actions are selectable ?
2018-11-6
Keule
astaehli Posted at 11-6 09:31
In your mission: under 'All Points' you must set 'cornering' to straight.
If this setting is 'curved' you can't set any waypoint actions.
2018-11-6
astaehli
Thanks for your  kind  answer
2018-11-6
Keule
astaehli Posted at 11-6 11:56
Glad i could help - Servus in die Schweiz :-)
2018-11-6
CanonMax
Keule Posted at 11-5 19:44
Herzlichen Dank...
Now I'll need to find out how to upload them to AirData UAV, because I like to see what happen(ed) when I was in the air
Danke schön… wünsche einen wunderbaren Tag!
(Canon)Max
2018-11-6
rmorse.mdesignz
Flight distance : 1404 ft
Unable to log in with my DJI credentials. Error message says:  Failed when creating account (CDUOLC, 2012)
2018-11-11
fansfe6a9925
Flight distance : 13625 ft
I have Version 2 of GS Pro and saw the same description, however, the 99 waypoint limit remains anyway. The app would not connect with my Phantom 4 until I reduced the waypoint count to 99, as the warning still remains within the app.
2018-11-17
Choerner
Also running into this limit with the DJI Gs Pro version 2.0.6 on iPad mini 4 and a Mavick Pro 2.
Any word on this?
2019-8-9
A J
Flight distance : 14588274 ft
Thanks for sharing
2019-8-11
Carlo’
astaehli Posted at 2018-11-6 09:31
DJI GS Pro, waypoint action. On the all points page set cornering to straight, then waypoint action menus are available.
2020-8-16
