Turn off Spark by turning upside down
6779 45 2017-9-11
Pashi
Flight distance : 4862598 ft
Dear DJI engineers! Will Spark turn off if it will be turned upside down by heavy wind?
2017-9-11
The motor will be turned off if the drone was turned upside down.
2017-9-11
Yes, it will...
2017-9-12
Wachtberger
Flight distance : 261509 ft
Actually 90° is enough already to switch off, doesn't need to be upside down. But that would need to be extremely heavy wind where flying is anyway impossible. Thus nothing to worry about but rather a good security feature!
2017-9-12
Pashi
DJI Susan Posted at 2017-9-11 23:35
So... If there any chances to be able to turn this feature off in next firmware?
2017-9-12
Pashi
Wachtberger Posted at 2017-9-12 04:25
Actually not very heavy wind + hard braking in Sport mode will be enough. I think this feature must work only in gesture mode or better it must be controlled via DJI GO...
2017-9-12
Wachtberger
I disagree, thats all I can add to this.
2017-9-12
Dronason
Flight distance : 5689042 ft
90°, tested is sufficient. Never seen in a flight record any way to reach that value. No reason basic wind will create a rotation. Only Spark motors can create it.
2017-9-12
Pashi
Dronason Posted at 2017-9-12 08:40
I don't know believe or not but one guy from another forum said that once his Spark was rotated by 180 degrees while braking in sport mode in strong wind but motors wasn't stopped and he managed to land...
2017-9-12
I have not seen an example of that just yet.
2017-9-12
Pashi Posted at 2017-9-12 07:33
This is a feature for Spark. I don't think it will be cancelled in the future.
As the User Manual mentioned, we do not suggest to fly in strong wind.
2017-9-15
Dronason
Pashi Posted at 2017-9-12 10:32
Do you mean his drone was upside down in braking ? And he was able to land !
Tried to play crazy in sport mode, tilt angle never higher than 70°.
I would like to see his flight record DAT file to trust it.
2017-9-21
rcayca
I think you should have the option to toggle the feature off. I get that it can be helpful at times, but I'm more worried about birds attacking the Spark and turning it sideways. If that were to happen, it would just fall out of the sky. At least if the propellers are still turning then there's a chance it can regain balance. Please really consider this.
2017-11-15
Viking-Pilot
Flight distance : 2379249 ft
rcayca Posted at 2017-11-15 13:44
I think it's a necessary safety feature as this drone is a beginner drone and most first time users will not have the skills to regain control if the drone tilts more than 90º, it could cause a much bigger damage to people or other people properties if the motors don't turn off...
2017-11-15
Viking-Pilot
Dronason Posted at 2017-9-21 08:45
Me too it's hard to believe...
2017-11-15
rcayca
Viking-Pilot Posted at 2017-11-15 13:53
Common now. I've touched the propellers with my fingers first hand. Trust me, it's not that bad. They're soft. You'll get minor cuts, but nothing too serious. It'll be much worse if the drone falls on your head from a high altitude due to a bird attack. The toggle should definitely be implemented. It should be the user's choice. Besides, if you have obstacle avoidance on, it's actually hard to grab the Spark in mid-air as it tries to distance itself from the ground.
2017-11-15
fans0c2e82a9
If the Spark turns 90° it will turn off this function is so if you crash to motors turn off.
2018-2-27
dj_dread
Flight distance : 648399 ft
Romania
the "minor" cuts are pretty bad. i've learned that the hard way. i would not recommend sticking your fingers into the propellers
i have seen no birds attacking the Spark so far and there were birds flying around my spark. i would say the birds will lose in this game
then, Spark indeed turn off if you turn it upside down. but it will resist as it is made to regain altitude and the normal fly (with propellers up). i've seen that as flying it, hit a branch of a tree and it stumbled but did not fall down.
if you hand catch your spark and turn it upside down it will turn off after resisting for 2-3 seconds.
2018-2-27
Arcicorsa
Flight distance : 235892 ft
Czechia
You can find lots of posts where the user has stopped the engines in Sport mode and unmanageable control ... I welcome this feature only in gesture mode.
https://forum.dji.com/thread-118986-1-1.html
2018-2-27
Cookster670
Have a think about the risk is of turning off auto shutoff.
With traditional Radio Control equipment, you can control your throttle and shut it off.   If you crash your plane or heli, your first action is to stop the props to prevent further damage
There is no “easy” way to stop the throttle on the spark,  (there is the little know kill process...which takes some time to take affect I believe).  So if you crash your spark, it will continue to spin uncontrollably on the ground causing more and more damage and presenting a safety risk.   It shouldn’t be an option...it should disable
I also happen to take advantage of this feature all the time.  I’ll hover the drone, come from behind and underneath to grab it and tilt it 90degrees to shut off.    It was very handy last week when I was taking off and landing from a small boat.  There was no room to land AND it was too choppy to give s stable surface.
2018-2-27
DJT_MVSP
Flight distance : 2018645 ft
DJI Susan Posted at 2017-9-15 01:04
This is a feature for Spark only. I don't think it will be cancelled in the future.
It works for the Mavic Air as well...
2018-2-27
Bing Err
Flight distance : 9249964 ft
If the Spark ever get's turned upside down (even if the motors keep going) I'm pretty sure it's toast. I don't believe it has hardware and software features to turn upright mid air like a cat. Although someday I'm sure DJI may add this functionality to future drones, they simply do not operate this way yet.
In drone crash videos it seems that if a drone starts tumbling in the air (end over end) there is no saving it. Thus, I don't see any reason to keep the motors going as it falls to the ground.
2018-2-27
Cookster670
Bing Err Posted at 2018-2-27 22:31
100% agree.  I think it would be foolish and dangerous to leave them running.   (and imagine all the DJI cases being raised saying "My drone  hit the ground then spun itself to death...DJI PLEASE FIX" )
2018-2-27
fansc15086a6
Flight distance : 4536073 ft
My spark flipped from hard brakeing and I
Have flight data probably why sparks fall from sky
2018-11-6
fansc15086a6
My spark fell from just brakeing and I have flight data
Probably a reason why they fall from sky
2018-11-6
DeuceDriv3r
Flight distance : 5035761 ft
I saw a guy catch a mavic by hand and roll it over to stop it
you sure?
2018-11-6
S-e-ven
Flight distance : 5922034 ft
Afaik Mavic / Air motors are stopping, when AC gets tilted over 90°
And isn't that a safety feature in all DJi's?
2018-11-6
Alex B.
Flight distance : 21105262 ft
DJT_MVSP Posted at 2-27 19:34
So the mavic air also turn off when it side ways or upside down just like spark? I don’t know coz I don’t have one I have a spark and a Mavic Pro, the spark I ALWAYS hand catch landing and then just fast turn it the nose down and it turns off, I actually like it, otherwise it would be impossible to turn it off that way when you catch it. I don’t know about the Mavic Pro, well actually it’s too big to turn it upside down like spark I also ALWAYS hand catch my Mavic Pro and keep the left stick down and the props shut off. Hell I even hand catch my Yuneec q500 )))
Flysafely all
Alex
2018-11-6
Bing Err
dj_dread Posted at 2-27 14:26
I agree with DJ Dread. DONT stick your fingers into the Spark blades while running. I got a really nasty cut the first month I had the Spark because I was trying grab it out of the air and it cut my palm wide open. Blood EVERYWHERE!
Don't listen to rcayca. Don't stick your fingers in running blades.
2018-11-6
DeuceDriv3r Posted at 11-6 04:27
you sure?
Thanks for heading up. As time goes by, this feature has been added for other models as well. After studying the attitude of various flying periods, if the drone has been flipped over to a certain degree for a certain time, the motor will be turned off to ensure the safety. Hope this helps.
2018-11-7
SAADHERO
Flight distance : 2269905 ft
Kuwait
wont having the drone be able to spin the motors backward help
so if its flips it can fly still
2018-11-7
fansc15086a6 Posted at 11-6 04:09
Hi there, we're sorry to read the crash. Just to verify, has the drone been retrieved? If yes, please kindly send it for diagnosis, we'll arrange data analysis and offer you a proper solution: https://www.dji.com/support If you encounter any difficulties during the progress, feel free to contact us with your case number, we'd like to help.
2018-11-7
wimherman
Flight distance : 208556 ft
DJI Susan Posted at 11-7 00:30
Hi Susan,
Just out of curiousity, can you get us more specific info about this item ? Like what angle, and time the AC has to be in that angle ? I guess we talk 2 angles here. X and Y
Thanks for your always good help :-)
2018-11-7
DeuceDriv3r
only thing I don't like about this 'feature' is that the motors cut off almost instantly as the aircraft approaches 90...
while not have happened to me personally yet... I live in an area with many large raptors.. hawks, falcons, osprey, and yes... even seagulls have been know to take a stab at brining a drone down
several videos out there of a drone taking a good hit , motors cut off either from tilt or (i believe) dji also uses some algo on the esc to shutdown motors if it senses a prop strike?  and the aircraft falls hundreds of feet to its demise...
2018-11-7
wimherman Posted at 11-7 00:49
Hi Susan,
This is different in various scenarios. You may refer to the below:
1. If the aircraft is close to the ground about 1-2 meters, the motor will be turned off immediately.
2. The protection will be stricter when the aircraft just takes off.
3. If the attitude is more than 75 degrees for a long time, and the flight controller cannot determine whether it is close to the ground, the motor will be turned off automatically. Hope this helps.
2018-11-8
SAADHERO Posted at 11-7 00:32
Hi SAADHERO, may I have a short video of your operation? We'd like to check the exact status and try our best to help.
2018-11-8
DeuceDriv3r Posted at 11-7 04:37
I understand your point and very sorry about this. It is recommended to stay away from the raptors and fly in open filed, safety is always the top priority.
2018-11-8
DeuceDriv3r
DJI Susan Posted at 11-8 18:42
Where do you think raptors hunt for mice and other things to eat. That also attach other birds and drones as they view them as a threat.
2018-11-8
wimherman
DJI Susan Posted at 11-8 18:38
Thank you so much for the detailed information!
My conclusion is that we dont have to be affraid that for example a strong wind gust will knock out the motors when flying higher than 2 meters. Since the delay will give the FC time to take controll over the AC again.. Nice.. Little wonders DJI makes !
2018-11-9
SAADHERO
Kuwait
DJI Susan Posted at 11-8 18:39
nothing wrong just something i would love spark to do so it can fly upside down if needed
2018-11-9
