HELP! Is there a Solution!?
2559 22 2014-9-24
simonfeaugas
Flight distance : 93146 ft
Dominican Republic
As you can see in the following pictures the camera is like pointing to a side. What could be the problem and the cause? Is there any solution?
Thanks in Advance! {:3_60:}
#1
#1
#2
#2
#3
#3
#4
#4
2014-9-24
hd_ultra
Look at that front rubber bushing it looks funky, Looks like it needs to be replaced.
My Channel
https://www.youtube.com/channel/UC6fqGgjRbBF83v1MF-TqfHA
2014-9-24
simonfeaugas
Dominican Republic
hd_ultra@msn.co Posted at 2014-9-25 09:11
What you mean by that? sorry
2014-9-24
hd_ultra
simonfeaugas@gm Posted at 2014-9-25 09:13
Looks like the white rubber isolator is broken. Between the camera and body.
2014-9-24
simonfeaugas
Dominican Republic
hd_ultra@msn.co Posted at 2014-9-25 09:16
the one on the left, right?
2014-9-24
hd_ultra
simonfeaugas@gm Posted at 2014-9-25 09:19
Facing the camera on the left. Check to see if it is in place.
2014-9-24
simonfeaugas
Dominican Republic
hd_ultra@msn.co Posted at 2014-9-25 09:20
Thanks!! Indeed it's broken, i have to change it.
2014-9-24
hd_ultra
simonfeaugas@gm Posted at 2014-9-25 09:24
No problem my friend. Always glad to help where I can. Those things tear real easy. When you put it through the whole use your fingers to pull it thru. Using a screwdriver to poke it through will tear the rubber very easy.
Good Luck.
2014-9-24
FromAdronesEye
Dominican Republic
hd_ultra@msn.co Posted at 2014-9-25 09:32
No problem my friend. Always glad to help where I can. Those things tear real easy. When you put i ...
Hey Ultra! I Have a question. When I change the rubber taking out the plastic security is not easy, I think the i have to "break" the plastic and put a new one. it's that right?
2014-9-25
hd_ultra
More than likely it will break. I did got mine off without breaking it. I used needle nose plyers, and gentle push downward, force to it. And they came off. There are extras in your little silver bag.
2014-9-25
FromAdronesEye
Dominican Republic
hd_ultra@msn.co Posted at 2014-9-26 04:02
More than likely it will break. I did get mine off without breaking it. I used needle nose plyers, a ...
Yeah I thought so, I just change them anyway I bought a pair more just for the next time! Thanks!
2014-9-25
hd_ultra
FromAdronesEye Posted at 2014-9-26 04:10
Anytime my friend.
2014-9-25
fadeawaychen
China
It looks like u have not removed the cap on the camera lens. The extra weight of the cap will cause the camera to tilt downwards.
2014-9-25
hd_ultra
It's  not the lens cap. his rubber ioslater was broken
2014-9-25
FromAdronesEye
Dominican Republic
Hey HD! I'm uploading some pic after changing the rubber but I think the camera it pointing sidesway, let me know if you know how to solve this.
Thanks in advance
2014-9-26
FromAdronesEye
Dominican Republic
Here are the picture, I dont know why this happend and how to repair it
#1
#1
#2
#2
#3
#3
#4
#4
2014-9-26
FromAdronesEye
Dominican Republic
If anyone out there can help I really appreciate it!{:2_27:}
2014-9-26
T J Gilbert
Flight distance : 74659 ft
Like fadeawaychen said, remove the lens protector.
It's hard on the gimbal motors to run them with it left on the camera when the airframe is energized.
With everything as it should be, see if your camera still leans.
The isolation damper didn't tear itself...
perhaps a flip over or a rough landing?
Leaving the lens protector on...
not a common thing, I hope?
The gimbal is a fragile mechanism.
Even minor mistreatment could be the root of your problem.
2014-9-26
hd_ultra
Can you send a pic that is in the right orientation.And with the cam in the up direction.
Thanks Buddy
2014-9-26
FromAdronesEye
Dominican Republic
hd_ultra@msn.co Posted at 2014-9-27 03:25
Thanks B ...
Uploading now!
2014-9-26
FromAdronesEye
Dominican Republic
Here you one, let me know if they work
#1
#1
#2
#2
#3
#3
#4
#4
2014-9-26
hd_ultra
I see it now a lot better.
You could try and fly it and bounce right to left hard a few times while your in the air. And see if it's not level.
After that if it's not level:
A full IMU recalibration in the software assistant may cure it.
See if this works for you. If not there are 2 other ways if it is a real problem for you.
2014-9-26
FromAdronesEye
Dominican Republic
hd_ultra@msn.co Posted at 2014-9-27 07:07
You could try and fly it and bounce right to left hard a few times while  ...
Thanks! I'll try that and i let you know!
2014-9-26
