PanGazer - a new app for extracting images from panoramas (etc.)
1749 4 2018-11-16
Speleo-flyer
I am happy to report that PanGazer 1.01 is now available at speleotrove.com/pangazer/.
PanGazer is a free (and advert-free) Windows application for viewing images and panoramas, including the 360°  spherical panoramas as captured by drones such as the Mavic series.
PanGazer features:
  • PanGazer detects spherical 360° panoramas automatically and you can pan around them easily, but you can also use it for viewing non-spherical panoramas and other images.
  • When viewing ‘hemispherical’ panoramas (e.g., drone panoramas, which typically cover 30° above the horizon and 90° below) PanGazer will automatically set the correct horizon.
  • You can save views to disk to extract individual photographs from a panorama. Unlike a screenshot, the saved image includes data such as the effective lens focal length of the view, the camera tilt and also, if known, the location and bearing and other metadata of the saved image.
  • In general, PanGazer tracks image geometry; for example, when zooming in while viewing an image the equivalent focal length of the view you are seeing is displayed.
  • If an image is geotagged you can show its location on a map in several ways (including Google Satellite or regular Maps, MapGazer, or Google Earth). You can also save the location as a GPX or KML file.
  • You can set North for any 360° image, to add compass points (N, S, etc.) to a view to give a sense of direction.
  • Multiple views (windows) are supported – you can view different images, or the the same image, from multiple angles and zooms at the same time. For example, you can compare still images with views projected from a panorama.
  • Strong viewing enhancements (brightness, etc.) are available to help you identify features of interest.
  • PanGazer uses a fast multi-threaded implementation of the gnomonic projection which reduces apparent distortion of horizontals and verticals. Interpolation is used to improve the display of zoomed or low-resolution images.
Mike Cowlishaw (speleotrove.com/mfc/)
2018-11-16
Sky Carrier
Flight distance : 590102 ft
Very informative. Thanks for sharing
2018-11-17
Thanks for sharing this informative thread. Cheers!
2018-11-18
Speleo-flyer
Some new features in 1.17:
* New ‘Set image geography’ dialog allows editing the location, elevation, bearing, and tilt data for images.
* New ‘Show tilt angles’ overlay optionally shows an ‘angle strip’ on the left of a view (similar to the compass points for bearings).
* The compass points and tilt angles overlays are shown automatically when the Image Geography dialog is open.
* New ‘Set horizon’ in pop-up menu allows setting the horizon for images (similar to ‘Set North’).
* Elevations can now be displayed in metres and feet (or both), and can be edited in either unit.
* Dragging an image to an open PanGazer window now opens a new window instead of replacing the existing image.
2019-5-2
PS013
Flight distance : 3579409 ft
Great!! Thank you very much.
2019-5-2
