Sphere Panorama mode only 27 Pics
1818 11 2018-11-19
zanve
Flight distance : 2222415 ft
Can anyone tell me why in the spherical panorama mode the Mavic Pro 2 (28mm) only takes 27 photos?  The Phantom 4 Pro (24mm) takes 34.
2018-11-19
Hi, thanks for the inquiry. We will forward your query to our team for further clarification in regards to the Sphere mode panorama of the Mavic 2 Pro. Thank you for the support.
2018-11-19
zanve
DJI Tony Posted at 11-19 14:50
Thanks Tony, it's not just a curiosity, I'm having trouble combining photos with the autopano pro software, probably not finding the contact points
2018-11-19
Balaes
Flight distance : 14241171 ft
Romania
I think because mavic 2 pro makes pictures at 20 Mp resolution. it's enough for 360 build. At lower resolution, is need more pictures.
2018-11-19
zanve
Balaes Posted at 11-19 22:48
no I'm sorry it's not like that! depends, if anything, on the focal length, in any case  the Phantom 4 pro has also 20mp
2018-11-19
F. Landmann
I can imagine, that you get in trouble to find stichtching points, and I hope that the optical system of the M2P ist better as the system of the P4P! The Lens distorsion in the corners of it is bad and the 34 photos of the P4P are rather close to the edge to get a stitching done.  For an easier stitching the P4P would need much more overlap.
I expected similar optical performance on the M2P and so I bought the M2Zoom to avoid any optical issues.   As I expected, there is no significant distorsion and only light-moderate vignetting.
The Mavic Zoom provides also 27 Photos (wide angle) in Pano 360, and it stitches well (mostly).
2018-11-20
zanve
F. Landmann Posted at 11-20 03:19
I do not know how much distortion can affect, but the m2 zoom has a focal length of 24mm, like the Phantom 4 Pro, so with the same shots the overlap points are greater.
2018-11-20
zanve Posted at 11-19 15:02
Hi, thanks for the response. Have you tried to use different editing software to see if the issue will persist?
2018-11-20
zanve
DJI Tony Posted at 11-20 10:20
From the last tests I did Autopano Pro did the Stich although not perfectly, I have to correct what is written in the title, the photos that produces the M2P are 26 and not 27.
2018-11-21
gnirtS
Flight distance : 5712575 ft
The M2 sadly does not tilt the gimbal up the full 30 degrees for sphere shot so it actually photographs less of the world therefore fewer images.
2018-11-23
A CW
Flight distance : 14588274 ft
The P4P takes 20mp stills.
2018-11-24
A CW
It is caused by the limitation of the tilt angle of the gimbal restricting the number of still images being taken in comparison.
2018-11-24
