Inspire 2 motors - one feels rough to turn (by hand)
3400 15 2018-11-24
GeoffG
Flight distance : 810082 ft
The tiltle says it all really.
I was checking prop mounts today and rotated each motor shaft in turn, back and forth.  One (the front right when viewed from rear) is definitely rougher to turn than the others.
I asked a couple of other people to do this test without telling them anything, and they both identified the same motor.  The other 3 motors all feel about the same, quite smooth.
It's only been used about 10 times and no crashes, heavy landings or anything untoward.
Has anyone else noticed this, I wonder?
2018-11-24
Matthew Dobrski
Flight distance : 1831050 ft
Definitely abnormal. Most likely a debris inside or a faulty bearing. Try to blow with strong compressor air gun thru vent gaps. Eventually motor replacement may be required.
2018-11-24
Altitude Drones
Flight distance : 1488520 ft
Might be a dodgy bearing. I'd have it looked at by an expert or just have it replaced,
2018-11-24
GeoffG
Thanks both,
It's still under warranty so I'll get it back to DJI.
It's strange because it feels like variation in the magnetic attraction as the rotor moves past the poles pieces on the stator rather than dirt or bearing breakdown.
2018-11-24
A CW
Flight distance : 14588274 ft
GeoffG Posted at 11-24 23:28
Thanks both,
Definitely return it if thats the case.
2018-11-25
Hello and good day GeoffG. I am sorry to know that you are having issues with one of the motors of your DJI Inspire 2. Since this issue is happening with one of the motors of your DJI Inspire 2. The best thing you need to do is to contact DJI Support at https://www.dji.com/support to create and open a ticket for your DJI Inspire 2. Thank you for your support.
2018-11-25
GeoffG
DJI Stephen Posted at 11-25 08:22
Thanks Stephen, I'll do that now.
2018-11-26
GeoffG Posted at 11-26 01:18
You are much welcome. If you have any other inquiries or concerns please feel free to post it here at DJI Forum. We are here to help you.
2018-11-26
GeoffG
I returned the I2 to DJI Europe and received it back last night.  8 days, door to door, which I feel is very good.  4 days in transit, 2 days inspection, 2 days repair.
4 new motors, 4 new ESCs and new prop mounts (white prop mounts are still stiff).   No problems, no discussions, job done.
Will test it today.  Thanks to all concerned.
2018-12-11
gersphoto.orange
Had the same problem with mine but the left one...
2018-12-11
GeoffG
gersphoto.orange Posted at 12-11 09:31
Interesting - I'm wondering whether the replacement will improve the erratic hovering performance of mine.  Hope so.
Was yours a warranty job?
2018-12-11
gersphoto.orange
Coming back from DJI Europe since july. It's a "new" one normaly but can't work whith that bird. Unstable, drift, toilet bowl,
2018-12-11
gersphoto.orange
GeoffG Posted at 12-11 11:12
What issue you had before changing motors ?
2018-12-12
JBSonic
Flight distance : 1050335 ft
gersphoto.orange Posted at 12-11 12:46
Yea the Inspire 2 has very poor position and altitude hold unfortunately. It is normal for it to move around several meters in any direction, up down left right.
Regarding the toilet bowl effect, make sure that you calibrated your compass properly and check that it is giving good data, also IMU calibration helps. But again, the I2 will never hold its exact spot (even a few meters over the ground in range of the Visual sensors)
There might also be firmware related issues, I use Crystal Sky and my compass just spins and spins around like mad, I believe it is broken in the firmware which may or may not get fixed at some point in the distant future.
If you want to more stable and reliable drone then I would recommend the Mavic or Phantom series, also the Inspire 1 is better than the I2 at holding position, dont ask me why because I have no idea
2018-12-12
gersphoto.orange
Yes I had an Inspire 1 to and it's realy better.
My Inspire 2 have a rotation on itself on raw axis, and then a toilet bowl if I don't stop this mouvement on GPS Mode.
In Atti mode can not stabilize, always living on right. Came back to left with RC controller, then it stopped and go back to right on itself
I never had an alert like Error compass or GPS
when the engines are hot it seems that the problem stops
2018-12-12
GeoffG
GeoffG Posted at 12-11 00:19
Finally got out to test it today.  All working, but just as before regarding stability issues (twitchy hover performance and drifting around).  I had a P3 originally, then P4. Both were rock solid compared to I2. Shame.
2018-12-19
