No flight log
1281 14 2018-11-24
Spacer2711
Flight distance : 821821 ft
I'm using a P3SE. The last few weeks I notice that no flight log is made anymore. Not with DJI Go and also not with Litchi. Is there a technical fault (with my drone) or does someone have advice what happends and how I can solve this.
2018-11-24
Hi, sorry for the troubles that it caused. May I know what happened before you noticed this changes? What is the version of your DJI GO app? Did you uninstall the app before causing to delete your flight logs? Please keep us posted for further help. Thank you for the support.
2018-11-25
lordgarth
Flight distance : 9642 ft
I just ran into the same Issue with my Mavic Air.  last flight logs are August.
2018-11-25
Lucas775
Flight distance : 50642090 ft
Following this thread hoping I would find my long lost single flight that would not show up on my flight log.
2018-11-25
Spacer2711
lordgarth Posted at 11-25 16:29
I see that the log files are made and saved. Unfortunately, the files are not seen by the DJI Go app. I use an Apple Ipad with iOS12. As soon as the weather conditions (locally) are better, I will continue my research.
2018-11-28
Spacer2711
Lucas775 Posted at 11-25 21:27
Just a curious question. Was your long flight broken at the end (connection problems or something else). And have you checked on your device whether the log file has been saved? I have noticed that a log file is not processed correctly when a flight is canceled because the signal is broken. At least with me.
2018-11-28
A CW
Flight distance : 14670299 ft
I have one of those too mate!
2018-11-28
Spacer2711
A CW Posted at 11-28 23:41
Can you remember if your flight was broken at the end?
2018-11-29
A CW
Spacer2711 Posted at 11-29 03:27
Not at all it just never synced
2018-11-29
A CW
2018-11-29
Lucas775
Spacer2711 Posted at 11-28 22:49
Yes, as a matter of fact I lost connection at 18,000 ft and I pushed RTH and took over when it was close to me.
2018-11-29
Flight distance : 2354357 ft
Even if the flight was broken it should still have saved part of the log, example, i fly with the dji goggles via the USB, because of this it means that i have to disconnect the device (S2) and connect the goggles once its in the air, i have always got a very short flight log from when it takes off til the point i disconnect the Tab S2
2018-11-29
Spacer2711
Bashy Posted at 11-29 20:26
@Lucas775 and @Bashy - II noticed that no automatic flight log is made when a flight is canceled. However, I do see log files in the appropriate folders. Go 3 does not process this correctly and Litchi and Go3  (both) doesn't send the files to 'Airdata'. As soon as the local weather conditions are good, I will try again.
2018-11-30
AH, i am referring to go 4, my bad, sorry ...
2018-11-30
Spacer2711
Just a small update. Yesterday I made a long flight. After about 18 minutes the drone came back and landed as expected. The flightlog is, as it belonged, available.
Then I made another flight (with another battery) and it was interrupted. The automatic RTH started. After returning there was no flight log.
2018-12-6
