The FAQ of Osmo Pocket(Continually updated)
1234Next >
45004 159 2018-12-18
DJI Support
Flight distance : 2408 ft
To make it easier for you all to learn the Osmo Pocket, DJI Support hereby summarized the FAQs in this thread. The questions in this thread will be continually updated as needed.
Also, if you have any questions, please feel free to comment below, we'll check and reply regularly, thank you!
Q: Does the Osmo Pocket supports AFS mode?
A: The firmware v1.4.0.20 adds focus mode switching toggle between AFC and AFS. We will continuously improve focus performance of Osmo Pocket through firmware updates.
Q: Is there a plan to add Pro Mode feature into the built-in screen of the Osmo Pocket?
A:
The Pro Mode has been added in the firmware v1.4.0.20. Please update the firmware in time to enjoy this feature.
Q: How do I change recording frame rate of Osmo Pocket to 24/25/48/50?
A: When the Osmo Pocket is connected to your phone, you can switch on the Pro Mode via Mimo app, then change the recording frame rate. The Pro Mode has been added in the firmware v1.4.0.20. Please update the firmware to enjoy this feature.
Q: Why does the audio track recorded by Osmo Pocket sound a bit tinny?
A: The Osmo Pocket uses its dual microphones, one below the built-in screen and one at the bottom of the product, to pick up audio signal. When you’re capturing video, please make sure these two microphones are not blocked or covered. Also, make sure the built-in screen faces you when you’re using the Osmo Pocket.
Q: I can feel the Osmo Pocket heating up when I’m using it, why?
A: The Osmo Pocket is capable of recording 4K60 video at 100Mbps, the actual file size of a one minute clip could reach 700MB. Such huge amount of data is processed by Osmo Pocket in real time hence heat is an inevitable issue. This is also true for other electronic products. To ensure system stability, we designed a T-shape heat dissipation system to continuously carry the heat generated to the part where the gimbal connects to the Osmo Pocket. According to our tests, the surface temperature will maintain in a proper temperature range.
Q: How long will the battery last while recording?
A: When not connected to any of its accessories and smartphone, Osmo Pocket can record 1080P30 video for approximately 140 minutes (at room temperature). Using higher frame rate, resolution, connecting to accessories and smartphone, and increasing the brightness of the built-in screen will shorten runtime. Temperature will also affect battery life. You can also charge the Osmo Pocket with 5V2A input while using it.
Q: How come the Osmo Pocket keeps charging my phone when connected?
A: According to AOA protocol of Android, Osmo Pocket must provide 5V 500mA power to the Android device when connected. This will result in reduced battery runtime, however, the Osmo Pocket allows you to charge it when it’s turned on. Adding an optional Wireless Module can also prevent the reverse charging from happening while not compromising advanced control and features.
Q: What SD card should I use with the Osmo Pocket?
A: The Osmo Pocket renders high quality 4K60 video and up to 12mp stills, so a minimum write speed of 20MB/s is required. And we recommend using micro SD cards with a write speed of 30MB/s or higher. You could see the micro SD cards we tested via the link: https://store.dji.com/cn/categor ... ?from=menu_products
Q: What’s the minimum focus distance of the Osmo Pocket? Can I take some close-up shots with it?
A: When in Photo Mode, the minimum focus distance is 10cm (approx. 3.9 inches). When in Video Mode, the minimum focus distance is 20cm (approx. 7.9 inches).
Q: How do I make sure the images and videos captured are in focus?
A: Osmo Pocket uses face detection to actively focus onto faces within the frame. By default, the Osmo Pocket will continuously focus onto subject in the center, but you can also manually select the focus subject by tapping the built-in screen.
Q: When will I have My Store Mode and D-Cinelike?
A: Story Mode has been added in DJI Mimo app v1.0.4 and D-Cinelike is now available in firmware v1.4.0.20. Please update the app and firmware to use these features.
Q: How do I properly hold the Osmo Pocket when it’s connected to my phone?
A: To securely hold the Osmo Pocket and your phone, we strongly recommend holding the devices with both hands.
Q: Will the smartphone adapter damage my phone’s data port?
A: The smartphone adapter of Osmo Pocket is engineered to enhance connection rigidity and data transfer so you don’t need to worry too much while using the device in normal conditions. We advise you to slide the smartphone adapter horizontally when connecting and disconnecting. Please do not twist, bend or spin the Osmo Pocket and your phone while they are connected and always hold them with both hands. To minimize damage caused when dropped, the smartphone adapter will disassemble to keep the phone’s data port protected. We plan to release and ship the smartphone adapters as optional accessory soon.
Q: Do I need to store the Osmo Pocket back into the carrying case all the time?
A: Mechanical gimbal is a precision instrument which is delicate compared to ordinary electronic products. The carrying case is a must-have item to properly protect the gimbal. You can refer to Quick Start Guide document for guidance.
Q: Is it possible to import the 4K video clip shot on Osmo Pocket to my phone for further editing?
A: Currently you could import 4K 24/25/30fps video to your iPhone 8, iPhone 8 Plus, iPhone X, iPhone XR, iPhone XS, and iPhone XS Max. As for Android devices, you may see a pop-up message about video play back compatibility. But you can still import the video.
Thank you for your support.
2018-12-18
Thanks for the info!
2018-12-18
dronie1965
Flight distance : 24971795 ft
Afc still keeps pumping. Footage useless
2018-12-19
dronie1965 Posted at 12-19 00:27
Hi dronie1965, thanks so much for your feedback. The AFC issue has been forwarded to our engineers and they will keep optimizing the experience in the future. Appreciate your support and patience.
2018-12-19
MichealMedia
Flight distance : 179026 ft
Nice move! Thank you!
2018-12-19
M2Wair
Flight distance : 1192231 ft
When will the accessories be available in the store!
2018-12-19
trica de
Flight distance : 1062090 ft
thanks - can you add this please
https://forum.dji.com/thread-175151-1-1.html
2018-12-19
S-e-ven
Flight distance : 5922034 ft
Good to know, thanks!
2018-12-19
djiuser_tTQVCmy2q4Wh
Where can I buy a tri pod mount for this camera? Love it but need a tri pod mount?Osmo Pocket Camera
2018-12-19
djiuser_sx50T3csduaB
When will I get my OSMO pocket if ordered on 12/17? Before Christmas?
2018-12-19
Luca Rubino
Flight distance : 711512 ft
djiuser_tTQVCmy2q4Wh Posted at 12-19 11:06
You may be interested in this gear: https://www.pgy-tech.com/18c-holder
2018-12-19
WebParrot
Flight distance : 23625 ft
Nice idea.  Thanks.  Suggest you add this as a link in the Tutorial Section of this Forum
2018-12-19
Curt1591
I really liked doing hyperlapses with my Osmo Mobile. I hope this will be available in an update.
2018-12-19
hashiko
Please please please make the beeping on start recording and end recording defeatable. Using the product in a quiet setting is impossible and defeats the descrete nature of such a promising product. The beeps draw too much attention, ruin candid moments and scares off animals, etc.
2018-12-19
rCkxMapY3Y8X
Just received my osmo pocket today 12/19/18, when turned on, panning to left makes a click sound On left panning only. Anybody else have this issue? Also updated to the  latest firmware.
2018-12-19
GeorgeGreek
Flight distance : 684104 ft
Thanks for the faqs!
2018-12-20
Mikail Sim
Any kind souls out there to advise which mode to use for taking ground or Low footage while walking ?
And which mode is the best ?
2018-12-20
rCkxMapY3Y8X
Mikail Sim Posted at 12-20 00:53
Just hold osmo pocket upside down. Works great.
2018-12-20
M2Wair Posted at 12-19 03:43
Hi M2Wair, we do not have the estimated date of the accessories for now. Sorry about this. You may keep an eye on our website or subscribe to the stock reminder, thank you!
2018-12-20
trica de Posted at 12-19 05:15
I've replied you in that post, please kindly check later, thank you!
2018-12-20
Hi there, there are three methods to connect the tripod:
1. Use the Osmo Pocket Wireless Module as a flat base.
2. Attach Osmo Pocket to the Extension Rod, which has a 1/4" tripod mount to which you can attach a third-party tripod or base.
3.  Attach Osmo Pocket to the Accessory Mount, which is capable of connecting to a tripod.
But we have not received any news the tripod for now, sorry about this. Hope it helps.
2018-12-20
trica de
DJI Susan Posted at 12-20 02:53
many thanks for this!
2018-12-20
djiuser_sx50T3csduaB Posted at 12-19 12:34
Hi there, could you provide us with your order number? We'd like to check the current status and see whether we can help.
2018-12-20
WebParrot Posted at 12-19 14:56
Hi WebParrot, thanks for your suggestion. I'll forward to the team for review.
2018-12-20
hashiko Posted at 12-19 22:26
Hello hashiko, sorry for the inconvenience. I'll forward this to our engineers for review.
2018-12-20
rCkxMapY3Y8X Posted at 12-19 22:37
Hi there, may I have a short video of your operation? We'd like to check the exact status.
2018-12-20
nisekorunner
Japan
Can't activate my brand new Osmo. This is rubbish... just keeps staying on the activation screen, never activates. Have tried with/without SD card, restarted etc. Help.
2018-12-20
BIG31
Ceci est très bien mais le problème de la batterie qui n'est pas interchangeable reste un GROS problème car parfois les batteries lâchent et dans ce cas le produit est bon à jeter.
2018-12-20
BIG31
English translation, my message in French is incomprehensible:
What happens when the battery is dead? the pocket is to throw? thank you
2018-12-20
Ray-CubeAce
Thank you for these updates. They are much appreciated. Particularly part 4. Useful to know.
Could you also please look at my post here and see if any of your stock Osmo Pockets behave in a similar fashion and if this is normal gimbal behavior.
I'm wondering if a part of the update didn't load as I see there are various components to the update and that the gimbal control is one of many parts that can be updated separately.
Thank you for the effort you are putting into replying to our queries.
2018-12-20
djiuser_ShKw2Tjsnqtz
Will you be adding face/active tracking for 4k 60fps?
2018-12-20
Will you be supporting 2.7k recording as well?
2018-12-20
rCkxMapY3Y8X
DJI Susan Posted at 12-20 03:23
https://youtu.be/f-s0wVNRrt0
2018-12-20
aznrage
Can I use a usb-c to hdmi cable to output photos and videos straight to a tv?
2018-12-20
Sayhelloforme
Flight distance : 8133219 ft
Great info thanks. I want one soon.
2018-12-20
fanseb96bbe7
Flight distance : 5653 ft
I don’t see the recharging case listed anywhere. I’d like to be contacted when this accessory is available. Thanks.
2018-12-20
trica de
A: When Osmo Pocket is connected to your phone, you can switch on the Pro Mode via Mimo app, then change the recording frame rate. Starting from January, we plan to progressively release firmware updates to bring these frame rate settings to the built-in screen of the Osmo Pocket.
YES good stuff!
2018-12-20
fans3d7e7463
Flight distance : 1339793 ft
If you have access to a 3D printer, you can get tripod mount design from thingiverse.com.
2018-12-20
Curt1591
DJI Susan Posted at 12-20 02:47
Many of the "aftermarket" accessory manufacturers seem to be predicting "the end of December" as their shipping date. My guess, since I presume DJI has outsourced many accessories, "end of December" might be a good guess.
We can hope!
2018-12-20
trica de Posted at 12-20 03:04
You are welcome. If there is anything else we can help, feel free to contact us.
2018-12-21
1234Next >
