Ronin S Screw getting loose
7117 5 2019-1-20
Pradipwb
Flight distance : 20545 ft
Hi
I am looking for this screw as this is getting loose every now and then and its useless forme.
Can you tell me where I can get this.
2019-1-20
Hi, thanks for the inquiry. Would it be possible if you could provide us with a short video of this situation for further help? You may upload the video using the dropbox or google drive for us to check. Please make sure that this screw is included in the video. Thank you for the support.
2019-1-20
fans5269cd92
Flight distance : 2286230 ft
DJI Tony Posted at 1-20 08:46
Were i .can buy  spare part?  I have same issue.
2019-2-15
Hi, thanks for the inquiry. If the item is already removed from the where it was installed, then I'm afraid that this situation needs to be handled by our repair team for them to fix it right away for you. You may also refer to the image below for the image that needs to be fixed. Please see the link below if you wish to contact our support. Thank you for understanding.
www.dji.com/support
2019-2-17
djiuser_RKGOKL7cr9B2
You can fix this with off the shelf parts. You'll need an m5 helicoil screw insert + tool to install it.
I used: https://uk.rs-online.com/web/p/thread-repair-kits/7037166/
35GBP / 46USD
If the insert came out completely you could just screw in a new insert from the kit. Once in break off the tap and get it out with a magnet / a bit of shaking. If the insert is inside the mounting point you would need to take the top off using an M2 allen key.
Worked like a dream for me!
2019-3-27
MahilDeva
I'v removed the inserts inside the mounting point, removed the threaded insert now just going to order the new one from the link you sent... looks like it will be working fine at this rate.. thanks for that - hopefully if anyone reads this they'll have some confidence that the issue can be fixed.. well, should fix. Im confident it will though
2022-6-8
