Trust This Device
2713 12 2015-7-20
jhall651
I never received the "trust this device" promt on my ipad mini 2.  Should it always pop up?  I am affraid to fly it because I do not want it to disconnect.  Any help?
2015-7-20
buzzcbr
Flight distance : 316545 ft
Dont worry its fine. It dosent always show, but when it does just select 'trust'
Its okay to fly with it like that, and if it should disconnect you still have visual contact to fly it back.
Buzz
2015-7-20
jhall651
buzzcbr@gmail.c Posted at 2015-7-20 23:57
Its okay to fly wi ...
Cool thanks
2015-7-20
DJI-Dave
Yep, always click "trust"
2015-7-20
Ulysse
Flight distance : 1389931 ft
To be sure I have this message, I always unlock the iOS device before turning on the RC. Here is how I proceed :
1. Connect the cable to the RC
2. Install the tablet on the RC
3. Connect the cable to the tablet
4. Unlock the tablet
5. Power on the RC
6. Click "Trust"
7. Power on the quad
8. Launch DJI Pilot app
Each time I didn't unlock the tablet before turning on the RC, I didn't receive the trust message.
2015-7-20
jhall651
I believe I am having an issue because of this. I have never been asked to trust it and I keep losing signal to the drone. I still have connection and I am able to fly but lose the FPV and it says no signal. I am thinking it is because I have never been asked to trust it. Is there any other ways to make it ask. I wish it would just ask once so I could at least eliminate that issue as being the problem. When I do lose signal all I have to do is pull cable and plug it right back in and I instantly have signal again. I have tried 2 different iPhone 6 cables that are in perfect condition. Both did the same.
2015-7-20
jhall651
Anything guys and gals?
2015-7-20
terrylewis
Flight distance : 3517287 ft
Trust this computer is an IOS sub dialog..... See this: Apple KB
2015-7-20
Willie Wonka
Turn on controller then phantom, turn on iPad, connect controller to iPad, DO NOT TOUCH THE TRUST THIS DEVICE ,it will go away, click on the dji pilot and fly.  If you trust the device then you will get disconnection in the middle of the flight and you WILL have lag on video.
2015-7-20
jhall651
terrylewis Posted at 2015-7-21 07:27
What do you mean it is a sub dialog?  Could that have anything to do with my signal lose?
2015-7-20
jhall651
Willie Wonka Posted at 2015-7-21 07:43
Turn on controller then phantom, turn on iPad, connect controller to iPad, DO NOT TOUCH THE TRUST TH ...
This is the first I have ever heard that you should NOT trust the device?... You sure about that?  Even if so my iPad will not even give me the prompt.
2015-7-20
Willie Wonka
jhall651 Posted at 2015-7-21 09:10
This is the first I have ever heard that you should NOT trust the device?... You sure about that?  ...
What I ment don't click on any of the choices in the box when it pops up.
2015-7-20
richardpwills
This prompted me half way into a flight last week. It crashed the app but it restarted after 5 seconds. The P3 just hovered. I was in a rush to get a shot so turned on the ipad - opened DJI Pilot and stated flying.
.  I will always make sure to press trust before the flight begins from now on to avoid this happening again.
2015-7-20
