Low lens quality and huge distortions
1531 38 2019-1-5
Mishmish
Israel
So disappointed with the Mavic 2 pro quality results. A lot of noise, barrel distortion which is not yet available as a fixing filter on Photoshop and a lot of blurry areas around. Seems that even the Mavic was better. 1" sensor and great new lens? Don't think so.
2019-1-5
FatherXmas
Flight distance : 4058619 ft
Both of my M2Ps have great photo quality. I wonder if yours has a camera issue.
2019-1-5
Mishmish
Israel
I wonder but it's new of course and repeated results in sun and cloudy days. I've noticed that each time someone is complaining about huge distortion and blurriness the reply of DJI is usually - check the hardware. Too often. Cheers mate.
2019-1-5
_Yannik
Hi, the noise and distortion can be corrected easily in a Raw converter. A bigger problem seems to be that there are good copys of the Mavic 2 Pro with sharpness all over the image and bad ones with partly blurry areas. At least I have my second one already and still have a blurry area in every image. Very frustrating!
2019-1-5
Fre Mo
Flight distance : 803868 ft
Could you post some pictures and videos to show us these features.
2019-1-5
Lisi
I have the same problem. My first camera in MP2 had blurry area near the center of all images, here is an example - https://1drv.ms/u/s!AnsoxnsGSBOLsXdTNwEzjFADFwLc
I sent MP2 to my reseller to fix this issue and after 3 weeks I got my drone back. They replaced camera module and this one is better but now blurry area is on the right side, left side of each photo is much better than right side... When I set focus to infinity + 0.5 bar (in DJI GO app) then blurry part on the right side is slightly less visible but another blurry part appears - on the lower left side of image. Setting aperture to f4.0-f5.6 helps a little but blur is visible on each photo.
Here are pictures from my drone after camera module replacement - https://1drv.ms/f/s!AnsoxnsGSBOLshyG4mbbTrNreWCI
I have to send my drone for repair because controller stopped working (it's totally dead after charging using DJI charger) and I am puzzled because I don't know if to report camera issue together with controller issue. If I'll report camera issue then I may get 3-rd camera module with blur on another part of images but mayby luckily I'll get a sharper one...
2019-1-5
_Yannik
Hi Lisi,
that is very frustrating! I just sent my second and still not working M2P to DJI and they say it is within normal tolerance. So disappointed of the support! Here are some 100 percent crops of my M2P. I am a professional photographer and wanted to built up a drone portfolio, but if this quality is within tolerance, then I might better give the M2P back to the reseller.   i
2019-1-5
Mishmish
Israel
Fre Mo Posted at 1-5 10:39
Here is one. They all rather suffer from low quality in general as well.
2019-1-6
djiuser_jBXOnzT6p8Z1
Flight distance : 507087 ft
My guess is the actual camera modules on Mavics are a fraction of the cost of the drone, perhaps 3% -5% of manufacturing cost.
So on a £1000 drone which perhaps costs £200 to make including battery, remote etc before upmarking the camera sensor/lens/housing may only cost 5 to 10 dollars.
Of course, it's perhaps not fair to look at it this way as it doesn't include DJI's R&D and buying power but it perhaps does explain why these things are not equal to 'proper' photographic equipment.
For that they have Inspires etc.
2019-1-6
Flight distance : 11959747 ft
djiuser_jBXOnzT6p8Z1 Posted at 1-6 09:07
I think you will find after any crash camera is by far the most expensive part to be replaced, so I’m not sure this tallies with your 3%....
2019-1-6
hallmark007 Posted at 1-6 09:38
I think you may find that what DJI charge you for a replacement camera may not be quite commensurate with what it costs them ... .
It probably bears very little resemblance.
2019-1-6
Would DJI sell the cameras separately I personally would expect to pay around £120 for the Zoom, perhaps £350 for the 2Pro (not because I think it is worth that much more but simply because DJI decided to charge 300 quid more for the drone with the cam being the only difference ... ). That, my friend, is Marketing for you.
Neither would have cost them more than a few dollars and thats ok.
Now, the camera with the thermal imaging module on the Enterprise Dual is a different kind of kettle. The FLIR thermal unit is not cheap. In fact, if you look at how much you would have to pay for an equivalent stand alone unit you are probably looking at cost somewhere in the region of 2/3rds of the whole drone, perhaps even a smidgen more. - Add to that the DJI technology which combines the conventional camera with the thermal unit to increase read out and improve on the FLIR and it makes that drone the best value unit in the Mavic line out ... that is if you need thermal imaging!
2019-1-6
Ps. I hope DJI will make the thermal combination camera of the Enterprise DUAL available to Mavic 2 owners as an aftermarket option. I also hope they would price it at or a little South of a grand.
It would make this a viable option for commercial applications for Mavic 2 owners without having to buy a new drone
Having said that, that may be the reason they will not do so ... .
I hope I am wrong as I for one would be interested.
2019-1-6
djiuser_jBXOnzT6p8Z1 Posted at 1-6 12:00
You miss the point, this has nothing to do with what it costs dji, the post was regarding the percentage cost of the camera as opposed to the rest of the parts of the drone, the poster claimed it probably cost 3% of the total cost of the drone, which just doesn’t add up, so my point being if you crashed the single most expensive part to replace would certainly be the camera.
2019-1-6
djiuser_jBXOnzT6p8Z1 Posted at 1-6 12:23
I don’t think you will ever see the dual camera available for M2.
2019-1-6
djiuser_ZFUaSaOBgIxz
My problem is with noise in good light and at ISO100. I tried to remove some of it in LR but any more and any sharpness is gone. Maybe I am doing something wrong or just expecting too much. Probably a combimation of both. Think I will tweek some settings and pay more attention to the histogram.
2019-1-6
Bussty
Flight distance : 359705 ft
djiuser_ZFUaSaOBgIxz Posted at 1-6 13:32
My problem is with noise in good light and at ISO100. I tried to remove some of it in LR but any more and any sharpness is gone. Maybe I am doing something wrong or just expecting too much.[view_image] Probably a combimation of both. Think I will tweek some settings and pay more attention to the histogram.
For special images AI Gigapixel can really clean up the noise and ADD detail! Crazy I know but it works.
See this thread over in mavic pilots
2019-1-6
Phantom_Film
Flight distance : 1609482 ft
I also have noise in my photos, even day photos with iso 100. Hearing how great the camera  and image is,  i was worried it was my idea about the noise... but it is not.
I have sent it in for gimbal tilting problem, the transmitter opened somehow in its top right, and a dead battery after 11 flights. Thankfully battery died before i fly it.
I think this mavic 2 is having too many issues already.  Dji someday will have to apologize for taking people's money and have them waiting not being able to fly, for service or replacements.
2019-1-7
_Yannik
If you shoot Raw, then you can remove the noise pretty easily in the Raw converter. I use Capture One Pro 12 and the results are great!
2019-1-12
Mishmish
Israel
Thanks Yannik. I actually have the Capture 10 so worth a try but the blurriness on the left is just a manufacturer problem. In video mode you hardly note.
2019-1-12
_Yannik
Mishmish Posted at 1-12 10:23
That´s true. I hope you get a well-working M2P soon. Good luck!
2019-1-12
_Yannik
I just received my third M2P and this one is even more unsharp than my two previous versions. Pretty frustrating! I will have to send it in another time. Hopefully number four won´t have a blurry right side!
2019-1-25
Mishmish
Israel
_Yannik Posted at 1-12 11:01
That's is rather frustrating. It looks even worse. Mine wasn't even picked yet and I need it for work (archaeology). I'll update with any positive news. Hard to understand how they can get so bad. In other aspect I'm pleased but I bought to capture stills not to fly.
Michael
2019-1-26
_Yannik
Hi Michael, same with me. I need it for my photography clients and that´s the only reason why I bought it. Here are two more crops to show the big issue.
2019-1-26
EnricoBrun
Flight distance : 917087 ft
you make me worry, where are blurred areas?
2019-1-26
DH_Pilot
Flight distance : 3301621 ft
Slovakia
EnricoBrun Posted at 1-26 07:36
According to my opinion they look quite good. By the way nice photos.
2019-1-26
EnricoBrun
DH_Pilot Posted at 1-26 08:28
Thank you! And they are original without post retouching, and here posted are also less beautiful than I see them.
2019-1-26
EnricoBrun
even with little light, no significant aberrations are known
2019-1-26
HedgeTrimmer
Mishmish Posted at 1-26 01:29
Michael
See recent scandal at DJI involving some of DJI's employees.  Accorrding to DJI, what has been discovered and reported thus far, is "tip of iceberg".
2019-1-26
HedgeTrimmer
EnricoBrun Posted at 1-26 08:41
Okay, your MP2 doesn't have photo problems.
How does that help those with MP2s that do have problems?
2019-1-26
EnricoBrun
HedgeTrimmer Posted at 1-26 09:01
That was not my intent, I just wanted to understand if they were all provided with these aberrations, because the photos I saw posted here I did not see anything so little defined. That's all
2019-1-26
EnricoBrun Posted at 1-26 09:07
Great photos, your camera works the same as mine and I expect most others, but it looks like OP has got some Duds for some reason , the photos seem so blurry that it looks like aircraft could be moving around when shots are taken.
2019-1-26
Mishmish
Israel
hallmark007 Posted at 1-26 10:25
Hi, that's not the issue. Blurriness only in one or two parts of the photo. I have it all along the left side, Yanick has it each time on a different area after replacement etc. It is not barrel distortion. It is a a company fault which most probably they are aware of as got thousands of complaints.
2019-1-26
Mishmish Posted at 1-26 11:23
I only see two complaints here, and I didn’t say what was the problem I surmised, I did say you got a dud, now maybe you can point me to the thousands you are talking about, this thread has been up here for almost 3 weeks yet I see only two people with problems on this thread and I haven’t seen any other thread.
2019-1-26
El Diablo
2019-1-27
Francis
Flight distance : 774203 ft
Please, tell me. Am i lucky man or blind man?
2019-1-27
Francis Posted at 1-27 15:40
It maybe your settings are what they should be.
2019-1-27
Francis
I can notice a little softness, maybe, in this still. I m from analog film age. Nothing was too sharp as today. I m journalist and  use M2P to make broadcast tv videos, All videos are sharp and very good. White noises on dark areas in low light shots are only my complain. But after i read this topic i took some still shots to test my unit.  Is there any problem here, please?
2019-1-27
M Stuart K
Flight distance : 1329629 ft
Mishmish Posted at 1-6 08:40
Looks like a focusing issue to me.  Mine has been spot on from day one.  Sorry about your issues but mine captures outstanding photos and video.
2019-1-27
