Mavic 2 short distance in europe
8541 22 2018-8-30
TomiToivonen
Flight distance : 722343 ft
Finland
First day with the new Mavic 2 Pro. I am very satisfied with the image quality, but very disapointed in flight distance.
In Helsinki, suburb area (only small houses) I was able to reach 700-750m (2300-2450ft) distance when I got image transmission errors. I was able to pilot OK, but the image was cutting. No buildings in between, but some trees, when drone was ap. 50m (165ft) high.
I have iPhone 7+, WiFi disconnected, remote and drone updated, dual channel on, normal image quality selected.
Is there anything else I could do? I would of expected at least 1000-1500m (3300-5000ft) distance.
2018-8-30
Alex Batalov
Flight distance : 24101106 ft
Change to fcc
2018-8-30
gnirtS
Flight distance : 5712575 ft
Its a mavic 2.  You can't.
2018-8-30
Alex Batalov
I only have a spark. I read that the fake gps app trick works also on Mavic air apart from spark.
I mean you can try to do the fake gps app trick, it might work!
There are many videos on YouTube how to change from ce to fcc using fake gps app trick on Android.
Pease try and report back here if the switch was successful.
Fly safe.
Alex.
2018-8-30
Alex Batalov
There is also the BOOST FCC 1.5Watts patch that only works on Mavic Pro 1on OcuSync,
And therefore it might be possible to install it on Mavic 2 also.
https://forum.dji.com/forum.php?mod=viewthread&tid=163195
Fly safe everyone.
Alex.
2018-8-30
gnirtS
It won't work.  Firstly the Mavic 2 doesnt use wifi and secondly the versions of Go4 hacked for FCC are old.  The MP2 requires the latest Go4 which has not been cracked.
Fake GPS hasnt worked for ages on occusync.
And anyway that isnt the issue, he should be getting 5x that range under CE mode so clearly something else is wrong.  Simply hacking it to be illegal wont fix that.
2018-8-30
Alex Batalov
Then I advise to try in a different area and maybe also try on another device.
Safe flying.
Alex.
2018-8-30
fans1a444724
Flight distance : 3282805 ft
Indonesia
gnirtS Posted at 2018-8-30 11:58
This works on OcuSync v1.0/v2.0
2019-1-29
Alex B.
fans1a444724 Posted at 1-29 01:34
https://www.youtube.com/watch?v=ukntSNAudV4
Wow, does fake gps app trick really works like it’s showed here on the mavic 2???
Fly safely
Alex
2019-1-29
raven swe
Flight distance : 517936 ft
as far as I know this is only for android and you have to mess around each time you fly,
2019-1-29
I've flown to 6000ft over sea without issue on the Mavic 2 pro and based on the spec I would expect to be able to get further if there wasnt any interference.  However on another flight at 1200ft  I got break up of video due to the landscape (big hill in the way).
2019-1-29
Buzzyone
Flight distance : 4647913 ft
Make sure you have latest firmware installed and check antenna orientation if they are out straight you will limit your range.
Im in the UK so also CE and can easily get 2000mtrs without any messing about.
2019-1-29
Check out the video for correct antenna position.
2019-1-30
EnricoBrun
Flight distance : 917087 ft
I confirm, also in Italy, in flight in the countryside reached 4000m, radio and video signal with 2 notches
2019-1-30
Hobbiebop
gnirtS Posted at 2018-8-30 11:43
Yes you can!!!!!!!
2019-5-15
Daltair
Flight distance : 1167723 ft
Is it possible to increase signal with some reflectors? Or this just waste of time?
2019-5-16
SPIKE_151
Flight distance : 69767 ft
Windsurfers may give you a small increase in signal strength. Better to go to an aftermarket antenna like the Raptor SR or XR, the Titan Switch or half a dozen other manufacturers that make them. The antennae on the M2 are +3dB, going to a high dB gain antenna will increase your distance. Then there are boosted systems which can give you up to 3 watts of amplified power, but these are not normally dual band, which means you have to chose 2.4 ghz before taking off. I have the titan switch 3 watt amplifiers with +9dB whip antenna and I get full 5 bars signal on video and remote control at 5 km distance.
2019-5-16
Dronie2
Flight distance : 1336365 ft
I have almost reached 3 km in a mountain area with signal Ok.
Mavic 2 Pro and Smart Controller.
2019-5-16
Decebalus
Flight distance : 203806 ft
Romania
Climb to 100 m is you have some trees between you and the drone ..
2019-5-16
jpap
Flight distance : 1780679 ft
I found this topic because I was facing severe signal issues on MP2. I was flying close to the edge of a city, with houses close and got antenna related messages in about 300-400 meters. At that  distance I had around 2 bars of signal and didn't want to push it too far as that was not normal.
After I found the topic I tried another flight in an open field away from houses and easily got around 1Km with only 1 bar dropped. It would easily go farther, but I was OK with my result and didn't want to push it too far.  On that flight, I had put my phone & watch on airplane mode.
Anybody with signal issues, should try an open field with no trees close to the pilot's position.
2019-5-20
Aus
Flight distance : 517133 ft
Can I ask a stupid question.  Does it make any difference where you bought the Mavic2P?  For ex, if you buy it in Asia or US, does it by default apply the FCC standard?  Or does the DJIGo app auto detect which region you are currently at, and switch to local standard?
2019-5-30
*DM*
Flight distance : 507087 ft
NLD has now released their support for the M2, including switching power modes.
Needless to say you should still strictly adhere to your local laws, many of which preclude flying outside line of sight, which is not far with such a small SUA.
2019-5-30
JMR Grieve
Flight distance : 95554 ft
Aus Posted at 5-30 06:43
It’s not a stupid question, it’s a valid one.
It doesn’t matter where in the world you buy the aircraft. The GPS automatically knows the region you are flying in. For example the same aircraft when flying in the USA will use fcc mode, then when in Europe will use CE mode.
2019-10-16
