"lower_version_boardnum" in the ac name in app?
12
9126 70 2017-8-13
rolling56
Flight distance : 138310 ft
DJI Thor Posted at 2017-9-5 03:38
I had forwarded the update to our engineers to look into. Will reply you once I heard from them. Thanks for your feedback.
DJI Thor has there been any resolution to this? Seems not? or does the re-sync work?
Just preparing in case it happens to me.........
2018-2-9
MickeKling
Flight distance : 3144075 ft
BumblerBee Posted at 2017-8-27 09:38
And today I am again "lower_version_boardnum".
Am I the only one to have a problem with the name changing after flights/syncs?
Hi!
I have the same ”problem”. One of my Spark flights are ”marked” as ”lower_version_boardnum"
/Micke
2018-4-4
nismo_spark
Flight distance : 15988 ft
MickeKling Posted at 2018-4-4 02:46
Hi!
Same thing happened to me tonight... any luck??
2018-6-4
nismo_spark
any luck?
2018-6-4
forbsie
I don't think the issue is related to syncing. I don't sync and I still have the lower_version_boardnum record (single flight of 1 metre and 3 minutes on 1 May) along with my Spark and Mavic Air records.
2018-6-4
RPAS
Flight distance : 1641696 ft
Same issue here.
26 flights / 590
1hr11mins
between 11/05/2017  -  29/3/2018
i sync regularly
I hope the solution is made public, not pm to one or two.
2018-7-3
Wind Diesel
Flight distance : 226168 ft
Had the same this morning - had 3 flights - 1 battery flight was perfect - came back and put in the next battery and went up but the drone was behaving odd and had problems getting video feed to my phone even at 30 meters away - went back to restart the app & mavic air - it returned to me but kept drifting away from me when i wanted to hand land it - finally got it turned it off - restartet the app - took of again and it was ok - the next flight was recorded with the normal name of the drone
Screenshot
2018-9-29
Alex B.
Flight distance : 24101106 ft
I have this issue as well. One of my records says lower version boardnum and the flight corresponds to my real drone profile.
Fly safely
Alex
2018-9-29
mfreed420
Flight distance : 2084360 ft
I also have the same issue but on that same flight my drone entered atti mode and disappeared.  According to my flight records, the drone is still at 145.6ft and distance of 106.1ft but I can promise you it is not there considering there are no tall buildings or trees near the area.
2018-12-24
marvfreed
I also have the same issue but on that same flight my drone entered atti mode and disappeared.  According to my flight records, the drone is still at 145.6ft and distance of 106.1ft but I can promise you it is not there considering there are no tall buildings or trees near the area.  Oh and this is on a Spark not Mavic but after a google search this is the only thread I could find with the same issue.
2018-12-24
Lucas775
Flight distance : 50642090 ft
I just ignore mine, but what the heck!
2018-12-24
CanonMax
Flight distance : 8953215 ft
DJI Thor Posted at 2017-9-5 03:36
Had you also tried to sync again? They should come out when you sync again if the records were synced successfully before.
@DJI Thor
but -as you will know- there is a SYNC problem again... Flight Records do sync but at 99% there is the message that sync failed and that you should try again, which does not help.
This happens more often... sometimes it is solved but now, since a few weeks the situation is not OK.
And -I am SURE and CONVINCED- this problem is not on my side of the DJI GO and DJI GO 4... not a problem with my internet connection (download 250mB/s upload 30mB/s...)
I do have the last versions of iOS (maybe DJI GO and DJI GO 4 have problems with iOS v 12.1.1 and v 12.1.2 (iPhones)) and I use the last DJI GO and DJI GO 4 aps...
Mr. Thor... please talk with your engineers and to the people who are responsible for your servers....
ohhh and when DJI would do what they promised (WAYPOINTS v 2.0 for the Mavic 2 Pro) and accessories for the DJI OSMO Pocket it would be even nicer
2018-12-25
marvfreed
2018-12-25
marvfreed
2018-12-25
BumblerBee
Flight distance : 639764 ft
Houston, we have a problem...
Without a GPS signal, the drone won't know where it is, so it will always report its last known position.
Once ATTI kicks in, it is up to you to fly the drone visually.
2018-12-26
marvfreed
BumblerBee Posted at 12-26 03:32
Only problem is that it wasnt anywhere near that position.  Because you could not hear it.  I should've been able to hear it right above my head.
2018-12-26
BumblerBee
marvfreed Posted at 12-26 15:52
Could you start a new thread and upload the log from you controller to PhantomHelp? MAybe we can glean something from them?
2018-12-27
Coachsteve33
Flight distance : 314862 ft
Me too
2019-2-4
Coachsteve33
Me too
2019-2-4
Coachsteve33
Me too
2019-2-4
Coachsteve33
Me too
2019-2-4
Coachsteve33
Me too
2019-2-4
Coachsteve33
I actually have 4 different logs showing.
This one is only 1 flight and it happens to be when my Phanthom 3 flew away
2019-2-4
Aurelian Irimia
Flight distance : 903350 ft
You are not alone.
2019-3-9
MrKrys
Flight distance : 106158 ft
I have the same issue and I have three Logs, my name , my name with the Spark, and Lower Version Boardnum.
I dont have ton of fancy flight data but Its still strange.  Thought I would just have one?  Any thoughts??
2019-3-9
MrKrys
I signed out of the DJI app and then Signed back in and it went away!!!!
2019-3-9
djiuser_ET5bIXJUP4SB
I have the lower version boardnum too. Macic 2 only just a couple of weeks. Logged in and out of app. No change. Seems the is ongoing issue without explanation?
2019-5-24
Geo8
Flight distance : 35830 ft
Mafia16 Posted at 2017-8-31 04:07
I have the same error with multiple devices like the mavic and P4 can you guys help me? all my flight are sync you can check.
Same Issue with ALL my DJI drones.
2019-7-14
fans177658a7
Flight distance : 621335 ft
Seychelles
Noticed it today yes!
2019-11-5
fans3457dae1
Flight distance : 178264 ft
Indonesia
Happen to me , this is strange I hv lost my mavic air last night. drop GPS from 18 to 4 and switching atti by itself, can't control anything just disconnected , Aircraft fly away and i cant do anything .
2019-11-10
fans3457dae1
Indonesia
2019-11-10
12
