Ronin-SC focus motor
2750 7 2019-7-22
Gregor Queck
Flight distance : 1638366 ft
Is the Ronin-SC focus motor working with the Ronin-S?
2019-7-22
Hi, thanks for the inquiry. The Ronin-SC focus motor is designed to be used to Ronin-SC only, therefore, this is not compatible with our Ronin-S. You may refer to the link below to check the compatibility as well. Thank you for understanding.
https://store.dji.com/product/ronin-sc-focus-motor
2019-7-22
Gregor Queck
DJI Tony Posted at 7-22 16:04
What exactly is not working? As the focus wheel is the same....
Is the power cable + this the power supply working?
Thank you for your reply.
2019-7-22
DJI-Paul
Flight distance : 41159547 ft
The power source on the Ronin-S outputs a higher voltage than the Ronin-SC focus motor can handle. This is because the Ronin-S uses a 4-cell battery in the handle and the Ronin-SC uses a 2-cell battery. Therefore when designing the Ronin-SC focus motor, we used a lower voltage requirement.
Short answer is no, the Ronin-SC focus motor will not work with the Ronin-S.
2019-7-23
Gregor Queck
DJI-Paul Posted at 7-23 00:54
Real information, Thank You!
2019-7-24
BerkayGulum
Flight distance : 123862 ft
I want to ask the opposite.. Does Ronin S focus motor fits and works on Ronin SC?
2019-9-13
Gregor Queck
BerkayGulum Posted at 9-13 09:13
Voltage to low; so no, it won't work.
2019-9-13
i.am.ivan.stan
Flight distance : 345302 ft
United Arab Emirates
what kind of voltage are we talking about here
I have ronin S focus motor and it works with 5V output obviously
if i wanted to buy a ronin SC now, what kind of output does it have so it cannot power the ronin s motor, 2.5v or what?
2020-1-16
