A3 - Flight LOGS
3349 4 2019-4-8
TomPhotography
Flight distance : 113881 ft
Hi everyone,
Planning on purchasing a A3 controller (or M600pro), I have the following questions :
- is it easy and how do we extract the flight logs ?
- Possible to register the LOGs at a 50hz rate ?
- do we have access to the gyroscope data ?
- do we need to do everything through the SDK ?
Many thanks !
Thomas
2019-4-8
WiSi-Testpilot
It is easy. With the Assistant 2 open the SD card modus and then copy the files to your computer. In the Assistant 2 folder you find a viewer. With this viewer you can analyze a lot of data, for instance altitude, barometer pressure, acc, gyro and raw gyro, all xyz.
Best regards,
Wilhelm
2019-4-8
TomPhotography
WiSi-Testpilot Posted at 4-8 11:23
Best regards,
Wilhelm
Thanks a lot for your reply!
2019-4-24
Michal Pesek
Flight distance : 1385476 ft
Czechia
Best regards,
Wilhelm
Contain logs coordinates of shutter trig (shutter function on F-port)?
2019-7-24
Edward_Horvath
Flight distance : 560715 ft
Michal Pesek Posted at 2019-7-24 22:41
Been a long time for this post. But hope you see it.  If we had a servo attached to the F Port, could it record the points of on or off of an acc power?
2022-9-29
