Phantom 4 Pro - Gimbal Not Staying Level While Yawing
6745 25 2019-5-1
Force Aerial
Flight distance : 11286 ft
My Phantom 4 Pro is having a gimbal problem. It seems to be a software issue as I have never crashed and it has always been in a hardcase when traveling.
I have done:
Firmware downgrade
Firmware upgrade
IMU Calibration
Gimbal Auto Calibration
Airframe Calibration
If anyone has any suggestions I would really appreciate your help. Please have a look at the video to see whats going on.
2019-5-1
Cetacean
Flight distance : 2528264 ft
Aloha FA,
     There is a setting for the aircraft of "Follow" or "FPV" (First Person View).  FPV will tilt while YAWing.
     Hope this helps!
Aloha and Drone On!
2019-5-1
A J
Flight distance : 14670299 ft
Bring up the grid in the app, go to gimbal settings and manually align the horizon if you are already in follow mode.
2019-5-2
Cetacean
A J Posted at 5-2 01:30
Aloha A J,
     Good suggestion.  Mahalo!
Aloha and Drone On!
2019-5-2
A J
Cetacean Posted at 5-2 02:40
Aloha A J,
2019-5-2
Force Aerial
Cetacean Posted at 5-1 20:50
Aloha FA,
This did not work. Same issue
2019-5-3
Force Aerial
I could do this, but then the gimbal is even more unlevel when yawing in the opposite direction. Think 5 minute video where the horizon needs to be level when turn in multiple different directions. It could do just that the first year and a half of owning it.
If i were only taking pictures, I agree, your solution will work. But recording video while turning, yawing, pitching is a whole different story.
2019-5-3
A J
Force Aerial Posted at 5-3 06:37
Setting it manually should not cause a see-saw effect, just align the horizon for all directions - if that is happening you may have a bigger issue with your gimbal motors.
2019-5-3
Force Aerial
A J Posted at 5-3 06:48
I appreciate your help, but did you watch the whole video. The gimbal starts level and ends level after
about 10 seconds of correct itself. The problem is that it takes to long to make this correction. The horizon needs to be level or close to level while shooting a video where the p4p making multiple turns. Not just up and down or making one turn to the left or right.
2019-5-3
Force Aerial
Also what do you mean by "align the horizon for all directions"?
2019-5-3
A J
Force Aerial Posted at 5-3 07:34
After you align the gimbal manually it should remain level to the horizon irrespective of the yaw movement or pitch angle of the drone.
2019-5-3
Force Aerial
A J Posted at 5-3 07:38
Yes correct, if I manually align the gimbal to the horizon pointed in one direction for a photograph, the image will have a level horizon.
But I am shooting video. During a video, the drone is pointed in multiple directions. While maneuvering the drone from one direction to another, the horizon line becomes tilted. This is not normal. It used to keep a level horizon at all times while shooting a video.
2019-5-3
A J
Force Aerial Posted at 5-3 07:48
That is my point - it should keep a straight horizon all the time once set. If it now doesn't then you may have a fault with the gimbal if you have tried calibrating it etc already and nothing has changed. In that case you may be better off contacting DJI support in your area.
2019-5-3
ATJ
Flight distance : 17736 ft
A J Posted at 5-3 07:57
I would try adjusting the Yaw Movement Limit in the Sensitivity  settings-The Main Controller Settings Advanced Settings.
2019-5-3
Force Aerial
ATJ Posted at 5-3 09:17
Please walk me through the path to get to the Yaw Movement Limit on a P4P+
I cannot find what you are referring to.
2019-5-5
koopmans
Flight distance : 7497 ft
I am having the exact same problem, with my phantom 4 pro v1. Whenever I yaw, the horizon tilts in the same way. It takes about 10 -15 seconds to return to normal. Very annoying. The solutions offered in this thread dont work.
2019-8-19
AntDX316
Flight distance : 3394731 ft
Turn the bottom left map to Atti mode and see the copter tilt.  I would max the gain on all the settings then make another video to see if it fixed it.  I've increased the gain to 125 from 100% before but it seemed to overload the computer.  My drone works great for mapping so I don't really care.  I have to run it in regular mode because HD in Photo can sometimes crash the computer and I lose the feed and connection.  I have made all my money back from mapping and still make more so it's free.
Also, try lowering the gain to the lowest to see what happens.
2019-8-19
Grant Essex
I am a late comer to this thread, but i have the exact problem as Aerial Force does with my P4P.  I agree with koopmans that none of the solutions in this thread work, and that because this is not a common issue it would seem that only those who fall victim to it understand what it is like to deal with it.  At this point i think that there is not a software problem, but a hardware problem with the gimbal, and even AJ mentioned this as a possibility.  Probably a DJI service center would be the only alternative left.
2021-5-25
Stratcat
Flight distance : 4283012 ft
Grant Essex Posted at 5-25 17:37
It's likely the sensors on the yaw motor have been damaged. Mine did this very thing until I changed the yaw motor and ribbon cable.
2021-6-29
Grant Essex
Stratcat Posted at 6-29 08:10
Thanks for that interesting suggestion.  I just replaced my gimbal yaw/roll circuit board with a new one i bought (new condition, and compatible with the P4P) on Ebay and it failed instantly.  What i mean is that, it heated up after less than a minute and started burning one of the ribbon cables after a minute, i could smell it.  Also, the new circuit board behaved erratically, worse than the one i tried to replace.
So now what i am wondering is, if the yaw motor sensors are defective, why would two different circuit boards have two different reactions instead of one common reation since they are the same thing?  I don't see how a new circuit board could not be compatible with my gimbal, but since i've never considered the yaw motor sensors, i have only at present to assume that the solution lies with a new yaw motor and ribbon cable since it worked for you.
Frustrated, but glad for any advice.
2021-7-1
djiuser_aA9yhIxFVlH8
Hello, any solution found for this case??? Thank you.
2021-9-12
djiuser_Bz96PkIZMgZX
Force Aerial Posted at 2019-5-5 07:36
Hello, did you find a solution to this problem?
2021-9-20
fans959dc118
Flight distance : 650623 ft
Had the same issue. Not 100% sure on cause, but a replacement for the whole gimbal assembly with a spare drone I have did resolve the issue at least.
2021-9-27
Turkey
fans959dc118 Posted at 9-27 16:24
Whole gimbal assembly?? Where did you find it? Is it hard to replace?
2021-10-4
djiuser_vuU0VbK1XuRz
Having the same issue with a Phantom 4 Pro gimbal as in the video above as of 5/30/2022, although mine is more pronounced. When pointed straight ahead, the gimbal is level. As I yaw it begins to point upwards and in the direction of the turn, so far that at 90° all I can see through the camera is the blades rotating. Has anyone found a solution other than replacing the entire gimbal?
2022-5-29
dejansmaic
Flight distance : 464757 ft
It's December 4, 2022 and recently discovered this problem on my P4P v1 while trying to sell my drone.  Software is not the issue, it is hardware. Cost to replace the gimbal = almost a new Air2S, more than my P4P is worth.  Looks like I'm stuck with this problem unless another buyer wants to inherited it.  Still a pretty functional drone.
2022-12-4
