Android DJI GO version 2.02
12
6136 73 2015-8-17
tester01
john_351@yahoo. Posted at 2015-8-19 06:22
So mine auto updated to 2.02, and it would not run without crashing in first few seconds.  So no dji ...
Hallo, same here:
Test the new Go-App 2.0.0 for Android on Phantom 3 Pro, FW 1.3.20.
After installation I've got problems until the Go App finally ran.
After that I've got no App crash during test ... so far so good!
Problem with the CPU load is not eliminated.
The Go App starts the process "com.google.process.gapps" (same as Pilot-App)
A CPU load between 50-80% ended up to the already known temperature problems ...
on Asus Momo Pad 8: In case of switching to the map I lost live-viewing (Pilot App 1.1.0 was OK)
On Lenovo Life Tab: During the test no abnormalities detected (except the CPU load)
Waited so long for the new Andriod Go-App ... and then missing the big breakthrough!
Test the Go-App 2.0.1 from Android App Store.
Clean and Stop Go App 2.0.0, delete Folder, make a Complete new Installation.
On Asus Momo Pad8: Still lost live view if I'm switching to the Map.
I've had about two App crashes while an 15min flight.
On Lenovo Life Tab - I've had two crashes while starting the App.
I've had three App crashes while a 20min flight.
The Go App 2.0.1 still starts "com.google.process.gapps" and CPU load is between 50-80%
The App has become even more unstable
Test the Go-App 2.0.2 from Android App Store.
On Asus Momo Pad8: Still lost live view if I switch to Map.
On Lenovo Life Tab - I had about 100% crash rate when I start the Go App 2.0.2.
The App is not useable.
I do not want to be rude but this can not be true, ... an App nightmare!!!
My App Summary:
Pilot App 1.0.7 & 1.1.0 - worked for me (some minor bugs and the CPU load/Temperature issue)
Pilot App 1.2.0 - more unstable (some problems with App-Crash, CPU load/Temperature, local Video-Cache,...")
Go-App 2.0.0 - worked for me (some problems and CPU load issue).
Go-App 2.0.1 - unstabel (more App-crashes)
Go-App 2.0.2 - not usable (crash, crash, crash)
Regards
2015-8-19
Nemmo
jorski@netti.fi Posted at 2015-8-19 22:42
Hi. Have you test your Nvidia with DJI GO 2.0.02?
Hi. I've test the Nvidia Shield on the table, not at the air. On the ground successfull without issues per 1 hour. Hope to test at the AIR  this weekend.
2015-8-19
Nemmo
**TESTING** DJI GO 2.0.2(46)
Nvidia Shield! I disable most google apps like GOOGLE PLAY, GOOGLE MUSIC, FOTOES,deinstall GOOGLE CHROME  and so any defaut apps in my device which can be delete. Only Google MAPS I didn't stop and not downgrade Google Services to default
                         l reduce background process to 2
                         I stop in DJI GO Local video Cash & clear the cash
                         I setup CPU to MAX PERFORMANCE
                         I switch the "Plane Mode" in device
l have test on a table without props. During 1 hour l start and stop motors,put some sticks control to aircraft, change the location of the aircraft. close  the craft to reduce GPS ability , start video recording and stop it, switch OFF RC  and start it again.
So I couldn't got message" DJI DO unfortunatly made an Error"or e t.c ( that errors what i've seen during my previous flights) Only two times i've seen Disconected but in a second app start up again. Disconect was after I'll start or stop video recording. Not every time but a few(2times)
So now I must have a real flights. Hope I can fix)). Try! May be it will be usefull to You.
2015-8-21
jorski
Flight distance : 171946 ft
Finland
Nemmo Posted at 2015-8-22 02:20
Nvidia Shield! I disable most google apps like GOOGLE PLAY, GOOGLE MUS ...
I have tested 2.0.02 with Sony Xperia Z3 Compact tablet. I get also one total disconnect issue.
I have stayed in 2.0.01 version with my Nvidia Shield. It is very stable, no crash.
By the way, have you notice Nvidia Shield Recall? https://forums.geforce.com/defau ... dia-shield-tablets/
I also got defective tablet...
2015-8-21
tester01
Lucky Boy Nemmo!
My three Android devices are original config.
When I turn off Google Services, then there comes a point where the App no longer work.
Last working Pilot Version for my Flight Tab (Asus MeMo 8) was 1.1.0 !
Frustrating for me ... upgrade, test, downgrade ... all the time ... again and again.
OK, DJI  ... Firmware_v1.3.20 is really well done ... stable as hell.
But the stability of the Android App is a nightmare ... and I do not wake up!
Actually, I just want to fly safely. That's all ... only beautiful flights.
But how will that work if the App quit unexpectedly ... or not even work.
Regards
2015-8-22
Kyokushin
Flight distance : 296381 ft
Except high cpu usage and video feed stuttering i have not noticed any unstability. I have disabled cache, and when i downgrade google play services everything works well.
DJI should fix this high cpu usage and thats all.
2015-8-22
tester01
Kyokushin Posted at 2015-8-23 02:42
Except high cpu usage and video feed stuttering i have not noticed any unstability. I have disabled  ...
Hello Kyokushin
... not only the high CPU Usage (that annoys me also) is the last big thing.
As I wrote above: - from GO App Version 2.0.0 to v2.0.1 and v2.0.2 the GO App works on two out of three Android devices no longer!
And such a thing should not happen.
Now ... if I buy myself another new Android-Pad ... will this pad also function after the next Go App update?
How can I be sure? ... The release policy has to change very quickly!
Quality is in demand ... beta test is made prior to release .. not with the release (as at the moment)
regards
2015-8-22
Kyokushin
Strange, on my works very well (except this high cpu usage). In fact i removed any bloatware and crap like facebook from my tablet and i am using it only for Phantom.
2015-8-23
capbat
Flight distance : 54905 ft
rayrokni Posted at 2015-8-18 11:04
it can not be DJI fault if it crashes on your device, maybe there is a reason it crashes on your d ...
I don't have this problem, (crash on start up.) With 2.0.2.
Bat
2015-8-23
capbat
iheartrobots200 Posted at 2015-8-18 14:35
It's DJI's fault for pushing an update to non-compatible devices.  The small list of compatible de ...
How can DJI be responsible for users that are using their software on NON COMPATIBLE device?
Bat.
2015-8-23
rayrokni
Flight distance : 8139875 ft
capbat Posted at 2015-8-23 20:30
Bat. ...
Well said, because.
Ford should make cars so I can plug in my coffee maker while I am driving
2015-8-23
tester01
Q: Already read in the forum?
You will find the following statements (Compatible Devices and Go App)
SAMSUNG S6: ... more Vid lag
Samsung NOTE4: ... I am also having the video feed lag/stall issue
IPhone 6: ... the IPhone gets hotter and hotter
Xperia Z3: ... my Sony Xperia Z3 get hot and laggy
Some comments from a German forum (GO App 2.0.2):
Nexus 9: Over time the app is getting slower and slower.
Sony Xperia Z3: At irregular intervals stops App and disconnects from the RC
Sony Xperia Z3: Error message: com.Google.Process.gapps terminated
Samsung S5: After 20 minutes, the app is been frozen
Sony Xperia Z3: GO App shut down during flight / My App also keeps crashing.
Samsung S5:: Clean Master reports: Go App is launched in 5 minutes 6 times again and claims the benefit battery strongly.
All crazy? or are there  still problems?
cheers
2015-8-23
Quadifier
Flight distance : 2664 ft
I flew about 30 minutes today with my Samsung Galaxy Tab 4 7" running 2.0.2 .  It never crashed and worked perfectly.
2015-8-23
Nemmo
tester01 Posted at 2015-8-23 02:09
Lucky Boy Nemmo!
Yesterday I've tested in the field. Two flights about 10 min.  Nvidia Shield+ Go 2.0.2(47) from DJI site.
No dissconect and no crashes. Google Play was off. Background process=2 All apps exept Go stoped
Google services did not downgrade. Plane mode in device I fogot to activate. NO problem this time
Testing once more in a days.
2015-8-23
Nemmo
jorski@netti.fi Posted at 2015-8-22 02:40
I  ...
Yes , thanks I have the deffective device too. Recall program was ativated month before. Nothing happend this day
2015-8-23
b.wierda
well after i record and press stop the app crashes and i cant start the app as it crashes on boot.
when i manualy delete every dji data and reinstall i can start the app again.  well
untill my recording stops and i gotta repeat the process ......
never had this issue with the earlier releases
2015-8-29
d.j1977
Israel
b.wierda@chello Posted at 2015-8-29 15:11
w ...
Same to me...what i did is reset the tablet to factory  setting becuse i read that when you uninstall the app it doesnt delete everthing ftom last versions.turn off the video catch and now it doesnt crash when rec presses
2015-9-1
tester01
tester01 Posted at 2015-8-19 20:56
Hallo, same here:
Update:
Go app 2.0.2 crashes on boot after installation.
Stop Go app, delete Go app, delete DJI folder ... reinstall Go app 2.0.2 from SD card.
Ok, no crash when starting the Go app
Then i went out for testing. After the first battery it started ...
-> com.google.process.gapps crash.
-> then after 1 min "GO-APP stop"  ... (restart Go app)
-> after 2 min "GO-APP stop"  ... (shut down app process and restart Go app)
-> after 1 min "GO-APP stop"  ... finished! ... nothing works anymore!
A complete uninstall (including folder) was necessary.
regards
2015-9-3
SpunOne69
I get the same thing "com.google.process.gapps no longer working"...when I first bought the tablet, it worked fine with GO 2.0.2.  I installed it on the device, not the SD Card...device memory usually runs faster.  After I logged more than 5 or 6 flights it started slowly getting worse and worse.  I tried clearing the Cache/Data from the app, it helped a little, but then went back to running like crap after a couple flights...I'll try a "factory reset" when I get home today and see if that helps...I don't use the tablet for anything but flying my P3P, so if there's nothing on it I don't care
2015-9-3
SpunOne69
Did the factory reset and flew twice now with no problems at all, no video lag, good signal...went out to 8000 ft and video was still fluid and responsive.  I downloaded the apk file and put it on my SD card so I can install it even when I don't have a wi-fi connection.  Seems that with no apps and no updates (I didn't even setup my google account after factory reset) it runs perfect.  I'll fly a few more times and see if the residual effect comes back or not...so far so good
2015-9-3
tester01
SpunOne69 Posted at 2015-9-4 04:41
Did the factory reset and flew twice now with no problems at all, no video lag, good signal...went o ...
Hello SpunOne69,
..." Factory Reset and didn't setup google account"
I use my tab only for the phantom, ... otherwise there is nothing on it.
A good idea. I have not tried yet.
If the Go App 2.1.0 does not work well, ...  I'll try that out.
regards
2015-9-7
SpunOne69
Well...by the fourth or fifth flight, the app was starting to lag again...I'm going to update my firmware and try out the new app/firmware today
2015-9-7
SpunOne69
I noticed the new app re-connects the video alot faster when it loses signal...The screen just blinks for a second or two, then the video comes back...no need to restart the app
2015-9-7
jayhkr
Quadifier Posted at 2015-8-23 22:21
I flew about 30 minutes today with my Samsung Galaxy Tab 4 7" running 2.0.2 .  It never crashed and  ...
Can you tell us what cable you are using?  I'm trying to narrow down what brand, length might best be used for our Android's.
2015-9-7
jayhkr
Do you know what brand/length of cord you're using for you Android?  Maybe that has something to do with your good luck?!!
2015-9-7
abbasimosin731
Pakistan
hey all... i want to know how can i add Android DJI GO version 2.02 to my site http://apkprofessor.com/   ............plz advice me thanks
2016-3-31
seo.breaker12
Pakistan
i really appriciate your blog you can also visit this
thankyou for yours co-operation please also visit our sites
richswaggers
2016-6-22
Rogen
Bangladesh
Downloaded the 3.1.1 apk from here and it looks like we're good to go.  http://www.androidpureapk.com/2017/01/dji-go-apk.html
  And turn off app auto-updates.
2016-12-31
stevecook2017
same  problem is i am having you can go for kingroot for mobile rooting Kingroot apk download
2017-4-17
djiuser_1dXxovt
jorski@netti.fi Posted at 2015-8-19 06:42
Downloaded the 2.01 apk from here and it looks like we're good to go.. all updated apk file formats download free apkmirrorpure.com
2017-12-5
KedDK
Flight distance : 1133038 ft
djiuser_1dXxovt Posted at 2017-12-5 03:39
"jorski@netti.fi Posted at 2015-8-19 06:42"
Possibly the best news he has had for more than two years ?
2017-12-5
Nebuchadnezzar
Flight distance : 3462946 ft
old school post OMG ;)
2017-12-5
Nebuchadnezzar
KedDK Posted at 2017-12-5 04:44
for a moment I thought that I had traveled to the past ... lol
2017-12-5
KedDK
Nebuchadnezzar Posted at 2017-12-5 04:47
Sorry for the OT.
Guess this ridiculous range for point system is cause of many of those strange postings, a new user can't even ask a Q or report an issue without just popping in to the first, best or oldest thread!
2017-12-5
12
