SD Card Recovery
6638 17 2019-2-3
Lapadus
Flight distance : 473940 ft
Does anyone know if there is a way to retrieve deleted video on the osmo pocket?
2019-2-3
DJI Natalia
Hi, thanks for reaching out. Just to clarify, may we know if you manage to connect your Osmo Pocket to your mobile device? If yes, please try to check the files on cache folder. Should you have further question, please let us know. Thank you
2019-2-4
BeterBan
Austria
There are a lot of (free) programs in Internet to restore data/videos from SD cards, sticks, HDs ...
2019-2-4
Ray-CubeAce
The recovery programs will recover files if you haven't recorded anything after you formatted or deleted the card.
2019-2-4
Lapadus
Thanks for the info
2019-2-7
AliceSmith
As far as I know,there are a lot of SD card data recover software,such as Mobikin.It will scan the trash bin and help you get back the deleted video.
2019-5-4
Amimi
Hi, I think you can apply a third-party tool, but many of them are not free of charge. I have used one named the Bitwar Data Recovery, it's free to use and support recovering data on SD card, you can have a try.
2019-9-2
djiuser_SGtX4I7iJci7
If you’re using Sandisk cards they often come with access to something called RescuePRO Deluxe, usually there’s a sticker in the packaging with a code.  Loads of options out there to recover ‘lost’ data.
2019-9-2
Amimi Posted at 9-2 19:19
Hi, we do appreciate adding information with regard to this scenario. Thank you for continued support.
2019-9-3
mscotgrove
I have bee  n adding support for many DJI cameras go my GPR software www.goprorecovery.co.uk .  It may be worth a try, and if not, a sample would help me.
2019-9-24
JasonWilli
Hi, I suggest the best way you can try SD card recovery software demo or free version and see the preview of lost video files. There are number of data recovery software available in the market like Stellar Video Repair, Digital Video Repair, File Video Repair,Divx Video Repair or etc....
2019-10-23
LCTMichael
Agree with some of the other posters. If it's a SanDisk card....an Extreme for instance, it comes with a coupon for a free one year of RescuePRO.
2019-11-18
djiuser_xNzaAd9sVjfo
Hey…I think you should try the command prompt option for performing SD card recovery effectively. Therefore, just follow these steps to do so:
•        Firstly, you’ve to plug your SD card to the system and then go to Start menu
•        After that, type the ‘cmd’ in a search bar and hit the Enter key
•        Next, right-click the ‘cmd.exe’ and then there you will get the command windows that allow you to recover data that are infected with a virus.
•        Lastly, type in ‘attrib -h -r -s /s /d drive letter:\*.*’, as for example, ‘attrib -h -r -s /s /d G:\*.*’.
I hope after following the above steps, you will be able to undelete your SD card files. All the very best to you…
2020-4-1
For more info: http://www.rescuedigitalmedia.com/sd-card-recovery-4
2020-4-1
LauraYuan
If you have an SD memory card for your Osmo Pocket, you can plug out the card and insert it in a computer. Then find a data recovery tool to retrieve deleted videos . According my experience,  iBoysoft Data Recovery, Recuva, and EaseUS are great. But please note that recovery is never guaranteed. If you continue to use the SD card after accidental deletion, the deleted videos would be overwritten, which make data recovery impossible.
If you mean from your phone, you may be in luck with the cached folder.
2020-7-21
Alla19
Ukraine
DJI Natalia Posted at 2019-2-4 05:56
Hello! I had such a problem
Videos disappeared from the memory card after shooting on Dji pocket 2. Previously, I deleted some videos from the card to free up memory. I did it directly in Osmo Pocket. Not through a computer. I only use this card for Osmo. After deleting the video, I started filming. The camera did not show any errors. The videos were recorded, everything was fine. In the evening, when I decided to view the recorded videos, I saw that the gallery contained only those files that I did not delete before shooting. There are none of those that I shot during the day. I've been using the camera for two years and it's never happened before. How I can recover files? And how be sure that this situation will not happened in future again?
3-24 06:46
Flight distance : 2354357 ft
I use EaseUS Data recovery, not free but works great!
3-24 07:28
DJI Natalia
Alla19 Posted at 3-24 06:46
I apologize for any inconvenience caused by your utilization
It appears that your SD card is damaged. The following methods can be attempted to help you recover the data, but I cannot guarantee the complete recovery of all materials. If the materials are particularly precious, it is recommended to opt for professional data recovery by a third party.
1) Repair the damaged SD card using CMD:
   a. Insert the SD card into the computer using a card reader.
   b. Go to the Start menu, type "cmd" in the search bar, and press Enter. You will see "cmd.exe" in the list of programs.
   c. Click "cmd.exe," and you will get a command window that allows you to repair the damaged SD card without formatting.
   d. Enter: chkdsk f: /f
   For example, "chkdsk [space] f:[space]/f" Note: Replace "f:" with the corresponding drive letter of the damaged SD card.
   After completion, check if it returns to normal.
2) Scan and repair the SD card:
   In "My Computer," right-click the damaged SD card drive, open Properties, go to Tools:
   Choose 'Check' - 'Start checking', select both options (Automatically fix file system errors and Scan for and attempt recovery of bad sectors), then click Start.
3) If the above methods do not work, you may consider using third-party data recovery software.
3-25 03:12
