Any lawyers in the group (FAA rules)?
1130 12 2019-12-10
fans8a8c6c0a
Started wading thru the FAADroneZone information, went ahead and registered as a recreational UA flyer, even though not required with the Mini.
All seems reasonably clear, except for taking a test on aeronautical knowledge and safety.  This was specified in several locations as a requirement to fly recreationally, except in the following section (note this info was updated a few weeks ago):
Do I need permission from the FAA to fly a UAS or drone for recreation or as a hobby?              Published 12/21/2018 02:16 PM          |            Updated 11/25/2019 10:11 AM
              There are two ways for recreational or hobby UAS or drone fliers to operate in the National Airspace System in accordance with the law and/or FAA regulations
Option #1. Fly in accordance with the limited statutory exception for recreation. Under this rule, operators must:
    • Register your drone or UAS with the FAA
    • Fly for hobby or recreational purposes only
    • Follow a community-based set of safety guidelines
    • Fly your drone within visual line-of-sight
    • Give way to manned aircraft
    • Obtain an airspace authorization to operate in controlled airspace.
    • Fly a drone or UAS that weigh no more than 55 lbs. unless certified by a community-based organization
Option #2. Fly under the FAA's Small UAS Rule (14 CFR part 107). Under this rule, operators must:
My interpretation is per Option #1 I don't need to pass the aforementioned test.  Any wisdom to be added from the group?  Sorry for the junk formatting, the cut and paste was not clean.
Richard Southworth
2019-12-10
Gimpy
You're correct that there currently is no test you must take to fly recreationally. That's going to change in the near future, but as of today you can fly for fun without taking a test.
2019-12-10
fans8a8c6c0a
Gimpy Posted at 12-10 11:35
Any more details?  From my FAA readings the test requirement came from a Congress bill that was two years old, and the apparent deletion of the test requirement was specified a few weeks ago.  So what specifically is coming down the pike?
Richard Southworth
2019-12-10
Joemar7
American Samoa
I'm not an attorney, but the test is coming:
https://www.suasnews.com/2019/12 ... l-drone-flyer-test/
https://www.faa.gov/news/updates/?newsId=94805
2019-12-10
Hi. Thank you for reaching out to DJI Forum. I hope that our valued DJI co pilots who are familiar with regards to this matter can provide you the best response and information. Thank you for your valued support.
2019-12-10
fans8a8c6c0a
Ok, I think I understand.  The bill I referred to as two years old is actually the new law.  It appears the FAA will draft an additional test, appropriate for the recreational flyer.  The existing test appears to be overkill, as well as expensive.  No timeline, but more FAA info here:
https://www.faa.gov/uas/recreational_fliers/
Richard Southworth
2019-12-10
fans8a8c6c0a
And even more info here, under section 7 of Authorization...:
https://www.federalregister.gov/ ... f-unmanned-aircraft
The key point here is the online requirement for testing.
Richard Southworth
2019-12-10
The Saint
Flight distance : 5902228 ft
i don't think i've made it a secret that i am totally against this test.  for too many reasons to name them all here and for other reasons probably shouldn't post aloud here.
so when the test is announced, we're all grounded until we pass the test?
2019-12-10
JohnK48
Flight distance : 311020 ft
DJI Paladin Posted at 12-10 11:52
I am a FAA certificated private pilot with an instrument rating. This does not grant me any special UAV flying privileges (well, maybe some), but the main thing is that the same rules that govern the use of airspace apply to UAV operators.  Obviously however the legal administrators in government can change the rules from time to time.  It does tend to take them a lot of time.  But the wheels of progress are definitely moving. There is now in place a software system for recreational UAV pilots to seek and gain permission to fly via online apps using third part contractors.  This is the equivalent of a private pilot filing a flight plan (also not mandatory in most cases). The part 107 certification is for "commercial" drone operations and the test for this is very similar to the written test for private pilots.
2019-12-10
The Saint
time to look at this for what it really is and evolve.
sure you are a pilot flying an aircraft but there are some differences that are relevant.  did we forget about 249g?
that's fine; we can take a hard line today or we can wait until tomorrow when high tech companies like google and amazon re-write the rules for us.  my guess is we'll be choosing the latter route; fine by me.
2019-12-10
HedgeTrimmer
The Saint Posted at 12-10 19:42
Think there are few other companies re-writing rules, or at least hoping to influence re-writing of rules for their own gains.  Information about individuals has become valuable.  It pays to collect information and sell it or use it.
2019-12-10
Cetacean
Flight distance : 2528264 ft
fans8a8c6c0a Posted at 12-10 12:12
Aloha Richard,
     According to the FAA rules, the regulations cut-off is at 249 grams as pointed out by the Saint.  That means as you noted, you did not have to register your Mini.  The size of your Mini may also not require you to follow any other rules.  However, it would be less than intelligent to do so.
     That being said, the rules will very likely be changed in the future to include the smaller drones in the next evaluation cycle.  That evaluation cycle may also determine that radio transmissions in any size drone require an identifier as is now under consideration for drones over 249 grams.  So it is a good idea to do as you have started to do and learn the rules and follow them.  It will be good training for later compliance.
     Any irresponsible drone operator will only make it worse for other operators.  Follow the rules and make the skies safer.
Aloha and Drone On!
2019-12-11
R&L Aerial photography
Flight distance : 298100 ft
The Saint Posted at 12-10 18:21
There may be some type of grandfather clause when rules go into affect but I doubt it, if that’s the case then I’ll just always fly in airplane mode, I do anyway with the exception of the mini...
2019-12-11
