Phantom 4 pro V2.0 and HDMI Output Module
22582 45 2018-6-8
RemusK
Flight distance : 1145869 ft
Hello!
I have a HDMI Output module installed in my old Phantom 4. I just bought a 4 pro V2.0.
I wonder if the old HDMI Output module works with the new Phantom.
Thanks,
Remus
2018-6-8
DJI Wanda
Hello. Thank you for inquiring this information to us. We will raise this issue in one of our management so that we can provide accurate information to you. We will keep you updated. Thank you for your understanding.
2018-6-8
DJI Wanda
Hello. Thank you for waiting. We were able to confirm that HDMI Output module is not compatible with Phantom 4 pro v2.0. You can check it here: https://store.dji.com/product/ph ... lete&position=3
2018-6-11
KedDK
Flight distance : 1133038 ft
DJI Wanda Posted at 2018-6-11 01:27
Hello. Thank you for waiting. We were able to confirm that HDMI Output module is not compatible with Phantom 4 pro v2.0. You can check it here: https://store.dji.com/product/phantom-3-hdmi-output-module?from=autocomplete&position=3
Did you get that confirmed from the engineers?
That compatibility list is from before anyone even thought of the P4P v2.0 and DJI is not famous for updating the information provided around their pages.
2018-6-11
DJI Wanda
KedDK Posted at 2018-6-11 02:07
Hello. Yes. This answer came from our engineers.
2018-6-11
RemusK
Any plans to release one compatible with V2.0?
2018-6-11
DJI Wanda
RemusK Posted at 2018-6-11 02:17
I fully understand that this information is very important to you. However, we do not have any information yet if there will be an update or will release a new one for Phantom 4 Pro v2.0. But no worries, we will forward this information to our engineers to confirm if there will be one.
2018-6-11
RSPB
DJI Wanda Posted at 2018-6-11 03:16
So DJI Wanda,  can you just clarify that if I have a Phantom 4 Pro v2 without the HDMI module fitted as standard, I can't fit one retrospectively?
2018-7-4
yarik83
I find it absolutely absurd that DJI would do this to us. Not providing HDMI capability as they did on phantom 4 pro is a direct intent to remove available options for consumer and force them to buy DJI goggles instead.
Many of us have multiple drones and use fatshark goggles (or whatever else) and use HDMI port upgrade on P3 line and P4 line. For P4 v2 not to include an HDMI out is flat out crazy. It should not matter if it is Lightbridge or Occusync. A video out is a video out.
Video out could be found on 1950s televisions, virtually every single piece of electronics have video out capability and DJI drones themselves have provided that capability. And now all of a sudden V2 model does not have it? Come on....
Someone at work crashed work drone and after procurement took its sweet time we finally got a replacement drone. They got us V2.0 Now we have fatsharks at work that we can't do anything with.... that we have been using for years on P3 and P4.
Come on DJI... what is this absurdity....
2018-7-17
johan milani
Flight distance : 7046667 ft
hello its just crazy situation than DJI cannot think about no comptaiility between 2 product and create a new HDMI module !! we need to know at which date the new item is avalaible ..
2018-8-9
djiuser_cdtbKxis1bGl
Hi There, do you have an update to the HDMI module for P4 pro v2? Are you planning on one been released?
2018-11-13
Błażej
Hi! Have you any news about this problem? Or any issue? :-(
2018-12-2
PointGeorge
This is really nuts, no HDMI output module?
2018-12-16
Country
I went on the DJI Store website and ordered one.  It was listed as an accessory for the P4P V2 but when it came in it was the standard part 54 for the P3.  Even the Customer service reps found it odd that it is listed as compatible with Phantom 4 series drones.  It says NOTHING about not being compatible with the V2.  I wish I had visited this forum sooner now I'm stuck with having to pay for return shipping.  Any ideas how to get a HDMI signal out of the system without buying the goggles?  One Tech I chatted with said I could bind another RC with the HDMI module to it in order to get the signal output.  GOOD LUCK
2019-1-9
The reason the old HDMI module does not work is because the newer V2 uses Occusync, a completely different method of transmitting the video signal. It will require a new design board to work with the V2, and will not be a software patch. It might be possible to use a Shield pad to provide a HDMI output.
2019-1-9
Bischofftep
Flight distance : 881230 ft
I imagine that someday we will see an OcuSync receiver that can output HDMI.... but yes, suddenly finding that there was no HDMI out on the "Pro" model was a disappointment and one I hope is corrected soon.
2019-3-19
Cetacean
Flight distance : 2528264 ft
Aloha Remus,
     The CrystalSky has a 1080p HDMI out Port.  The old P4 HDMI module only put out 720p.  Even the 5.5 inch CrystalSky puts out 1080p.
Aloha and Drone On!
2019-3-20
Cetacean
Aloha KedDK,
Aloha and Drone On!
2019-3-20
Cetacean
RSPB Posted at 2018-7-4 03:13
Aloha RSPB,
Aloha and Drone On!
2019-3-20
Cetacean
yarik83 Posted at 2018-7-17 09:29
Aloha yarik,
     The CrystalSky has a 1080p HDMI out Port.  The old P4 HDMI module only put out 720p.  Even the 5.5 inch CrystalSky puts out 1080p.  Unfortunately, FatShark goggles do not use 1080p or have they been improved?  Last time I checked, they were something like 800X600.  Hopefully they will work with the CrystalSky.
Aloha and Drone On!
2019-3-20
Cetacean
johan milani Posted at 2018-8-9 04:47
Aloha johan,
Aloha and Drone On!
2019-3-20
Cetacean
fans241b2efb Posted at 2018-11-6 14:15
I have too Phantom 4 Pro V2.0 in our company. We need hdmi output all the time in our work. Please tell me when that HDMI OUTPUT module comes????? Very sad how DJI done in this case.
Aloha fans241,
Aloha and Drone On!
2019-3-20
Cetacean
djiuser_cdtbKxis1bGl Posted at 2018-11-13 17:22
Aloha djiuser_cdtbK,
Aloha and Drone On!
2019-3-20
Cetacean
Błażej Posted at 2018-12-2 22:52
Aloha Błażej,
Aloha and Drone On!
2019-3-20
Cetacean
PointGeorge Posted at 2018-12-16 09:41
Aloha George,
Aloha and Drone On!
2019-3-20
Cetacean
Country Posted at 1-9 13:53
Aloha Country,
     If you need one, the CrystalSky has a 1080p HDMI out Port.  The old P4 HDMI module only put out 720p.  Even the 5.5 inch CrystalSky puts out 1080p.
Aloha and Drone On!
2019-3-20
Cetacean
Bischofftep Posted at 3-19 07:00
Aloha Bischofftep,
     Some of this was addressed in your other thread.  But, the CrystalSky has a 1080p HDMI out Port.  The old P4 HDMI module only put out 720p.  Even the 5.5 inch CrystalSky puts out 1080p.
Aloha and Drone On!
2019-3-20
Cetacean
Aloha Wanda,
     There are many ways to reach our destinations.  The CrystalSky has a 1080p HDMI out Port.  The old P4 HDMI module only put out 720p.  Even the 5.5 inch CrystalSky puts out 1080p.
     Mahalo for your patience!
Aloha and Drone On!
2019-3-20
Sherif Elmalek
Egypt
How is this I have purchased from about 5 month 30 pieces and I want them now to exit HDMI and there is no how this is this reasonable I want a response from the company and how to exist for previous models and there is no .. I am surprised by this company
2019-4-18
VE7CUP
DJI Wanda Posted at 2018-6-8 06:53
Is there a multiport adapter that could be used ?
2019-12-20
VE7CUP Posted at 12-20 21:38
No. It requires a special board to be provided that can convert the signal as received from the aircraft into a HDMI output.
2019-12-22
rwynant V1
Flight distance : 4842277 ft
Geebax Posted at 2019-12-22 12:59
Gee,
I just read on the DJI site that the V2 + version transmitter has the HDMI OUT
TX Model GL300K
The Standard V2 TX is  GL300L      I am waiting for a call back as to if there are replacement Modules available for the GL300K, and if that module is compatible with the GL300L......crossing my fingers!!
Randy
2020-2-5
rwynant V1 Posted at 2-5 15:45
Gee,
Yes, the Mavic 2 Pro Smart Controller has HDMI out as well, so maybe it will become standard on the newer models from now on.
2020-2-5
fansf48c19e1
Flight distance : 1837411 ft
Gee,
Were you able to use the HDMI module from the P4P V2+ in to the standard RC?
2020-3-17
rwynant V1
fansf48c19e1 Posted at 3-17 17:22
No one seems to be able to answer my question as to if the Plus module can work on the standard RC.
I asked the local dealer, and they said they can't get the part........
Randy
2020-3-18
rwynant V1
Ok guys and gals..... got a work around
https://www.amazon.com/gp/produc ... 0?ie=UTF8&psc=1     HDMI Dongle
I also have the Freeworld 2200 nit 7" Monitor   https://www.amazon.com/gp/produc ... 0?ie=UTF8&psc=1
Readup on this!!   I got 2 high capacity batteries as well and this Powerbank  https://www.amazon.com/gp/produc ... 0?ie=UTF8&psc=1
In direct sunlight, you can see this monitor clearly and sitting on a tripod is absolutely brilliant!!
What you are doing is CASTING your screen to the DONGLE and it HDMI feeds at 1080P to your monitor.....Crystal Sky 7.85" is $1000.......
Randy
2020-3-18
BLACKVICELARD
Flight distance : 117146 ft
Hello Remusk, Did you find a solution to connect your HDMI module on your P4P V2?
2021-2-5
RemusK
BLACKVICELARD Posted at 2-5 03:16
Hello!
No solution.
2021-2-5
BLACKVICELARD
RemusK Posted at 2-5 03:19
Hello!
No solution.
In fact, I've just been confronted with the problem this morning, so I haven't had time yet to search on the net for what he says...! But when you say that there is no solution it's because the HDMI module itself is not compatible (electronically) with the P4P V2?
2021-2-5
djiuser_gmWkInxYCh7c
It's a pity that dji does not put this information in their sales brochure I bought a phantom 4 Pro v2 at a much higher price than the older phantom 4 was available at thinking that I had the best model I also bought a high brightness mobile monitor which is normally used on professional video recording which only has hdmi connectors thinking I was getting the best daylight viewable screen it has a 2200 nits screen has anyone managed to get a hdmi output sorted out yet I don't mind opening the box and doing a little soldering to sort it out I bought one of the modules for the older version if anyone can help I would love to hear from them.
Regards Poppy Ann.
2021-4-5
