Dedicated cellphone for remote controller
1713 15 2020-1-4
bonmot
Flight distance : 382815 ft
Anybody use a dedicated cellphone for the controller?
I thought it would be a good idea to do so.
Because it could cause problem if a phone call comes in during the flight.
My question is: does DJI Go 4 need to connect to the Internet during the fly using cellular network?
2020-1-4
bonmot
Is iPad mini 1st fast enough?
2020-1-4
lannes
Flight distance : 4465 ft
bonmot Posted at 1-4 21:43
No, Ipad Mini 4 is the minimum for DJI Go4
For DJI Fly (Mavic Mini) you can use a Ipad Mini 2
2020-1-4
The Go4 app will only use the Internet to obtain map information, but it is not essential to do that as you can pre-load the map at home before you go out to fly. The app has no other need to connect to the Internet.
2020-1-4
Like many other flyers, I use a wifi only tablet for flying.
There's no need for any cell data to fly.
And if you are concerned about incoming calls, you can always use the appropriately named Airplane Mode on your phone.
2020-1-4
fanse5394b5d
Flight distance : 128471 ft
I recently upgraded my phone. I factory reset the old one(Nexus 5X), removed the SIM and installed a minimum of apps alongside DJI GO 4. It works brilliantly. Better than what I normally use, which is a Nexus 7 (2013). Quicker to connect, less lag and no fractured video link. Only problem is screen size, apparently bigger is better.
2020-1-4
Hello and good day bonmot. Thank for reaching out and for the inquiry. During the actual flight of your drone DJI it is best and it is recommended to put your mobile device to airplane mode to minimize interference from calls and text. Thank you.
2020-1-5
bonmot
lannes Posted at 1-4 21:54
Ok. Thanks. Then is my iPhone 7 good enough to fly my Mavic 2 zoom?
2020-1-5
lannes
bonmot Posted at 1-5 09:55
Yes, it’s on the compatible device list
2020-1-5
Lucas775
Flight distance : 50642090 ft
Dedicated ipad is my choice of monitor with a mavmount.
2020-1-5
bonmot
Lucas775 Posted at 1-5 16:46
Google search says a lot of people just use the stock clamp for the iPad mini 2/4. They work just fine.
Do you like this configuration?
2020-1-5
Lucas775
bonmot Posted at 1-5 18:17
I use an ipad bigger than the ipad mini even though I used a mini before and it was hard to hold on to the RC.
2020-1-5
bonmot
Lucas775 Posted at 1-5 18:35
Thanks. First hand info is always useful. Probably I will keep using my iPhone 7 (New battery installed today) for a while before spending another $400 on a Mini 4 and a bracket.
2020-1-6
bonmot
Just found out the iPad mini I have is iPad Mini 2!
2020-1-10
lannes
bonmot Posted at 1-10 21:39
That's unfortunately not powerful enough to run DJI Go4, but it will run DJI Fly and work with the Mavic Mini
2020-1-10
bonmot
lannes Posted at 1-10 21:41
Selling mini 2 now. I have two of them.
2020-1-11
