New Smart Controller Firmware Released (10/01/2020)
56393 224 2020-1-9
Avronaut
Flight distance : 53996 ft
I connected the Smart Controller to WLAN and started the update. Works fine, no language bugs
2020-1-11
raven swe
Flight distance : 517936 ft
yep just refreshed mine, language bugs are gone
2020-1-11
JuJuMP2_User
Avronaut Posted at 1-11 10:10
Same here.
Waiting for weather to improve, blowing a Hoolie here.
Got a nice silicon protector/visor for it.
2020-1-11
BIGDZ
Flight distance : 10255860 ft
For some reason mine keeps failing to update using Assistant 2 for Mavic. Weird how some have updated with no issues. I have tried multiple times.
2020-1-11
djiuser_9f87BOMKKVV9
SzczechzCzech Posted at 1-11 09:40
All good with update on my smart controller with the controller update only - not via assistant. Also no language bugs in my case. And Fly Immediately is an awesome option.
Did you download new update today I did it yesterday and have a Chinese language on one line the rest is english
2020-1-11
Dronie2
Flight distance : 1336365 ft
Mine refreshed too. No language bugs.
2020-1-11
tyler947
Flight distance : 3878802 ft
Tried to update with DJI Assistant 2 for Mavic. Took about 2 hours to download then it failed. I uploaded the failure log and have tried it again but it is trying to download it all over again - painfully slow.
Will try via the controller over wifi instead..
2020-1-11
tyler947
tyler947 Posted at 1-11 12:06
Well, it downloaded over Wifi and now is stuck at installing at 1% for about 15 minutes now.
2020-1-11
tyler947
tyler947 Posted at 1-11 12:33
Reinstalled DJI Assistant, after plugging in the SC I did not click on the message regarding slow charging or select a data connection type via the cable and DJI Assistant finally worked and updated it.
2020-1-11
tyler947
KlooGee Posted at 1-10 09:26
DJI,
Which third-party apps did DJI test with and are supported for SkyTalk?
I have been unable to figure out what works with SkyTalk. I only see the existing live broadcast option via Facebook etc.
2020-1-11
KlooGee
Flight distance : 16783757 ft
Yes, they pulled back the original version, fixed at least the language issues I had reported and re-issued it.
The original one had a kernel date of Jan 06 and the new one is Jan 11.
In the System Version, one of the lines there also changed from:  PAD@V00.00.09.80 release-keys
To:  PAD@V00.00.09.84 release-keys
I used DJI Assistant 2 for Mavic to refresh my firmware and it updated to the latest one.  After doing so, the language issues have been fixed.  Still really surprised such obvious issues had slipped through their quality assurance processes.
2020-1-11
bumper
KlooGee Posted at 1-11 14:38
Same here. Used Assistant and chose "Refresh" to go from the "Chinese text" version loaded yesterday, to the English version today. Updated two Smart Controllers, no problems.
2020-1-11
BIGDZ
I was finally able to update to new firmware. This time, I was able to do it via the controller rather than using assistant 2
2020-1-11
Rob W
Flight distance : 96152 ft
I had the beta installed previously. Installation through DJI Asssistant for Mavic went well. Language bugs, though. All 3:rd party apps worked.
In order to rectify the language bugs, I tried to factory reset, but the language bugs are still there (for instance the Quick Fly option).  English language set, English keyboard set and european time zone.
Still no DJI Pilot for Mavic 2 Pro/Zoom! Fix it, DJI!!!!
2020-1-11
akozc
Flight distance : 2019951 ft
Macao
Installation was Ok but very strangely  SC Video and Photo records bottoms does not working smoothly  not only DJI GO Apps but also Litchi as well
More strangely when you press the video  record bottom non English voice command comes out ,  guessing  she says recording or stop recording.
Btw Play Store App  working fine
2020-1-11
AntDX316
Flight distance : 3394731 ft
akozc Posted at 1-11 23:23
How did you install Play Store?  I'm worried about breaking the controller resulting in aircraft connection loss.
2020-1-12
AntDX316
Anyone else having this problem?  I've paired it with the M2Z.  Before it showed unknown before pairing too. I think the .530 to .650 worked perfectly fine but refreshing and doing nothing, the controller turned off by itself around 16%.  It was beeping but I did nothing.  This happened when I was updating it when I first got it to .530.  I didn't know I had to press the screen every now and then for it to stay on.
2020-1-12
akozc
Macao
AntDX316 Posted at 1-12 01:50
Very long process but try this https://www.certifiedaerials.com/info/how-to-install-google-play-store-on-dji-smart-controller
Play Store does not interface with DJIGo 4 or signal connection so feel free to install .it is on my SC  for months and haven't experienced any difficulties.
2020-1-12
AntDX316
I had to downgrade to .530 to try to get the Switch aircraft back but I'm currently stuck at 98% with the DJI loading logo stuck..
fixed by turning it off and back on, going to update with just wifi
Stuck at (1%)........
It won't let me turn off the controller to update through the PC.
update: I got it to turn off
You have to set your screen timeout to 30 minutes.  No idea why this isn't said on Post #1 or setup automatically or at least shown at the firmware update page of DJI Assistant for All the products.
update: Aircraft management still shows unknown
update: Computer doesn't even see the Smart Controller at all.
Update: turning USB debugging worked
update: going back to .400 then back to .650 to see
Can you all check to see if aircraft management works on .650??
Update: going from .400 with factory reset to .650 fixed it.
2020-1-12
raven swe
mine works, mines listed as my name
2020-1-12
Avronaut
AntDX316 Posted at 1-12 02:35
https://www.youtube.com/watch?v=Uqww7oQwPrc
Mine paused at 16% for a few minutes. Then it went on and ended successfully (via WLAN, controller standalone)
2020-1-12
raven swe
every update I've ever done always takes forever at 16%
2020-1-12
Avronaut
To those with update problems: Have you used the smartphone Go 4 on the Smart Controller before?
2020-1-12
Avronaut
raven swe Posted at 1-12 07:52
Forever? So you are still waiting and looking on stuck screen? Unbelievable ;)
2020-1-12
yoengel
Flight distance : 2370988 ft
tyler947 Posted at 1-11 14:00
The website says skytalk works with Facebook and Instagram but I can’t figure out how.
Btw, the latest Instagram keeps crashing on the SC.
2020-1-12
raven swe
no, it takes awhile when it gets to 16% to move on, it just makes you think its stuck when its not
2020-1-12
roamer105
Flight distance : 3156145 ft
knarfboy Posted at 1-11 02:40
DJI apparently withdrew the update for the Smart Controller due to the many errors. it is currently no longer available.
This must have just happened because earlier today I "refreshed" the update making sure it actually reaches 100% completion. It did and it tells me it is ".0650".
2020-1-12
raven swe
they pulled it, fixed the problems, then re-upped it
2020-1-12
roamer105
roamer105 Posted at 1-12 12:59
The really annoying thing about the new version is that the PACKAGE INSTALLER keeps stopping. I can not install ANYTHING anymore.
Anyone with ideas about that?
2020-1-12
AntDX316
Steps to make it work in order
Ensure your PC and USB cable and its connections are stable and not overlocked if possibleEnsure 100% battery just to have it
Enable the Developer Mode setting by pressing one of the version numbers 6 times?
Enable Developer Mode
Enable USB Debugging, touch nothing else
Set display to 30 minute timeout
Launch DJI Assistant 2 for Mavic 2.0.10 with Run in Administrator Mode
Downgrade to .400
Factory reset w/o doing tutorials once at .400 in settings
Upgrade to .650
Refresh .650
Done
If you miss any of the steps you may have problems.  Do not update through the Smart Controllers otherwise, it will get stuck at 1% forever.  I've spent at least 4 hours trying to get it to work with the USB not working once it hit 98%, unknown aircraft under aircraft management, etc.  I've went back to .530, did many other things, and it was still broken.
I just flew the M2Z perfectly with .650.  You can't risk having the controller Maybe work at 90%.  It has to be 100% in the real-world.
2020-1-12
KlooGee
Thankfully, I didn't have to do anything like that.  I just used DJI Assistant 2 for Mavic and chose to upgrade to the new version and it just worked.
2020-1-12
KlooGee
raven swe Posted at 1-12 10:00
Yeah, mine hung at 16% just long enough to make me nervous before it moved along.  Lol!
2020-1-12
akozc
Macao
Yes same here  @16% stuck about 10min then smoothly completed the update.
all fine so far and really enjoy the new function of quick start.
My earlier reported problem here  about  poor sound effects on Litchi  also been corrected after downloading the google text to speech plugin.
If you need to use  Play Store you need to re install it as per the post here
Btw,  is not related to this topic but why the SC icon disappered from every SC owners profile?
2020-1-13
raven swe
yeah mine disappeared a while back
2020-1-13
AntDX316
KlooGee Posted at 1-12 20:55
Yeah but I want to be 100% it all went through.
2020-1-13
Dronie2
Mine has also disappeared...
2020-1-13
CanonMax
Flight distance : 8953215 ft
U P D A T E D
... Goodday...
I connected my 100% charged DJI Smart Controller to my Windows PC, turned it on and launched DJI Assistant for Mavic 2 (V 2.0.10) in Administrator Mode... then I turned on my Smart Controller... Controller was immediately recognized but I do not get to see the last version (V. 01.00.0650)...
Actual Firmware at this moment is V 01.00.590
Is this just me? Usually I never have problems updating firm-, hard- or software...
Any help is appreciated...
Take Care,
CanonMax
-----SOLVED----
it seems to be neccesary to REMOVE the MicroSD-card in order for the remote controller to update the firmware....
I'm updating now and will see how things end...
as they say "ALL's WELL that ENDS WELL" - did not have the right weather to testfly, but all seems pretty much OK!
2020-1-13
AntDX316
CanonMax Posted at 1-13 01:30
... Goodday...
Screenshot the .590 screen or the DJI Assistant 2 with the firmware selections.
2020-1-13
Bob Draijer
Flight distance : 915279 ft
After update to 1.00.650 the UI craches on every start up, the logbook function does not work anymore can i downgrade to previeus firmware? I grounded my smart controler!!!
2020-1-13
BobB
Flight distance : 138310 ft
I suppose i will wait for another week or so before i update anything on my SC.
2020-1-13
