DJI LIGHTBRIDGE 2 Release Notes (11/20/2019)
19285 7 2019-11-19
DJI Support
Flight distance : 2408 ft
Overview:
  • Date: 2019.11.20
  • Air System: v1.1.81
  • Ground System: v1.2.52
  • DJI GO App: iOS v3.1.59, Android v3.1.59
  • DJI Lightbridge 2 Assistant: v1.2.4
What’s New?
  • Fixed occasional issue: when the Ground System is disconnected with the Air System, they cannot reconnect to each other automatically.
  • Fixed rare issue: the master and slave Ground System disconnected from each other.
Notes:
  • Restart the Air System and the Ground System after updating the firmware.
  • If the firmware update fails, restart the Air System, Ground System, then try updating again.
2019-11-19
Thanks for the info!
2019-11-20
You are very much welcome and thank you for your valued support.
2019-11-20
Woe
Flight distance : 4129268 ft
Thanks for the info.
2019-11-24
rfAndy
Flight distance : 396365 ft
Is there a specific order/procedure to use to successfully update? Controller first? Air system first? Thanks.
2019-11-24
Adrian1232000
hey,
i have a update problem with my LB2 Ground unit :/
The actual Firmware on the LB Ground unit is 1.2.10 and i cant upgrade to 1.2.52 becuase the Android app says that i already have the latest update?
Maybe someone can help me!!!
THANKS <3
2019-12-29
piazueler
Flight distance : 456260 ft
Hi, I have the same problem.
I can upgrade to version 1.1.81 of the air system, but I can't find version 3.1.59 of the ground station, neither on android nor on ios, with the problem of not being able to link the station with the air system, so I'm forced to degrade the firware.
I wait for your answer.
Thank you.
2020-1-14
thomas7041usmcgmail.com
Can I get a Copy of the Bin file for 1.2.52 for some reason I cant update my remote via app
2020-4-13
