SSD card not recognized (SOLVED)
4956 11 2020-2-12
Matthew Dobrski
Flight distance : 1831050 ft
Well, this is new territory to me. I've acquired injured but alive Inspire 2 with CDNG and ProRes licences, purchased new 240GB SSD card and Thunderbolt reader. I was told that video recording on both SD and SSD cards is happening without issue. The system is recognizing standard micro SD card and recording on it, but don't see SSD card. The reader is apparently accepted by MacBook Pro, but when open to explore the content or whatever is plugged in (virgin SSD card in this case), it shows nothing ...
Like I said, I was able to survive without these advanced video formats of Inspire 2 until now, but why not to try since I've access to such options now.
What may be the issue(s), Brothers?
EDIT: It turned out that the SSD interface cable was un-plugged inside Cinecore module.
2020-2-12
Hi, thank you for reaching out and we're sorry for the inconvenience caused. Can you please try to format your SSD to see if the problem persists. Also, please make sure that the aircraft is running the latest firmware before formatting. In addition, if you have a different SSD on your end can you please try to use it for us to only isolate the issue. Please keep us posted. Thank you!
2020-2-13
Matthew Dobrski
DJI Gamora Posted at 2-13 09:43
Gamora, please examine second screenshot again ... Can you see greyed Format SSD button (in red circle)? What that means?
2020-2-13
Matthew Dobrski Posted at 2-13 11:49
Did you try to format it using your PC?
2020-2-13
Matthew Dobrski
DJI Gamora Posted at 2-13 13:00
My Mac is accepting the reader, but see nothing when this new card is plugged in ...
2020-2-13
Matthew Dobrski Posted at 2-13 14:30
Can you please clarify if the DJI GO 4 app is now recognizing the SSD?
2020-2-15
Matthew Dobrski
DJI Gamora Posted at 2-15 15:04
Yes, now DJI Go 4 app is recognizing the SSD, but the license is gone. Please refer to this thread:
https://forum.dji.com/forum.php? ... D560%26typeid%3D560
2020-2-16
Matthew Dobrski Posted at 2-16 13:24
https://forum.dji.com/forum.php?mod=viewthread&tid=209073&extra=page%3D1%26filter%3Dtypeid%26typeid%3D560%26typeid%3D560
Already sent you a PM with regards to this issue, Matthew kindly please check your inbox. Thank you!
2020-2-18
Tsebu
Mongolia
can you tell me where is "SSD interface cable" located in the front or back side of the Body? Much thanks i have same problem as you.
2021-2-8
Matthew Dobrski
Tsebu Posted at 2-8 19:48
That is not necessarily the culprit, but you may check this connector anyway. You may try to format SSD card via computer using specialized software. Somebody did that, but I don't remember what is the software name.
2021-2-8
Tsebu
Mongolia
Much thanks, if you remember what is the software name please let me know. Mine sometimes SSD is enabled, and start recording few times then disappeared.
2021-2-9
Matthew Dobrski
Tsebu Posted at 2-9 07:32
1. Are you using one only SSD card or multiple?
2. The issue is permanent or intermittent?
3. SSD card may be broken as well.
2021-2-9
