OTG cable dosent work?
2556 12 2020-2-26
ManOfSand
Flight distance : 1736883 ft
Remember seeing an update a while ago saying that OTG cables were now compatiable with spark controller, I was pretty excited. However, when I finally tried to connect my phone to the controller, it wouldnt work. I looked at my phone notifications, and it wasnt connected and transfering data to the controller, it was attempting to charge the controller? It said that a "High power drain device is conncected", and it wouldnt show up on my screen that the drone was ready to fly. Is there any way to fix this? Ive had this problem before where the android os decides that it has to charge evrything that it is connected to.
2020-2-26
Hi, thank you for reaching out and we're sorry for the inconvenience. Can you please try to use a different USB communication cable to see if the problem persists? The cable must be a data cable not a charging cable for us to make sure that it will transmit data. Please keep us posted. Thank you for your understanding and support!
2020-2-26
Wolferl
Flight distance : 23793 ft
Austria
Hi there,
You may have connected the cable the wrong way round. The end marked "HOST" goes into the remote controller, the other end goes into your phone.
Cheers,
Wolferl
2020-2-27
Tentoes
Flight distance : 6018255 ft
When the controller connects to the Spark, your phone should think it is being charged. Mine always reminds me that if I connect it to its own charger it would charge faster. Very helpful. If your phone does not charge from the remote, try swapping ends of the cable.
2020-2-29
ManOfSand
DJI Gamora Posted at 2-26 13:09
I see, this whole time i was using a charging cable rather than a data cable, which i never knew was a variant of a cable. I always thought that a charger cable was universal, thank you for your help!
2020-3-3
ManOfSand Posted at 3-3 12:37
You're welcome and we're glad that you already isolate the issue you had before. Happy flying always!
2020-3-3
Lucas775
Flight distance : 50642090 ft
Have you tried a different cable, sometimes that could be your problem.
2020-3-14
S-e-ven
Flight distance : 5922034 ft
If it was the charger cable, that did come with the phone, that will not get you anywhere.
even if it IS most likely also a data cable.
You need an USB-OTG cable.
Or an OTG-adapter, to plug in an usb cable
And that one NEEDS to be plugged into the RC with the side, that is charging the phone!
(If micro on micro)
So best thing to do, visit the Bay or the south american river, and look out for USB otg cable for DJI Spark, Mavic.
And I suggest you get 90 degree versions!
2020-3-15
bjr981s
Flight distance : 139698 ft
S-e-ven Posted at 3-15 07:30
Phone charging is only an issue with android.
It doesn't happen on iOS devices.
2020-3-21
darkfull1
Flight distance : 13114 ft
bjr981s Posted at 3-21 06:05
Apple is finnaly supporting OTG?? wasn't for a long time...
2020-4-4
NRRTRAINS 85
make sure it's not just a charging cable , it has to be a data cable .
2020-4-6
bjr981s
darkfull1 Posted at 4-4 08:46
Apple has always supported the OTG. I used it from day 1. It was DJI that advertised they were not supporting OTG.
2020-4-28
djiuser_cADt6brDFHg5
Vietnam
Rankie OTG cable works with a variety of devices and operating systems. It makes Android and Windows-powered gadgets hosts for connecting keyboards, hard drives, gaming consoles, card readers, and more.
2021-10-29
