Charging the iPad with it connected to the remote?
7018 15 2017-6-30
fans81504005
Flight distance : 90833 ft
Has any one found a way to charge the ipad or iphone while its still connected to the remote.
Phantom 4 Pro
RK
2017-6-30
BrianKushner
Flight distance : 44281716 ft
When connected to the remote the remote charges the Ipad..
2017-6-30
BrianKushner Posted at 2017-6-30 20:27
Yes, it does, but at such a slow rate it is practically useless.
2017-6-30
Rodger8
Flight distance : 20145135 ft
You are better off bringing it to a full charge with it's own charger
2017-7-1
fans81504005
I have tried and iPad Air an iPad Pro 9.7 and an iPhone
2017-7-1
fans81504005
I have tried and iPad Air an iPad Pro 9.7 and an iPhone 6s with different cables and have had no luck.
When you first plug in the iPad or the iPhone to the remote and you look at the top right-hand corner at the charge indicator it seems like it's going to charge but then it disappears,it stops charging
To be able to charge The iPad or the iPhone with an external USB battery  and still be plugged into the remote  would be wonderful
Trust me I've tried every combination of different cables and adapters to try to get this to work still nothing
How are you guys getting this to  work even if it only charges a small amount
What versions of iPhones or iPads are you guys using and are you sure you're getting a charge indicator in the right-hand corner  top corner  when it's plugged into the Remote
Thanks  for any info
2017-7-1
fans81504005
Just checking again if anyone has gotten this to work
2017-7-2
fans81504005 Posted at 2017-7-2 14:45
No, they won't, the RC unit does not supply sufficient voltage to charge an iP{ad or iPhone properly.
2017-7-2
Joelr
Flight distance : 579167 ft
You could try something like this and use an external battery to the other port.
http://www.belkin.com/us/p/P-F8J198/
2017-7-2
Joelr
Joelr Posted at 2017-7-2 18:20
I see that link is for an audio adapter, we need to find something that will allow data.
2017-7-2
fans81504005
Some one needs to build a device to get this to work
2017-7-4
fans508689dd
My ipad is charging the controller....
2020-3-3
fans508689dd Posted at 3-3 13:30
You can turn that off in the iOS version of the app.
2020-3-3
Jordan1978
Where in the iOS? I've got 2 P4Ps right here in front of me, both with iPad Mini 2's, all same firmwares and one is charging the iPad Mini and the other is not. Swapping cables, which are the same, does not change the outcome.
2020-5-2
Vlas
Flight distance : 1398100 ft
Wish it would work with the Mini.
2020-5-2
djiuser_pJRLqyi22mXS
Flight distance : 118406 ft
Chile
Rodger8 Posted at 2017-7-1 02:22
You missed the point.
I once did an 8 hour continuous flying with my P4Pv2 with 5 batteries and a 3-parallel-battery-charger while mapping a 900 hectare farm with 6000+ images.
I had to reduce iPad brightness to barely distinguishable levels and charge it while moving to between takeoff locations.
The problem is rapid chargers use signaling on data pair to negotiate charging speed.
2022-6-25
