dronecoyote
DJI Natalia, I've been gone over weekend - here's the only file under LOG under the MISC file.
File Name P3X_FW_LOG_AB.txt
Last Modified: 1/1/2014 (as you can see, I have RARELY updated firmware because it simply never works.
Contents:
[00016817]========== remo-con disconnect. boot(15) ============
[00016953]Firmware [C:\DM368Fw.bin] detected, card sn [0xb0ce39a5].
[00016987][08 00] Firmware upgrade start...
[00521213][08 00] Firmware upgrade finished successfully.
[00521250]Done.
[00012929]========== remo-con disconnect. boot(15) ============
[00012966]Packet [C:\P3X_FW_V01.10.0090.bin] detected, card sn [0x73100789].
[00013010]Packet upgrade start...
[00013055]Packet checking...
[00013095]Packet vlink 01.10.0090 <-> 01.10.0090.
[00013164]Done.
[00013202]Version checking[1]...
[00013283][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013363][03 06][00] v2.3.0.13 -> v2.4.20.28 need upgrade.
[00013405][04 00][00] v1.41.0.0 -> v1.48.0.0 need upgrade.
[00013522][11 00][00] v1.8.0.0 -> v1.8.0.0
[00013622][11 01][00] v1.8.0.0 -> v2.0.0.33 need upgrade.
[00013707][12 00][00] v1.10.0.0 -> v1.11.0.0 need upgrade.
[00013803][12 01][00] v1.10.0.0 -> v1.11.0.0 need upgrade.
[00013897][12 02][00] v1.10.0.0 -> v1.11.0.0 need upgrade.
[00013974][12 03][00] v1.10.0.0 -> v1.11.0.0 need upgrade.
[00014158][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014235][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014353][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014413][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014453][01 00][00] v1.23.3419 -> v1.32.5432 need upgrade
[00014497][01 01][00] v1.23.3419 -> v1.32.5432 need upgrade
[00014546][08 00][00] v0.12.0.4 -> v0.13.0.7 need upgrade.
[00014593][09 00][00] v1.7.0.3 -> v3.0.0.10 need upgrade.
[00014655]Done.
[00016691]Waiting for user confirm...
[00026730]Timeout, start upgrade automatically.
[00026806]Firmware upgrading[1]...
[00039014][01 00] Firmware upgrade start...
[00012154][01 00] Firmware upgrade finished successfully.
[00012195]Done.
[00012235]Packet [C:\P3X_FW_V01.10.0090.bin] resumed, card sn [0x73100789].
[00012282]Packet vlink 01.10.0090 <-> 01.10.0090.
[00012355]Version checking[2]...
[00012431][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012510][03 06][00] v2.3.0.13 -> v2.4.20.28 need upgrade.
[00012676][04 00][00] v1.41.0.0 -> v1.48.0.0 need upgrade.
[00012789][11 00][00] v1.8.0.0 -> v1.8.0.0
[00012910][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00012951][11 01][00] v1.8.0.0 -> v2.0.0.33
[00013038][12 00][00] v1.10.0.0 -> v1.11.0.0 need upgrade.
[00013122][12 01][00] v1.10.0.0 -> v1.11.0.0 need upgrade.
[00013248][12 02][00] v1.10.0.0 -> v1.11.0.0 need upgrade.
[00013339][12 03][00] v1.10.0.0 -> v1.11.0.0 need upgrade.
[00013482][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013578][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013698][17 01][00] v1.0.2.7 -> v1.0.2.7
[00013769][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013818][01 00][05] v1.32.5432 -> v1.32.5432
[00013859][01 01][00] v1.23.3419 -> v1.32.5432 need upgrade
[00013914][08 00][00] v0.12.0.4 -> v0.13.0.7 need upgrade.
[00013990][09 00][00] v1.7.0.3 -> v3.0.0.10 need upgrade.
[00014031]Done.
[00014071]Firmware upgrading[2]...
[00014234][01 01] Firmware upgrade start...
[00044545][01 01] Firmware upgrade finished successfully.
[00045463][08 00] Firmware upgrade start...
[00567484][08 00] Firmware upgrade finished successfully.
[00567549][12 00] Firmware upgrade start...
[00633572][12 00] Firmware upgrade finished successfully.
[00633636][12 01] Firmware upgrade start...
[00692225][12 01] Firmware upgrade finished successfully.
[00692281][12 02] Firmware upgrade start...
[00766663][12 02] Firmware upgrade finished successfully.
[00766718][12 03] Firmware upgrade start...
[00828405][12 03] Firmware upgrade finished successfully.
[00828683][03 06] Firmware upgrade start...
[01227832][03 06] Firmware upgrade finished successfully.
[01227904][09 00] Firmware upgrade start...
[01279960][09 00] Firmware upgrade finished successfully.
[01280031][04 00] Firmware upgrade start...
[01338490][04 00] Firmware upgrade finished successfully.
[01338530]Done.
[01338574]Version checking[3]...
[01338663][03 05][00] v34.2.0.9 -> v34.2.0.9
[01338744][03 06][05] v2.4.20.28 -> v2.4.20.28
[01338909][04 00][05] v1.48.0.0 -> v1.48.0.0
[01339043][11 00][00] v1.8.0.0 -> v1.8.0.0
[01339160][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[01339206][11 01][00] v1.8.0.0 -> v2.0.0.33
[01339286][12 00][05] v1.11.0.0 -> v1.11.0.0
[01339387][12 01][05] v1.11.0.0 -> v1.11.0.0
[01339486][12 02][05] v1.11.0.0 -> v1.11.0.0
[01339591][12 03][05] v1.11.0.0 -> v1.11.0.0
[01339740][15 00][00] v1.1.2.0 -> v1.1.2.0
[01339835][17 00][00] v1.1.1.7 -> v1.1.1.7
[01339974][17 01][00] v1.0.2.7 -> v1.0.2.7
[01340041][19 00][00] v1.0.8.96 -> v1.0.8.96
[01340085][01 00][05] v1.32.5432 -> v1.32.5432
[01340131][01 01][05] v1.32.5432 -> v1.32.5432
[01340203][08 00][05] v0.13.0.7 -> v0.13.0.7
[01340262][09 00][05] v3.0.0.10 -> v3.0.0.10
[01340312]Packet upgrade finish successfully.
[00012521]========== 2016.12.19 18:05:43. boot(15) ============
[00012564]Packet [C:\P3X_FW_V01.10.0090.bin] detected, card sn [0x73100789].
[00012610]Packet upgrade start...
[00012662]Packet checking...
[00012704]Packet vlink 01.10.0090 <-> 01.10.0090.
[00012747]Record vlink 01.10.0090 <-> 01.10.0090 (flow = 0).
[00012796]Done.
[00012841]Version checking[1]...
[00012939][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013022][03 06][00] v2.4.20.28 -> v2.4.20.28
[00013071][04 00][00] v1.48.0.0 -> v1.48.0.0
[00013223][11 00][00] v1.8.0.0 -> v1.8.0.0
[00013358][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00013401][11 01][00] v1.8.0.0 -> v2.0.0.33
[00013518][12 00][00] v1.11.0.0 -> v1.11.0.0
[00013627][12 01][00] v1.11.0.0 -> v1.11.0.0
[00013728][12 02][00] v1.11.0.0 -> v1.11.0.0
[00013827][12 03][00] v1.11.0.0 -> v1.11.0.0
[00013975][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014093][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014228][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014292][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014336][01 00][00] v1.32.5432 -> v1.32.5432
[00014380][01 01][00] v1.32.5432 -> v1.32.5432
[00014445][08 00][00] v0.13.0.7 -> v0.13.0.7
[00014612][09 00][00] v3.0.0.10 -> v3.0.0.10
[00014661]Packet upgrade cancelled at version checking.
[00013089]========== 2018.01.12 18:42:51. boot(15) ============
[00013127]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0x70ce2db4].
[00013169]Packet upgrade start...
[00013212]Packet checking...
[00013261]Packet vlink 01.08.0080 <-> 01.07.0060.
[00013301]Record vlink 01.10.0090 <-> 01.10.0090 (flow = 6).
[00013341]Packet upgrade failed at packet checking.
[00013068]========== 2018.01.14 09:31:34. boot(15) ============
[00013107]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0x70ce2db4].
[00013151]Packet upgrade start...
[00013193]Packet checking...
[00013239]Packet vlink 01.08.0080 <-> 01.07.0060.
[00013279]Record vlink 01.10.0090 <-> 01.10.0090 (flow = 6).
[00013319]Packet upgrade failed at packet checking.
[00012485]========== 2018.01.14 16:14:21. boot(15) ============
[00012523]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0x70ce2db4].
[00012564]Packet upgrade start...
[00012606]Packet checking...
[00012656]Packet vlink 01.08.0080 <-> 01.07.0060.
[00012696]Record vlink 01.10.0090 <-> 01.10.0090 (flow = 6).
[00012733]Packet upgrade failed at packet checking.
[00012964]========== 2018.02.04 14:46:21. boot(15) ============
[00013002]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0x70ce2db4].
[00013041]Packet upgrade start...
[00013085]Packet checking...
[00013125]Packet vlink 01.08.0080 <-> 01.07.0060.
[00013168]Record vlink 01.10.0090 <-> 01.10.0090 (flow = 6).
[00013208]Packet upgrade failed at packet checking.
[00013099]========== 2018.07.04 14:16:24. boot(15) ============
[00013141]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0x70ce2db4].
[00013183]Packet upgrade start...
[00013232]Packet checking...
[00013273]Packet vlink 01.08.0080 <-> 01.07.0060.
[00013314]Record vlink 01.10.0090 <-> 01.10.0090 (flow = 6).
[00013355]Packet upgrade failed at packet checking.
[00012518]========== 2018.07.04 14:30:39. boot(15) ============
[00012563]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0x70ce2db4].
[00012606]Packet upgrade start...
[00012660]Packet checking...
[00012705]Packet vlink 01.08.0080 <-> 01.07.0060.
[00012750]Record vlink 01.10.0090 <-> 01.10.0090 (flow = 6).
[00012798]Packet upgrade failed at packet checking.
[00012499]========== remo-con disconnect. boot(15) ============
[00012541]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0x70ce2db4].
[00012581]Packet upgrade start...
[00012633]Packet checking...
[00012672]Packet vlink 01.08.0080 <-> 01.07.0060.
[00012713]Record vlink 01.10.0090 <-> 01.10.0090 (flow = 6).
[00012754]Packet upgrade failed at packet checking.
[00012510]========== 2018.12.27 11:12:02. boot(15) ============
[00012554]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0x70ce2db4].
[00012595]Packet upgrade start...
[00012652]Packet checking...
[00012695]Packet vlink 01.08.0080 <-> 01.07.0060.
[00012741]Record vlink 01.10.0090 <-> 01.10.0090 (flow = 6).
[00012783]Packet upgrade failed at packet checking.
[00013572]========== 2020.01.12 22:01:15. boot(15) ============
[00013618]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0x70ce2db4].
[00013662]Packet upgrade start...
[00013718]Packet checking...
[00013766]Packet vlink 01.08.0080 <-> 01.07.0060.
[00013814]Record vlink 01.10.0090 <-> 01.10.0090 (flow = 6).
[00013856]Packet upgrade failed at packet checking.
[00013566]========== 2020.04.15 13:39:59. boot(15) ============
[00013611]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0x70ce2db4].
[00013655]Packet upgrade start...
[00013713]Packet checking...
[00013760]Packet vlink 01.08.0080 <-> 01.07.0060.
[00013806]Record vlink 01.10.0090 <-> 01.10.0090 (flow = 6).
[00013849]Packet upgrade failed at packet checking.
[00013072]========== 2020.04.15 13:51:34. boot(15) ============
[00013117]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0x70ce2db4].
[00013286]Packet upgrade start...
[00013341]Packet checking...
[00013391]Packet vlink 01.08.0080 <-> 01.07.0060.
[00013440]Record vlink 01.10.0090 <-> 01.10.0090 (flow = 6).
[00013485]Packet upgrade failed at packet checking.
[00013560]========== 2020.04.15 14:03:23. boot(15) ============
[00013605]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0x70ce2db4].
[00013702]Packet checking...
[00013804]Record vlink 01.10.0090 <-> 01.10.0090 (flow = 6).
[00013854]Packet upgrade failed at packet checking.
[00013008]========== remo-con disconnect. boot(15) ============
[00013056]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0x70ce2db4].
[00013096]Packet upgrade start...
[00013147]Packet checking...
[00013192]Packet vlink 01.08.0080 <-> 01.07.0060.
[00013240]Record vlink 01.10.0090 <-> 01.10.0090 (flow = 6).
[00013285]Packet upgrade failed at packet checking.
[00012518]========== remo-con disconnect. boot(15) ============
[00012560]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0x70ce2db4].
[00012604]Packet upgrade start...
[00012659]Packet checking...
[00012702]Packet vlink 01.08.0080 <-> 01.07.0060.
[00012748]Record vlink 01.10.0090 <-> 01.10.0090 (flow = 6).
[00012795]Packet upgrade failed at packet checking.
[00051619]========== remo-con disconnect. boot(15) ============
[00051662]Packet [C:\P3X_FW_V01.11.0030.bin] detected, card sn [0x70ce2db4].
[00051706]Packet upgrade start...
[00051763]Packet checking...
[00051810]Packet vlink 01.11.0030 <-> 01.11.0020.
[00051853]Record vlink 01.10.0090 <-> 01.10.0090 (flow = 0).
[00051898]Done.
[00051951]Version checking[1]...
[00052028][03 06][00] v2.4.20.28 -> v2.4.20.50 need upgrade.
[00052108][03 05][00] v34.2.0.9 -> v34.2.0.9
[00052168][04 00][00] v1.48.0.0 -> v1.48.0.0
[00052288][11 00][00] v1.8.0.0 -> v1.8.0.0
[00052550][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00052601][11 01][00] v1.8.0.0 -> v2.0.0.33
[00052677][12 00][00] v1.11.0.0 -> v1.13.0.0 need upgrade.
[00052783][12 01][00] v1.11.0.0 -> v1.13.0.0 need upgrade.
[00052856][12 02][00] v1.11.0.0 -> v1.13.0.0 need upgrade.
[00052937][12 03][00] v1.11.0.0 -> v1.13.0.0 need upgrade.
[00053071][15 00][00] v1.1.2.0 -> v1.1.2.0
[00053173][17 00][00] v1.1.1.7 -> v1.1.1.7
[00053291][17 01][00] v1.0.2.7 -> v1.0.2.7
[00053376][19 00][00] v1.0.8.96 -> v1.0.8.96
[00053429][01 00][00] v1.32.5432 -> v1.32.5432
[00053475][01 01][00] v1.32.5432 -> v1.32.5432
[00053548][08 00][00] v0.13.0.7 -> v0.13.0.7
[00053618][09 00][00] v3.0.0.10 -> v4.1.0.0 need upgrade.
[00053663]Done.
[00055708]Waiting for user confirm...
[00065768]Timeout, start upgrade automatically.
[00065863]Firmware upgrading[1]...
[00065926][12 00] Firmware upgrade start...
[00126457][12 00] Firmware upgrade finished successfully.
[00126528][12 01] Firmware upgrade start...
[00184752][12 01] Firmware upgrade finished successfully.
[00184820][12 02] Firmware upgrade start...
[00245988][12 02] Firmware upgrade finished successfully.
[00246051][12 03] Firmware upgrade start...
[00301318][12 03] Firmware upgrade finished successfully.
[00301594][03 06] Firmware upgrade start...
[00697886][03 06] Firmware upgrade finished successfully.
[00697974][09 00] Firmware upgrade start...
[00756215][09 00] Firmware upgrade finished successfully.
[00756262]Done.
[00756310]Version checking[2]...
[00756443][03 06][05] v2.4.20.50 -> v2.4.20.50
[00756523][03 05][00] v34.2.0.9 -> v34.2.0.9
[00756573][04 00][00] v1.48.0.0 -> v1.48.0.0
[00756704][11 00][00] v1.8.0.0 -> v1.8.0.0
[00756823][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00756870][11 01][00] v1.8.0.0 -> v2.0.0.33
[00756958][12 00][05] v1.13.0.0 -> v1.13.0.0
[00757053][12 01][05] v1.13.0.0 -> v1.13.0.0
[00757132][12 02][05] v1.13.0.0 -> v1.13.0.0
[00757344][12 03][05] v1.13.0.0 -> v1.13.0.0
[00757492][15 00][00] v1.1.2.0 -> v1.1.2.0
[00757588][17 00][00] v1.1.1.7 -> v1.1.1.7
[00757712][17 01][00] v1.0.2.7 -> v1.0.2.7
[00757793][19 00][00] v1.0.8.96 -> v1.0.8.96
[00757839][01 00][00] v1.32.5432 -> v1.32.5432
[00757888][01 01][00] v1.32.5432 -> v1.32.5432
[00757959][08 00][00] v0.13.0.7 -> v0.13.0.7
[00758034][09 00][05] v4.1.0.0 -> v4.1.0.0
[00758079]Packet upgrade finish successfully.
[00013577]========== remo-con disconnect. boot(15) ============
[00013632]Packet [C:\P3X_FW_V01.11.0030.bin] detected, card sn [0x70ce2db4].
[00013677]Packet upgrade start...
[00013729]Packet checking...
[00013778]Packet vlink 01.11.0030 <-> 01.11.0020.
[00013829]Record vlink 01.11.0030 <-> 01.11.0020 (flow = 0).
[00013878]Done.
[00013925]Version checking[1]...
[00014010][03 06][00] v2.4.20.50 -> v2.4.20.50
[00014110][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014170][04 00][00] v1.48.0.0 -> v1.48.0.0
[00014290][11 00][00] v1.8.0.0 -> v1.8.0.0
[00014411][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00014466][11 01][00] v1.8.0.0 -> v2.0.0.33
[00014559][12 00][00] v1.13.0.0 -> v1.13.0.0
[00014639][12 01][00] v1.13.0.0 -> v1.13.0.0
[00014738][12 02][00] v1.13.0.0 -> v1.13.0.0
[00014840][12 03][00] v1.13.0.0 -> v1.13.0.0
[00014995][15 00][00] v1.1.2.0 -> v1.1.2.0
[00015098][17 00][00] v1.1.1.7 -> v1.1.1.7
[00015243][17 01][00] v1.0.2.7 -> v1.0.2.7
[00015315][19 00][00] v1.0.8.96 -> v1.0.8.96
[00015363][01 00][00] v1.32.5432 -> v1.32.5432
[00015407][01 01][00] v1.32.5432 -> v1.32.5432
[00015480][08 00][00] v0.13.0.7 -> v0.13.0.7
[00015554][09 00][00] v4.1.0.0 -> v4.1.0.0
[00015600]Packet upgrade cancelled at version checking.
