Battery Low error message but battery ready 100%
1105 8 2020-4-21
nathkerr
Hi there,
I have used my Phantom 4 for around 2 years now. I used it yesterday flew with no problems then charged it up overnight.
I have flown it today and straight after take off i get the error message low battery but the battery reads 100%.
When checking the cells in the app it appears cell # 4 is lower then the restr causing the low battery error?
Is there a way to fix this issue? or am i missing something all together?
TIA
Ps see screen shots atttached.
2020-4-21
JetSam
Flight distance : 3462946 ft
Make sure baterry contacts are ok and clean
2020-4-21
JetSam
2020-4-21
JetSam
nathkerr hope it helps !! Dirty contacts can make the readings incorrect
2020-4-21
Hi nathkerr, please try to fully discharge the battery and charge to full again. If the error persists, you may replace it and dispose of the battery properly.
2020-4-22
bluebubble
Hi there. You can try to
2020-4-22
bluebubble
Hi nathkerr,
Sorry, I accidentally post the unfinished reply.
Did you powered battery in low temperature condition? The warning may appears because battery does not reach the ideal temperature. You can try to warm it first before take off next time. It is recommended to keep the battery temperature around 20 degrees centigrade.
But if the problem still exixt, I also recommend you to replace it. Hope this tip helps.
2020-4-22
JetSam
bluebubble Posted at 4-22 03:18
Hi nathkerr,
It could be but in Australia there are no extremely cold climates I think
2020-4-22
Tnap22
JetSam Posted at 4-22 10:37
We have about 5 ski resorts in Australia and multiple places get below 0 Celsius.
2020-4-23
