120ccpm
Flight distance : 1401115 ft
hallmark007 Posted at 4-27 15:16
Just saying that we have now proved that the cause descents is down to props, which you did with no proof in fact I still should be seeing proof of how bad these props are, I seen one staged photo that’s it, we now have the usual hysteria being spread about how combo case is the cause storing horizontally is the cause heat is the cause, bad batch is the cause, anyone can have bad props in storage that will cause the unknown descent.
So nothing solved and more hysteria created, it’s not about being right or wrong as you think. I have seen descents in pretty light wind in which craft can’t gain any ground and just goes backwards and down, now if 3 sets of props are working it would make sense that those 3 sets would at least make some headway.
So thinking this is only props and somehow you have proven yourself right is a bit presumptuous.
I said repeatedly that uncommanded descents (those where the MM would, out of the blue, start losing altitude and could not be stopped) might be triggered by bad props, but there is more to it, as a prop doesn't go back all of the sudden, in a way that makes the descent unrecoverable.
This particular "Motor Error", though, seems to be 100% about the props... it instructs pilots to replace props (not the motor, not the ESC, not the arm, not the battery, not anything else), and people say that's all it takes to make it go away. User GrahamJohnson10 provided excellent evidence of a motor experiencing high RPMs before, and normal RPMs after the replacement.
Only time will tell if - by introducing this warning in the latest firmware, and forcing pilots to replace props - DJI has effectively prevented the "uncommanded descents". I'd say there is a good chance, but of course it's pure speculation. Seems quite logical, though.
Instead of going down your usual road of judging my intentions, point out exactly what you think it's incorrect in my reasoning, and what you believe to be the correct interpretation for what we're seeing. |
