Strange RTH Behaviour
1710 19 2020-5-16
Eralp SAYGIN
Flight distance : 668734 ft
Turkey
Today while I was flying my Mavic 2 Pro, RC signal went due to strong interference. When the RTH procedure started, M2P changed it's heading to 3 different random way with a little delay. After that finally I got the RC signal and I have cancelled the RTH to return home myself. Do anyone have opinion about this behaviour ? May the strong interference confused the compass ?
If you have knowledge or experience please can you give information about this ?
Thank you,
Have nice flights everyone
2020-5-16
When it lost signal it should have hovered for a bit and then it would reverse course until it picks up the signal,  could it have been flying the same path as you had been just backwards?
2020-5-17
Eralp SAYGIN
Turkey
DAFlys Posted at 5-17 02:13
I don't know :/ but I have seen that the drone changed it's heading to 3 different ways
2020-5-18
Eralp SAYGIN Posted at 5-18 01:54
You could try analysing the log file here - http://phantomhelp.com/logviewer/
2020-5-19
Eralp SAYGIN
Turkey
DAFlys Posted at 5-19 00:17
Yeah I have tried it but you know M2P's flight logs are encrypted by DJI :\
2020-5-19
Eralp SAYGIN Posted at 5-19 06:20
1.  Your drone was doing exactly what it is programmed to do.
This is described in the RTH section of the manual.
2.  You didn't try very much.
The .txt file is readable if you follow the directions in the link given above.
2020-5-19
You can upload them here and they will be processed,  I did it just the other day.
2020-5-20
Eralp SAYGIN
Turkey
DAFlys Posted at 5-20 00:13
Thank you very much for advice
2020-5-21
Eralp SAYGIN
Turkey
Labroides Posted at 5-19 15:58
I have tried to open log files but in everywhere that I read there was writing "ONLY DJI CAN READ M2P's FLIGHT LOG"
2020-5-21
Eralp SAYGIN Posted at 5-21 02:42
no problem.
2020-5-21
Eralp SAYGIN Posted at 5-21 02:45
This is not true,  use this method to get your flight log and then you can upload it for analysis. - https://www.phantomhelp.com/tips ... logs-from-itunes.29
2020-5-21
You can also upload the log from the DJI cloud to airdate using their app HD Sync, but there PhantomHelp log viewer gives a better breakdown.
2020-5-21
2020-5-21
2020-5-21
It doesn't matter what you've read, the .txt file is easily unencrypted.
People read and analyse the flight data every day.
Post your .txt file and I'll read it for you.
2020-5-21
Eralp SAYGIN
Turkey
DAFlys Posted at 5-21 04:09
This is not true,  use this method to get your flight log and then you can upload it for analysis. - https://www.phantomhelp.com/tips/how-to-retrieve-dji-go-flight-logs-from-itunes.29
Thank you very much
2020-6-10
Eralp SAYGIN
Turkey
Labroides Posted at 5-21 04:12
Thank you very much Labroides
2020-6-10
Eralp SAYGIN
Turkey
also when I try to open it as txt. file it gives error
2020-6-10
Eralp SAYGIN Posted at 6-10 03:25
Don't try to open it.
Just post it here.
Upload to Dropbox or similar and post the link here.
2020-6-10
Eralp SAYGIN
Turkey
Labroides Posted at 6-10 07:18
Just post it here.
I couldn't find it after a long time I'll post it if I haveanything similiar thank you very much
2020-9-8
