Mavic Air 2 won't connect to phone and RC
46738 64 2020-5-11
Aaron Lavinsky
Flight distance : 195338 ft
Folks,
Just received my Mavic Air 2 and I'm having issues connecting the RC to the drone. I've tried manually linking the RC to the drone and vice versa and nothing works. Seems to be a communication problem between the phone and RC.
The onlly way I got the drone and RC to connect was to take the USB C cable, on top of the RC, and turn it 180 degrees, but it's awkward and the spring-loaded phone holder won't close.
Is anyone else having similar issues? Has DJI addressed this anywhere? I've ordered a third party USB-C to lightning cable and I'm hoping it solves the issue, but I'd rather have the drone and RC work like they're supposed to, brand new, out of the box.
Thanks,
Aaron
2020-5-11
Space_Cowboy
I can't get my Mavic Air 2 controller to connect to Android phone or a Android Tablet - All firmware has been updated (controller & drone). This totally sucks!
2020-5-11
GaryDoug
Flight distance : 1264639 ft
If you have to reverse the cable to make it work, obviously something is wrong with the cable or the socket. Are you sure it is plugged into the correct socket?
2020-5-11
Aaron Lavinsky
Yes. It’s plugged into the correct socket.
2020-5-11
mrkooks
Flight distance : 42359 ft
Costa Rica
I had to update the phone firmware to be able to use DJI Fly.. but after that everything went smooth..  Did you test it with another phone? if it works with another phone that means that the problem is the phone you are using.. and not the drone/rc .
2020-5-11
Aaron Lavinsky
mrkooks Posted at 5-11 20:25
When you say the phone firmware, do you mean an iOS update? Or an update of DJI fly? Thanks
2020-5-11
默默地微笑了很久
Flight distance : 507336 ft
Aaron Lavinsky Posted at 5-11 20:40
DJI fly need update to the latest version for support Mavic Air 2
2020-5-11
Hi Aaron, sorry for the troubles with the RC connection, which cable are you using? USB Type-C Connector or Standard Micro-USB Connector?
2020-5-11
Aaron Lavinsky
USB C to lightning connector. The default cable that came pre installed on the top of the RC.
2020-5-12
mrkooks
Costa Rica
The iOS update.. I had to update that because the DJI Fly app just kept closing.. after everything ( phone + drone) had everything updated the drone worked perfectly.
2020-5-12
iSkying
China
mrkooks Posted at 5-12 10:34
Looks like your phone is not compatible with the app. What phone do you use? DJI Fly app is only  compatible with 64-bit Android devices, take a look at the DJI website for the compatibility mobile device list or check this post: https://cultofdrone.com/dji-fly-compatible-device/
2020-5-12
Blellow
Flight distance : 1311056 ft
Flip the connector plugged to the remote.
2020-5-12
mrkooks
Costa Rica
iSkying Posted at 5-12 16:05
My phone is fine.. it is running the app and flying perfectly now.. I just had to update the iOS to the latest and that was it.
2020-5-12
Aaron Lavinsky
Blellow Posted at 5-12 17:25
Yup, that works (as I wrote in my original post).
2020-5-13
OrbFilms
Flight distance : 709 ft
Anyone figured this out? I just got my air and the controller really struggled to connect to the drone. I managed to get it to take off and lost connection pretty quickly after that and it returned home.
The phone says that it is connected to my phone no problem as soon as I plug the cable in. I can now no longer connect the controller to the AIR 2 at all.
2020-5-15
Cayton828
Flight distance : 2358383 ft
I am using the note 10 plus cannot get this damn thing to work for nothing. I've read all the ideas above anybody got anything else because I can't get it to recognize the app
2020-5-15
Cayton828
Hell I wish someone had told me that the DJI fly app is what you have to use instead of the DJI go. I was about ready to send the damn thing back now it's working fine
2020-5-15
OrbFilms
Cayton828 Posted at 5-15 12:44
I am using the fly app... with all the connection issues
2020-5-15
djiuser_kUlUOtTiFQT3
I’m having a bad time getting the dji fly app to connect to my Mavic 2 air drone. I use an iPhone 11 pro running 13.4.1 which is the latest and I have yet to get a connection. I get RC not connected. I select Mavic air 2 and go to camera view after selecting the Mavic air 2 and nada. And the app freezes up. I do run Bitdefender VPN if that makes a difference. I have deleted the app and reinstalled but no go
It’s frustrating and any thoughts would be gratefully accepted
Tim
2020-5-15
fanse3dbfcbe
Flight distance : 486293 ft
Had issues trying to connect my  Lenovo S5 using the supplied usb c cable.
Finally managed to get everything connected and working using a usb c otg cable with my phones charging cable plugged into the otg cable.
Lenovo S5 usb c port specs : 2.0, Type-C 1.0 reversible connector
Why is the usb c cable supplied not working ?
If any member could point me to a shorter length cable that will work i`d be grateful
2020-5-15
NBW877
Flight distance : 656444 ft
I too cannot get the RC to connect to any device (iPhone XR, iPad Air or Galaxy Note 9).  DJI tells me it is a known issue and no option other than return to dealer for replacement or refund or send to DJI.  Sucks.
2020-5-16
djiuser_or5SqBErsnhb
I have an S7 and its fine with the RC and APP.
But my RC connects very badly to the Mavic Air 2. Sometimes i have a good Signal for a few seconds and after another few secs Signal lost.
The Mavic is just 1m away from the RC. Error Code 80002 that said i should check antenna. How should i check them??
Bought it via Amazon and after Hours of trouble they send me now a new one. I have already activated the drone and did DJI care refresh bought over DJI on it.
How do i get this now back?
2020-5-17
Cayton828 Posted at 5-15 12:24
Got the same problem. Emailed DJI and non response. Right now it’s going back next week and I’m not buying another DJI
2020-5-17
Blellow
Try flipping the wire plugged into your screen.  It it is possible.  Otherwise, keep trying.  Mine did not connect the first time until I did the flip with the wire connected to my phone.  Good luck.
2020-5-17
djiuser_M3tUeKlVTQn7
I'm so glad you thought of turning the cable around. that fixed it for me too. Oh god.
2020-5-17
Chokolatrush
Wiggling the cord and making sure it was connected to the remote seems to work (but doesn't fill with confidence when flying).
Now the drone does not want to connect to the remote!!!
I've tried pairing etc but no luck!!
Any ideas
2020-5-20
vectorzero
I had an issue with the RC losing the drone intermittently and then permanently. I'm using an iPhone so I swapped to a known good USB-C to Lightning cable and all works. Looks like the supplied short cable is flaky.
2020-5-21
Phorevar
Bulgaria
Have you tried to reinstall the app? Same situation with another dude and that helped and fixed the issue
2020-5-21
Robbiemoto
Flight distance : 47198 ft
I had the same issue. I use an Iphone xs with latest software. I've had the drone a week and all was ok then a few days ago I started getting issues and an error message RC not connected to de.....
The issue was the supplied lightening cable. If you twisted it on the phone end it would connect
I have since purchased a much better cable from amazon and this works flawlessly. Unfortunately it seems the supplied cables are pretty flimsy and cheap.
2020-5-21
djiuser_Ukhhg5UQxEWL
Robbiemoto Posted at 5-21 22:18
I had the same issue. I use an Ipnone xs with latest software. I've had the drone a week and all was ok then a few days ago I started getting issues and an error message RC not connected to de.....
what cable did you purchase from Amazon to make this work?  I am having the exact same issue where it worked initially.
2020-5-28
Robbiemoto
djiuser_Ukhhg5UQxEWL Posted at 5-28 19:41
I got this one in the 30cm size. https://smile.amazon.co.uk/gp/product/B07XS4XN8S/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
2020-5-29
djiuser_FOv6i6yS5F6f
Chokolatrush Posted at 5-20 03:54
Have you found out the issue yet. I can not figure this out. I’ve been flying my drone for 2wks with no issues and now it won’t connect
2020-5-30
djiuser_EZ5kYq5DJKa1
I have the same issue, have only had this drone for one week.  I'm now going to try and buy an alternative cable to see if that resolves the issue as per the advice on this thread.  Ridiculous that DJI supply a product at this price point with such a flimsy cable.
2020-5-30
ScottishDroner
Robbiemoto Posted at 5-29 00:56
I have followed your lead and ordered the same cable.  Hopefully it will solve the issue for me too!
2020-5-31
Aristotle
Just arrived; tried two separate connectors (factory supplied and one I have on hand), and consistently getting the 'Accessory Not Supported' message; flipped the connector portion twice on each end. iPhone X; updated firmware (double-checked on this twice). Deleted Fly app and reloaded. How can something that is sold in Apple stores not actually connect? Any additional ideas?  Thanks!
2020-6-1
Jsgoecke
I am also having the same problem with a brand new Mavic Air 2. I got it to connect ONCE to with the DJI Fly app, and never with the DJI Go 4 app (why are there two apps anyway?). I have tried the following:
1. Ensured I am on the latest firmware on the drone and the remote controller
2. My iPhone is on the latest version of iOS
3. I have uninstalled and reinstalled the apps
4. I have tried a different USB-C to iPhone cable than the short once included
All to no avail. I know the remote itself is paired as I may start and stop the drone. I just can’t get the apps on the phone to work. I find this COMPLETELY UNACCEPTABLE and this will likely be going back shortly. I am astonished that DJI has not responded to this thread, nor to inquires. I will be opening a ticket to give them one last chance.
2020-6-3
Jsgoecke
I went to DJI support and they ultimately said send it back for service. I don’t have time to spend $800 on a product to just turn around and ship it back. They should have offered an exchange at the minimum. Therefore I am returning for a full refund and likely will think twice before buying another DJI product. This is unfortunate, as the other products I have had from them have been great quality.
But the fact they want me to send for service, when it is clearly defective, is a big no no for customer service.
2020-6-3
fansc1a235ea
Flight distance : 15174 ft
Same thing here but I'm on a Note 9. I have about 20 minutes total flight time on it in the three weeks I've had it. I updated the firmware before our trip to Florida where we planned to do a baby reveal with the drone and now it won't connect. I spent hours researching, purchased a new USB- C to USB-C cable and still nothing. I have had 4 dji drones and this has really left a sour taste in my mouth. Any tips would be appreciated, we have one day left on vacation.
2020-6-11
Tuzair
Flight distance : 26742 ft
Got the same problem, I tried a lot of cables and smartphones, but that make no sens, sometimes it's works and sometimes ( most of time ) not
2020-6-12
fans68f26d47
Ethiopia
The same for me, I just got my new brand Air 2 and I'm not able to connect with the RC at all. I tried everything but all to no avail. I'm really upset for that.
2020-6-27
