When zooming in, mavic turns to left
2881 18 2020-4-11
jakechristensen
I'm having an issue.  Whenever I zoom in, the mavic 2 zoom turns to the left.  Any ideas on how to fix?
2020-4-11
DJI Natalia
Hi jakechristensen, could you please provide us with a video so we can help to check the details of the issue? Thanks.
2020-4-12
Gobopolice
Flight distance : 926745 ft
Mine has also just started doing the same
As I manually zoom in the craft starts rotating left slowly, as i release the zoom dial it stops, but also resumes when trying to continue zooming, even when camera is at full zoom the craft will still rotate left, on zooming back in..... yes you guessed it it rotates right...
Odd behaviour from the craft.
I have recalibrated the compass, imu, and control but it still is not 100's
2020-6-3
nikusha73
Flight distance : 965505 ft
Georgia
I have same issue. It's not happening all the time I'm zooming in and it looks like not the whole drone, but only camera is rotating. Need to do some tests to see if it's actualy camera rotating left.
2020-9-17
jmb63
Flight distance : 7009439 ft
I have this same issue but it is on the Mavic 2 Pro.
The Thumbwheel (right side) that  controls the aperture ...(.which does the zoom on the Zoom's camera).... makes the drone turn left or right if held at the end of it's range (held against the "stop") .. This doesn't appear to actually happen when moving though, just if hovering!
Very weird and I originally thought the controller is going bad! But, now that I see this post, I realize that maybe it is software some how ?
Ohh, the smart controller does NOT do this, just the "regular" controller
2020-9-17
Blériot53
Flight distance : 6260935 ft
I haven't experienced this effect whilst doing a zoom ( in or out) but at the end of the Zoom, there is a slight drift of the camera direction, as though there might  be a slight lag on the zoom control. For me, it's very slight, and settles after a 1 to 2 degree drift lasting maybe a couple of seconds. I will pay more attention next time the drone is aloft.
2020-9-17
nikusha73
Georgia
Do some tests today. It's actualy drone turning to the left, not the camera. When right dial is at the end position it turns slowly, But when actualy zooming it turns very fast. Zooming out returns original position. To turn this wierd "feature" off, it's enough to turn drone right or left with stick. But then, in uknown moment, it starts rotating again
2020-9-17
Francis
Flight distance : 774203 ft
which remote control all you using.
2020-9-17
nikusha73
Georgia
Standard remote.
2020-9-17
Melo
Flight distance : 3469603 ft
I have the same problem, in my mavic zoo, can someone help me?
2021-1-16
fans75a3530f
I have the very same issue. Any hints for a solution?
2021-1-24
szpilman
Flight distance : 7110 ft
When zooming in, mavic turns to left.
2021-1-31
arg_tigger
Flight distance : 2189816 ft
Argentina
Same happening here, not always but when zooming in drone rotates left.
2021-10-8
Sean-bumble-bee
Flight distance : 15997 ft
What firmwares and app versions are you folks on?
drone (Zoom) 01.00.0510
controller (RC1A) 00.01.0510
app 4.3.37
No problems with the above.
2021-10-22
fans121cd252
Flight distance : 4694724 ft
So how do we fix this problem?
2022-2-21
JTK
I have the same issue. Any idea how to fix this problem?
2022-8-13
stopgogo
Flight distance : 531732 ft
Bosnia and Herzegovina
me too... help
2022-9-8
REMOVE DC NFZ
Flight distance : 942671 ft
So did they figured out what cause this problem or the fix?
2023-5-11
ljpremappinghotmail.com
Auto calibrating the gimbal sorted it for me
2023-8-20
