Vimarsh Gowda
Flight distance : 277992 ft
djiuser_kuvaEQvpV3Mf Posted at 10-2 14:27
I did read the numbers carefully and I do have the FCC model. You are bragging about 1.2 km? Are you really serious? I work for an internet company and I do know for a fact that 2.4 ghz has much more range. I just received my range extenders, shut my Bluetooth off of my smartwatch, shut the wifi and Bluetooth off of my cellphone and it is still terrible. I think you guys falsely advertised on the Mavic Mini BIGTIME.
Hi, first things first.
1. Dow load DJI Assistant 2 for Mavic
2. Update the firmware of mavic mini and controllers separately.
3. Once switched on, calibrate the compass, IMU and gimbals.
4. Calibrate the RC controller also , there is a option in DJI fly.
5. Calibrate your mobile compass. In Google Map, press the GPS location and see the blue center dot of your exact location, click on that blue dot and you will get a option to calibrate your mobile compass.
Once all calibrated, connect and fly.You will get 1000 Meter . If you're in city ,good range is 700 to 900 meter, If no interference; 1000 can be archived easily . Try this work, Still you can find DIY range extenders. Search in youtube you will get it. Remember, DJI MINI Manual has instructions for use of DJI assitant 2 firmware update |
