video timestamp incorrect
8248 24 2016-5-29
dick nixon
Flight distance : 206401 ft
I have noticed that after I import the photos and videos off the SD card, the timestamp for the videos is off by 4 hours.  The photos are correct.  For example, I was flying around 7 PM last night.  The videos indicate they were taken around 3 PM, but the photos correctly indicate 7 PM.  Is there some setting where I can get the clock for the videos set correctly?
2016-5-29
FAS1
Isn't there a setting in the MC area?
2016-5-29
dick nixon
What is the MC area?
2016-5-29
DJI-Paladin
Flight distance : 2408 ft
Hello Dick, what kind of drone and sd card do you use? Do you try to reset the camera settings and adjust your time settings in your mobile device?
2016-5-29
dick nixon
I am using the P3A, the stock SD card and a iPad Air 2.  I don't see how the make of the SD card could impact the timezone being off by 4 hours, so your line of questions see very odd.
I import the photos and videos off the SD card directly to my Photos on the Mac.  I do this routinely with other cameras (GOPRO, iPhone, Cannon, Nikon), and I don't have any similar issues other than some camera might be off by an hour if the day light savings time is off.  My guess is the camera on the Phantom has separate clock or timezone setting for the photos and videos.  The videos setting must be wrong, but I don't see anywhere in the settings to adjust it.
2016-5-31
Phantomski
Flight distance : 14869882 ft
Is your mac set up to the proper time zone? i ave noticed that my windows will sometimes adjust time of downloaded photos, if the camera is configured for diff time zone, or perhaps does not have daylight settings turned on...
I cannot recall anything on the GO app where you set the timezone, I assume it comes from the phone/tablet.. but I might be wrong.
Weird!
2016-5-31
mriksman_mavic
Confirm i'm having the same issue. After flying the Mavic Pro, I take the SD Card out and download the pictures and videos. Pictures show correct date in my iOS Photos album, but videos are 8 hours ahead. I am +8GMT. So it seems Apple is displaying the wrong time/date on videos due to some issue dealing with UTC and Local time.
2017-1-4
JohnnyD34
I'm having the same issue.  Photos show the correct date/time however the vispdeo is 11 hours ahead.  I am +11 GMT.  I'm using an android device.  When I was using an iPad it had the correct date/time stamp
2017-1-5
Bundyman
Flight distance : 27740 ft
My Phantom 4 is the same except it it 10 hours ahead. Have tried different cards, formatted with 32 fat and exfat still the same. Have tried it on three different devices, e.g. iPad Pro, iPhone 6s Plus and iPhone 6s all the same. The only way to get the time correct on the video is set the time back 10 hours on the device and than it shows the time as correct. have been in discussions with DJI and now they want me to send the aircraft to them so they can see the error
2017-1-20
scoutdogg
Flight distance : 1699600 ft
Same issue here! I took photos and video yesterday with my Mavic 2 Zoom. When I imported them via Wi-Fi from the drone to my iPhone X using the built in import features of the DJI Go 4 app, the pictures show as 10am (correct) and the videos show as 2am (incorrect). I’m in the Pacific timezone (GMT -8).
I’ve noticed the pictures and videos have always had timestamps that are out of sync with each other since getting my first drone (Mavic Pro Platinum) just over a year ago.  I’m surprised it isn’t fixed by now.
Anyone here heard a solution yet?
2018-12-28
fansd27a86a2
Flight distance : 15860 ft
I’m also having the same issue with a Mavic 2 zoom. The pictures are correct, but the video is off by -4 hours. I am -4GMT. It’s obviously a problem with the firmware, but I don’t understand why i don’t hear more people talking about it and why DJI isn’t addressing it!
2019-3-29
jocamero
Flight distance : 577487 ft
Having the same issue with a Mavic 2 Pro (with of course the latest firmware).
Any resolution to this issue?  Or does DJI not monitor these forums for bug fixes to their software?
2020-1-5
Mark The Droner
Flight distance : 2917 ft
I don't have this problem.  But my understanding is the AC gets its time and date from the mobile device.  So you might double check your mobile device and be sure everything is correct as far as time, date, time zone, etc.  Another idea is deliberately set your mobile device to the wrong time to trick the AC.  Just an idea.  Good luck
2020-1-6
headhacker
This forum question started in 2016, and has spanned almost all DJI product lines, and now it is October 2020, and Mavic Mini has the exact same issue.
I can confirm that it is not a SD card issue, nor my Mac settings, or anything extraneous. I've checked the EXIF data in both a picture and movie, and they are indeed 4 hours apart. Which is my timezone at the moment. The bad part is that some dates have a TZ component which is correct, but the time never varies. So it assumes current timezone and adds it anyway.
For reference, here are the EXIF tags being generated. The issue should be clear from the data below. These two were taken about a minute apart (1:06) for reference.
[System]        FileModifyDate       : 2020:09:24 18:14:47-04:00
[System]        FileInodeChangeDate  : 2020:09:24 18:14:47-04:00
[ExifIFD]       DateTimeOriginal     : 2020:09:24 18:14:47
[ExifIFD]       CreateDate           : 2020:09:24 18:14:47
======== 20200924_221553.MP4
[System]        FileModifyDate       : 2020:09:24 22:15:53-04:00
[System]        FileInodeChangeDate  : 2020:09:24 22:15:53-04:00
[QuickTime]     CreateDate           : 2020:09:24 22:15:53
[QuickTime]     ModifyDate           : 2020:09:24 22:15:53
Is there a setting to fix this in the software/firmware? Very annonying when naming fiies by embedded date, which is how I found this. I was going to rename all my media, and can't easily due to this issue.
Again - same Mavic Mini drone, same day, same microSD card, same flight, same Mac - different timestamps.
Thanks,
Jon
2020-10-19
cheddar-man
Flight distance : 44062 ft
Never noticed, must have a look!
2020-10-20
ProSki23
Took a shot today which is time stamped as 29/10/2020 - 4:37pm.
The Video I shot moments later is stamped 30/20/2020 - 3:38am.
11 hours ahead of the correct time ------------ Correlates to our Summer Time of GMT +11; as if the offset is applied twice.
Now notice that all Photo's & Videos follow the same pattern.
Haven't search past hitting this old thread yet, but surely there's a simple answer 4 years down the track.
Edit:- Should have added it's a Smart Controller I have; no phone involved.
2020-10-29
cheddar-man
There's something a bit wrong with your second date as well, no such month as "20" - or is that a typo?
2020-10-29
cheddar-man
Czechia
Just been out to record a video and take a few pix and the date stamps are correct slo not sure where your problems le? I'm in the UK.
2020-10-30
endotherm
Flight distance : 503241 ft
cheddar-man Posted at 10-30 06:26
Yet strangely, your movie was started 5 seconds before the photo, but the photo gets a filename of 0001 and the movie gets a filename of 0002.
2020-10-31
cheddar-man
Pass!
I did take off with the video running (I think) and then snapped a photo once up as I wanted to check the date thing.
Can't say I'm too bothered by it, I've got the pictures I wanted so what they're numbered is somewhat irrelevant
2020-10-31
endotherm
cheddar-man Posted at 10-31 00:55
Pass!
That would explain it.  I don't think the video is written out to storage until the camera buffer is filled, hence the later filename, but it still uses the correct start time in the EXIF.  I just thought it was a curiosity.
2020-10-31
snorbaard
Apologies for digging out this old topic, but I noticed that same problem. Video exif timestamps are out for me. I suspected this at first, but the kinds of responses here seem to indicate that the device is recording at GMT but incorrectly applying the time zone. I'm GMT+2, but the EXIF timestamps are two hours ahead. I'm currently manually adjusting the times.
2021-1-18
Scheize
I have this same issue with my Mavic 2 Pro.  The videos are 8 hours prior to my photos which are correctly timestamped (on computer and iphone).
What is the solution????
2021-2-10
Colin Lyon
Scheize Posted at 2-10 15:15
I don't think there is a solution, has anyone actually taken the time to get a hold of DJI about this?.
I've started uploading all my videos from my spark to my phone and backing them up to the cloud as opposed to taking the s d card out of the drone. they back up to the Google cloud and that's when I noticed that half of my videos that I back up that I recorded at the same time as I took the pictures, show up as yesterday.
It's not the date or time taken from the aircraft, because the photos and videos have different date time stamps. The date time stamp on the pictures is correct, and the date time stamp on the videos is from yesterday.
2021-2-14
Scheize
Colin Lyon Posted at 2021-2-14 12:03
Still doesn't look like a solution.
2022-9-20
