Flight altitude restrict
5403 20 2020-12-31
fans2b288274
Flight distance : 1029764 ft
Around a month ago, I have updated battery for once and after that some time this notice informed  “ Flight altitude restrict, log in or go to real name authentication”
Ps. I have already log in in app and wepsite.
2020-12-31
Id try to force quite the app and see if that helps.
2020-12-31
RobZilla
Flight distance : 1057844 ft
In addition to force quitting the app, have you checked the location where you're flying with other apps or websites? Obviously you've hidden the picture so hopefully its not an area thats meant to be restricted like an airport.
2020-12-31
fans2b288274
DAFlys Posted at 12-31 09:44
Try many times but did not help much
2020-12-31
fans2b288274
RobZilla Posted at 12-31 09:55
It was a resort camps, so close to any restrict areas
And ever fly in here with bo restrict before
2020-12-31
djiuser_WpD2lOJLRBIJ
Flight distance : 1476125 ft
Un-install the app and reinstall.or clear cache for the app.ur operating somewhere restricted.but it’s an orange notification. Not red. Is this in USA.?
2020-12-31
Hello there. I am sorry for the trouble this has caused and thank you for reaching out. Can you please try to uninstall and reinstall the DJI Fly application for us to be able to isolate the said issue. If the issue persist kindly please send and email with regards to this matter to our fly safe department at flysafe@dji.com for further assistance. Thank you.
2020-12-31
fans2b288274
DJI Stephen Posted at 2020-12-31 20:58
Hello there. I am sorry for the trouble this has caused and thank you for reaching out. Can you please try to uninstall and reinstall the DJI Fly application for us to be able to isolate the said issue. If the issue persist kindly please send and email with regards to this matter to our fly safe department at  for further assistance. Thank you.
Uninstall
Reinstall
Clear cache
But the problem still persists
2021-1-1
fans2b288274 Posted at 2020-12-31 15:44
Have you tried reinstalling?
2021-1-1
M1ssh0
Slovakia
I have the same issue and according my discussion with support it is a glitch on DJI side. I should try in 1-2 days.
2021-1-1
djiuser_wfgXzzCGUfYc
Flight distance : 247418 ft
I have the same issue well. I’m not able to go beyond 30 meters. Everywhere around me seems to be an altitude zone now.
2021-1-12
fans2b288274
djiuser_wfgXzzCGUfYc Posted at 1-12 12:36
Try turn cellular off
Or open flight mode
I do this and can bypass this problem
2021-1-12
GreenBarron
fans2b288274 Posted at 1-12 17:01
Or open flight mode
Thanks for your suggestion. I did not have the chance to test this yet on my drone but do you have a DJI Mini 2?
2021-1-14
EmpieDrone
Flight distance : 741102 ft
Or open flight mode
Hi. Very strange. I start flying with one battery. Everything OK. No restrictions. I bring back the MA2 for a battery exchange... AND???  Second flight is again with restrictions. I've done & tried everything. Sometimes a logout and new login helps.... Next time not. Yesterday I've tried turning cellular off... And Yes Bingo... This does the trick...  MA2+Iphone11+ all the last software/updates/firmware....
2021-1-17
Werner Franck
Flight distance : 2080886 ft
I have the same problem. Distance and height are limited. I fly with DJI Mini 2 coupled to Iphone 10. With one battery there is no problem at all, but with the other two batteries there is. SOLUTION : Disconnect the iPhone from the controller during the flight (plug the cable out and back in for just 2 seconds). Problem solved ! No restrictions any more during the flight. I've been looking for this for hours! Hopefully you have been helped with this.
2021-2-5
maihem.rc
Flight distance : 2076335 ft
Was there a recent update?  DJI used to reset the distance limit/beginner mode on updates so you'd have to go in and turn it off.  Are they still doing that?
2021-2-5
djiuser_AkSK3CAtgEys
Flight distance : 314944 ft
After updating firmware i am also facing same issue. Height is restricted as 29 Meters  and distance is restricted at 48 meters
2021-2-8
djiuser_AkSK3CAtgEys Posted at 2-8 20:38
The answer is staring at you on-screen. Login to your DJI account on your phone to remove the restriction.
2021-2-8
djiuser_Xv3bm8MVORk1
Flight distance : 408484 ft
Same issue here. I have tried reinstalling the app, and I have tried logging in with different users, but they all give me altitude zones everywhere and don't allow more than 29m/49m. iPhone 12 mini.
2021-2-12
kevinbkk123
Brand new Mavic Air 2 and have the same issue. Cannot fly more than 50 meters (horizontal) and 30 meters (vertical). I get the same message ("Log in or go to real-name authentication") despite being logged in and having the drone linked to my account. What a bummer! Seems like this issue affects many based on all the various forum posts I've seen.
Has anyone here found any solutions? Or acknowledgement from DJI of the issues?
2021-4-7
Lofty29
Flight distance : 6919 ft
My DJI Fly app says Altitude Restriction 60 or depending where I am 150.
60 or 150 WHAT. FEET, METERS,? What unit are the heights in?
2022-1-2
