New Osmo Mobile 3 Firmware Released (02/01/2021)
14916 17 2021-2-1
DJI Support
Flight distance : 2408 ft
Overview:
  • Date: 2021.02.01
  • Firmware: v01.00.00.90
  • DJI Mimo App iOS: v1.5.11
  • DJI Mimo App Android: v1.5.10
What’s New?
  • Added support for AI Life when using a Huawei phone (requires EMUI v11.0 or above and AI Life v11.1.0.302 or above). If no prompt appears after updating the firmware, the system of the phone needs to be updated to EMUI v11.0 or above.
Notes:
  • If the update fails, restart Osmo Mobile 3, DJI Mimo, and re-connect the mobile phone’s Bluetooth, and retry.
2021-2-1
djiuser_ThN8NYCh2CA8
WARNING: Mine worked fine with the iPhone 12 Pro till I updated to the new firmware. Yes, I know it's not listed as a compatible phone, but it was working like a champ before the update. Now, every time I shoot a video with the DJI Memo app and the Osmo 3 and import it into Final Cut Pro it imports sideways and cuts off the ends if you transform and rotate it 90 degrees. Most bizarre! I contacted support and when the technician heard that I had an iPhone 12 Pro they said it's incompatible and that I was "lucky" it worked at all. They literally said that! They said that updating to the new firmware made my luck run out. I kid you not! Not happy at all. If they don't add support for new phones this thing will be obsolete real fast.
2021-2-4
VanzPix
Flight distance : 229672 ft
(huawei p30 pro).
firmware update fails, I restart several times, deleted the application then reinstall and still impossible to install firmware. Frankly dji has each new firmware it's the same.
it's annoying
2021-2-6
VanzPix
30 attempts and still failed to install the new firmware...
2021-2-6
AlanHd
Flight distance : 797365 ft
VanzPix Posted at 2-6 04:52
I’m always scared to update DJI firmware, they never seam to offer any new features that I care about yet manage to break something usually.
2021-2-6
DaveSp
Flight distance : 6562 ft
djiuser_ThN8NYCh2CA8 Posted at 2-4 05:08
Thanks for the heads up. I have the 12 Pro Max and my OM3 works with it fine - I'll pass on this update as it's not needed.
2021-2-8
djiuser_GnMPcFvaFZ3g
I'm trying to make work my iPhone 12 Pro Max with the Osmo Mobile 3 but is very unstable and swingy. Somebody can help?
2021-2-11
ChristoM2021
I have been going through all these steps for the past two days and still my Osmo download/install to 93% and then bombs out. Getting very frustrated by this
2021-2-11
AlanHd
ChristoM2021 Posted at 2-11 05:52
Try delete the cache for the Mimo app
2021-2-11
Pierre maxi2
Flight distance : 177874 ft
VanzPix Posted at 2-6 03:54
(huawei p30 pro).
it's annoying
I don’t know if I can help you but I have a p30 pro too
and I was able to flash it without problems ,my app is in 1.5.4
2021-2-16
VanzPix
Pierre maxi2 Posted at 2-16 05:49
Thanks but for the app it's good it's on the latest version 1.5.12, but it's the firmware that I can't get to update.
2021-2-16
VanzPix
I finally managed to do the firmware update, I have a Huawei P30Pro EMUI 11, the latest version of AI LIFE, but I do not understand how it works or what it actually serves
2021-3-30
plavilayilbijoi
Hello I bought dji osmo 3 on last June 2020  and I used 2maximum 4 times shooting some videos .. From December  onwards I facing  a Bluetooth connection issue  with my phone and dji am using samsung  s21. I thought my mobile has some problem so I changed my phone to iPhone 12 Promax still I am facing same issue 2 -3 times now I missed valuable work because of this worse product . I am working this  filming industry last 15 years and never seen such a worse product i definitely not to recommend this product to anybody and am planning to  the bad review on google and other social medias I am very unhappy with this worse product.
2021-4-3
HSchmidt
plavilayilbijoi Posted at 4-3 17:52
Gentlemen,
does anybody know if this new Firmware solves the Zoom jump from 1 to 10 times, rather than smoothly moving up or down? My phone is a HW Mate 30 pro with latest SW.
Thanks an regards, herbert
2021-4-4
MrSepo
Samsung Galaxy S10+ firmware update failed (2). Cache deleted, DJI Mimo app reinstalled, doing everything (restart Osmo Mobile 3, DJI Mimo, and re-connect the mobile phone’s Bluetooth, and retry.) - still same fail
2021-4-26
MrSepo
MrSepo Posted at 4-26 11:08
solved - location (GPS) must be enabled.
2021-5-11
Johnny2265
Is there a patch that allows the MIMO app to be installed on a Samsung Galaxy 21?
2023-9-15
Johnny2265 Posted at 9-15 07:59
Hello there. If I may ask, are you getting an error when trying to install the Mimo app from your phone? Thank you.
2023-9-22
