Wilfried5719
Flight distance : 105285 ft
Portugal
LeChuck71 Posted at 3-6 03:26
Ah I see, well I guess you have to use something like APK Mirror to get the older 1.2.1 version of DJI Fly.
I just checked it and its available, but use it on your own risk.
Thanks ! This APK-mirror is what I was looking for. I have downloaded all Fly's from the 1.2.0 on. Fly 1.2.1 is still in the app-store (now) so I can also get it there if needed.
However, (only) the 1.3.0 refused to be copied from my laptop to the apk-dir at the sdcard in my phone. The copie-info window started but then simply disappeared after 2 seconds and the 1.3.0 apk was not there. I then managed to get it into the maindirectory from where I could move it into that apk-dir.
I uninstalled 1.2.1 from my phone, restarted it and installed 1.2.1 from the local apk. But it says "Do you want to update this app?" and then you have no option to accept that or to cancel installing. I accepted, it installed well and it then turned out to (still) be Fly 1.2.1.
I have uninstalled 1.2.1 once more, restarted the phone and installed 1.3.0 from the local apk. I will go out testing it this afternoon and let you know. |
