Gopro on a Mavic Air 2
4207 9 2021-3-12
hhasanain
Flight distance : 1064308 ft
Saudi Arabia
Hello, I have a gopro and was thinking about mounting it on the MA2. I saw a few Vids with that being done. I wanted to get your view if I should try it.
Cheers.
2021-3-12
wilbo23457
I wouldn't because the Mavic Air 2 already has a good camera
2021-3-12
wilbo23457
2021-3-12
Flycaster
One must be careful when adding "stuff" to the bird. First off, it will cut your flight time down. How much? Don't know, but you will find out.
Adding mass will place more current needs on the esc's, battery and motors.
The bird PID values are "tuned" with the motors, ESC's, props, and the weight of the actual bird.
It probably won't hurt for the short term, but the bird will have shorter flight times, and may behave "not as you have felt" with the GP mounted...
Like above poster typed: You already have a good camera on the bird. Besides, no wide angle distortion/bent horizons....
2021-3-12
hhasanain
Saudi Arabia
Thanks all, it’s an eye opener with the load and ESC , makes total sense. Let the bird fly as intended
2021-3-12
JimDandy
Flight distance : 144649 ft
No,  it has a better camera already on it,  with a gimbal
2021-3-12
Id agree,  seems pointless,  now a 360 maybe.
2021-3-13
Hi, hhasanain. Thanks for reaching out! We strongly discourage attaching or mounting any accessories which are not designed for the Mavic Air 2 as it could potentially cause flight instability and could result in a flight accident.
2021-3-13
asv1970
Flight distance : 117247 ft
Costa Rica
I want to do the same. For experimental purposes only. Also, GoPro videos have audio.
2023-3-7
blue_canyon21
Flight distance : 24583553 ft
asv1970 Posted at 3-7 08:43
Why does audio matter? The only thing you'd hear is the sound of the propellers.
2023-3-8
