Use focus motor to control zoom?
6492 4 2021-3-15
KabeM
I'm operating an RS2/Raveneye combo as a remote wirdlife camera, and would like to control the zoom of the lens with the focus motor.
It works fine from the hardware side to control the motor, however, ho do I tell the software that this is controlling the zoom and not the focus? Right now setting up the motor seems to disable the focus control.
2021-3-15
alefteri
Hello! Go to Dial functions and select Focus Motor. Then with the front Dial you will be able to control the focus motorthat will turn the Zoom  or the focus ring(depending where you connected it)
2021-3-24
KabeM
Maybe I wasn't clear enough here: I have no problems to control the motor with the front dial. My issue is that I would like to use that from the DJI Ronin app, which „sees“ the motor as a focus device, nt a zoom device.
2021-3-25
alefteri
KabeM Posted at 3-25 05:20
when connected with the raveneye you can control the Zoom from the app for sure. It might say focus on the app but it actually controls the Zoom if the focus motor is connected on your zoom ring of the lens. You must enable the focus control (don't worry - it will control the zoom / they are called focus motos...)
to me it works fine
2021-3-26
djiuser_rbumeMucdHNH
alefteri Posted at 2021-3-26 04:24
to me it works fine
Do you know if it's possible to operate the focus motor of the DJI Ronin-S from inside the Android app? I would like to use it for slow smooth zooming.
2023-5-6
