Osmo action won't connect to Mac OS11
17897 17 2020-12-7
Siggii
Flight distance : 185991 ft
Hey!
Got the new Macbook Air with Apples M1 chip, and I'm now unable to connect and transfer files from my Osmo Action by USB-C. It works on my older intel-based macbook (using the same cable, so its not an cable fault) which is very strange. When I connect the wire, the camera charges, but it doesn't show "connect to computer" on the camera screen.
Anyone experienced the same, any solutions out here?
Edit: It works if I put an USB-hub between. Very strange. Same USB-C cable into a USB-C hub, connected to the computer by USB-C.
2020-12-7
erik.telepovsky
Slovakia
Same issue here. Have you figured it out Siggii?
2021-4-14
Benjamin R. Waber
Hey I figured it out! When you connect the DJI to your computer via thunderbolt what you do is turn the camera on, connect it, then turn the display off and back on again and my MacBook recognized the device and then you click connect on the Osmo and you should be all set.
2021-4-14
Benjamin R. Waber
I figured it out for you guys I believe
2021-4-14
djiuser_cYroGYH7uWP9
Ive tried the step recomended in the thread, unfortunately  however it does not  resolve the issue for me. The camera receives power from the macbook air, but the macbook does not register that the camera is plugged into it. Ive tried turning camera on and off, changed the order of plugging in, still nothing! Ive tested the cable on a windows laptop and it works, so there is no issue with the cable. Its seems to be related to my macbook. Any suggestions on how to resolve, other than buying an adapter?
2021-5-17
I have now tried to connect via usb hub, still nothing!
2021-5-18
DJIOS11
Having the same issue running macOS 11.4 on the MacBook Air M1. Has DJI said anything about a firmware update to fix this issue?
2021-5-26
sonu
I think every Mac m1 owner with Osmo action is facing the same problem. What really strange is YET THERE IS NO SOLUTION.
2021-6-29
jcyc91
Hello, I have the same issue as well on my M1 MacBook Air, I am on the 11.4 OS
I actually was able to connect to my Osmo action the first time I plugged it in, the touch screen asked if I wanted to connect to the MacBook and I hit accept and it all worked OK to transfer videos. But now the next time I'm trying I can't get my Mac to recognize the Osmo Action at all.
2021-8-14
GabbaTimeStyle
Im having the same issue someone help! I don't wanna have to buy another cord just to be able to transfer my data.
2021-9-23
jorge.k
I think Apple has to fix it. I have the same issue with an insta360 camera. Both cameras (osmo action and the insta360)  work with my old macbook. With the m1 air it works only with an usb hub.
2021-11-14
Calu
Argentina
I have the same problem, unfortunately aplle does not recognize the osmo action
2021-12-16
MicMan
Hey Everybody, got the same here (12/2021) with the MacBook Air. If you connect it via USB-C to docking station, docking station with USB-C to Macbook. It works. Strange, but it works...
2021-12-24
JamoATX
I get the screen prompt to accept connecting to my computer, but there is no recognition in the finder. I use a MacBook Pro. Hard to believe that this is a problem. All my other cameras (non-DJI) work perfectly. I reached out support and after 20 minutes of telling me how to fix this on a Windows PC (?) the agent stated that the M1 chip has not been tested and that DJI isn't able to provide a solution and recommended I tranfer files via the SD card, which would require another purchase.
2022-1-21
GLK.NineSix6
2 Things. If you have the older version DJI Action it may not be able to connect using an older Mac OS. The Montery version of Mac can connect mine. The Action 2 have means to get your files and use them whatever OS you use by inserting a blank SD card and "export" your files to the SD card. It's a bit slow and it get hot but it should do the trick. Also, you can connect your A2 to your newer version of Mac OS but you have tweak and find the "device." Which I don't recommend. I find it easy to copy or export the files from the internal drive to the SD Card. That's all I can think of....
2022-3-19
northaal
I had this problem with my P2 when I got a new M1MacBook Air. Previously no problems with an iMac (2015 vintage).
I can now get it to work under the following conditions:
1) Remove the Do It All Handle
2) Use the DJI supplied USBA charging cable that splits into two USBC cables - one for charging and the other marked with a USB Logo. Connect the latter to the camera.
3) Connect the USBA end to a Dock station fitted to the Mac. I used an Anger Dock.
Hope this helps someone.
2022-3-26
enjayaitch
Flight distance : 15023 ft
Dominican Republic
northaal Posted at 3-26 13:27
I was able to get it to work with simple USB-C -> USB-A -> USB-C chain (in my case with an Apple USB-C -> USB-A adapter and then a regular USB-A -> USB-C cable).
2022-10-20
DmMoscow
Flight distance : 807356 ft
Georgia
Osmo Action, Mac M1, latest firmware.
Tried connecting directly, tried connecting through adapter, tried different cables (original and not), tried praying to old gods.
April of 2023 - Still NO SOLUTION!
2023-4-22
